Mosko Moto Soft Bags for Offroad & Dualsport
Discussion in 'Vendors' started by Sideoff, Oct 14, 2013.
  1. Blake D
    Blake D Blake Draguesku
    Aug 20, 2019
    128
    White Salmon, WA
    Got it! I assumed you were speaking of the Basilisk since that is what we had on display. My bad!
    Sideoff likes this.
  2. THRASHED
    THRASHED In your helmet, no-one can hear you sing, I hope.
    Jan 4, 2013
    1,208
    San Dimas, CA
    I received my Pinner Tool Roll yesterday. I made a video comparison between it and my Fatty Tool Roll. Hope this helps someone. Pete, et. al, if this somehow offends you, or violates some form of copyright rules/laws, please let me know and I'll make it right.
  3. Grinder
    Grinder Wrong way 'round
    Sep 7, 2006
    3,351
    Ottawa
    This is really useful. It’s hard to get a sense of scale on video. Both look huge on the back of your bike. Is there a significant difference between the two? I carry a relatively minimal set of tools for my ktm.
    Sideoff likes this.
  4. THRASHED
    Jan 4, 2013
    1,208
    San Dimas, CA
    There really isn't a huge difference. If I pulled the tire levers and stand out of there it would drastically reduce the bulk.
    Sideoff and Blake D like this.
  5. Blake D
    Aug 20, 2019
    128
    White Salmon, WA
    Approximately 20 lbs depending on your pocket setup. (edited)
  6. Blake D
    Aug 20, 2019
    128
    White Salmon, WA
    The pant is designed to fit true-to-size with armor, so you should be good pairing your armor pant to a 34.
    For your temperature question: The majority of the venting is carried out by the zip vents themselves - this gives you a wide range of adjustment for temperature control. You should be just fine at 50ish degrees without a thermal, but this also depends on things such as how much heat your bike puts out (a KTM ADV is much hotter than a BMW) as well as it depends on what you consider to be "cold". I would suggest going for a few test rides and getting a good gauge of what setup suits you best, so that you don't get caught in the cold without the right gear. Thanks for the good question.
    Oeths and Snake Oiler like this.
  7. Blake D
    Aug 20, 2019
    128
    White Salmon, WA
    Thanks so much for chiming in with this comparison video @THRASHED
    @Grinder, There isn't a massive difference in size between the two rolls. I'd say the Fatty is roughly 1/3-1/2 larger than the Pinner in terms of tool capacity and packed size, depending on your setup. If you want to keep things as slim as possible, go with the Pinner. If you want some spare room for more tools or extra parts, go with the Fatty. You can't go wrong either way, and I'm sure either would suit your needs just fine.
    Grinder likes this.
  8. Blake D
    Aug 20, 2019
    128
    White Salmon, WA
    Thanks for following up with this update Wade!
    WADE-O likes this.
  9. herdygerdy
    herdygerdy Adventurer
    Mar 20, 2012
    10
    Sydney, Australia
    Many thanks for replying Blake, very much appreciated. My concern is also the height of the MM BC35s may also foul on my OEM silencer on RH side or force the RH back to sit up too high. I'll continue doing my research though. And one of your Nomad tank bags is definitely in my future too. Keep up the great work, love your products and the MM team culture. If only you were in Australia....sigh!
    Blake D likes this.
  10. Emgo
    Emgo Started on a CT70 almost 50 years ago
    Feb 23, 2015
    441
    Gladeville, TN
    ATTN: Andrew / Reckless 40 redesign team I have a request for the new R40. Would it be possible to make the beaver tail on the R40 like the R10? I think it would really be beneficial to folks who want to use a larger tailbag. It would allow a larger tailbag to hang out over the rear fender a bit.
    Thanks,
    Ken
    Sideoff and easyrider11 like this.
  11. OKDQ
    OKDQ Been here awhile
    Nov 7, 2009
    978
    OK
    I think you may have misread the question, he ask for the weight of the set and I’d guess you gave the approximate weight per side. Per my bathroom scale the new v2.0 of the offset panniers (a 35 and a 25) weighs 18 lbs. per “set”. That includes the external pockets that come with it but does not include the wedges that are mounted to the rack.
  12. Grinder
    Sep 7, 2006
    3,351
    Ottawa
    Thanks. That about settles it then. The fatty is probably three way to go.
  13. Snake Oiler
    Snake Oiler If the world didn't suck, we would all fall off
    Apr 22, 2016
    4,298
    Pennsylvania, but living in a toy hauler full-time
    Thanks Blake for your help and support. I should be good to go then. But it's probably too late to get the pants before I leave at this point. What kind of ETA if I'd call in an order tomorrow morning and deliver to NM? I'm leaving on the 26th of Sept.
  14. THRASHED
    Jan 4, 2013
    1,208
    San Dimas, CA
    @WADE-O thanks for the write up. Thinking about the jacket. Hopefully the Mosko gang wil be at the Long Beach motorcycle show again this year. I would love the opportunity to try this stuff on first.
    easyrider11 likes this.
  15. AdamChandler
    AdamChandler Ascending n00b Supporter
    Feb 29, 2016
    7,705
    Hanover, NH USA
    Unfortunately, got a tube blow out and had to tow her home but the Reckless 40 looks fantastic on the Beta 500. On a bike like this, it's definitely noticeable when you put everything in there for an overnight camping trip. You can feel the load behind you.
  16. THRASHED
    Jan 4, 2013
    1,208
    San Dimas, CA
    Nice setup, Adam. Just out of curiosity, was there damage done to the bike when you got the flat? Why didn't you just swap the tube?
    AdamChandler and jdubb75 like this.
  17. AdamChandler
    Feb 29, 2016
    7,705
    Hanover, NH USA
    had a tube and tools with me but forgot a pump. The tube actually failed at the stem. Probably the place that installed it didn’t line it up perfectly and it tore at the stem base. Tire and tube installed 15 hours motor hours ago. Took it home and it’s back in business with a new tube and a bath.
    Sideoff likes this.
  18. Oddfellow
    Oddfellow Beasty Rider Supporter
    Aug 26, 2002
    924
    Austin, Texas
    What trailer is that?
  19. AdamChandler
    Feb 29, 2016
    7,705
    Hanover, NH USA
    https://www.kendonusa.com/collectio...ducts/single-rail-folding-motorcycle-trailers
    It's a 2006 Model I bought last year off an inmate who had put only 800 miles on it for $350 and he delivered it up to NH for me. did some de-rusting, re-painted and re-packed bearings and it runs really well! It's pretty bouncy and loud unloaded but pulls the dirt bike perfectly. We only have parking for 2 cars at the house so the stand up trailer fits the bill perfectly.
  20. WADE-O
    WADE-O Been here awhile
    Jun 18, 2011
    761
    SAN DIEGO, CA
    Yep they are planning to be there! What size are you looking at? I live in northern San Diego so we could meet in the middle if you're interested.
    Sideoff and AdamChandler like this.
