Moto Guzzi V85 TT
Discussion in 'Moto Bellissima: All Other Dualsports' started by cabanza, Nov 7, 2017.
  1. Trialsman
    Trialsman Been here awhile
    Oct 17, 2011
    304
    Pittsburgh, PA
    Just got back from a ride tonight in the low 40*. The heated grips were very nice.
    XT Traveler likes this.
  2. the_babaji
    the_babaji Long timer
    Oct 10, 2011
    1,190
    Ontario, Canada
    Stock Grips? Do they get warm? Is the first of the three power settings even noticeable? Is the 3rd power settings smoking hot?
  3. Trialsman
    Oct 17, 2011
    304
    Pittsburgh, PA
    They are not as warm as I would like but on three they did keep me very warm.
    TNWalker likes this.
  4. OtterChaos
    OtterChaos Guzzi Sud!
    Nov 28, 2007
    2,540
    Grover Beach, Ca
    Current bike status
    Install was very easy, the Mistral stuff comes with new clamps and gaskets, fit right in with no drama. I'd say the bike sounds just like the video on Youtube about the Mistral exhaust.
    At my BiL's shop so took advantage of his experience to look at the rear wheel. We found a fairly large section that was tighter than the rest resulting in deflection of the rim up and down. I took video of it but don't currently have a way to post it, maybe when I get home I can work on getting it posted. After releasing spoke tension and then tightening things up again the wheel spins much truer but there is still some movement side to side where the rim was welded together, BiL says that can't be taken out with spoke adjustment so I'll put the wheel back on tomorrow and see if this helps with the front wheel hopping.
    Utrider1, XT Traveler, tsak8 and 2 others like this.
  5. Trialsman
    Oct 17, 2011
    304
    Pittsburgh, PA
    In putting on the crossover pipe it is very short for the overlapping joints. Mine first time had a leak, the second time I used a tie down to pull the sections closer together before tightening. Made a huge difference - no leaks. While you are in there why don't you turn the wheel into tubeless? It is not that hard nor expensive. It requires 3M Marine 5200 caulking for around the spoke nipples and 3M 4411 3" Extreme sealing tape. Go to a NAPA and get a tubeless valve stem and you have everything necessary but the time to do it. I did both of mine two weeks ago and they are holding air perfectly. I will try to post up some pictures of the process.
    Night_Wolf and OtterChaos like this.
  6. Jayell
    Jayell Been here awhile
    Oct 11, 2012
    241
    Pickering, Ontario, Canada
    What brand?
  7. Trialsman
    Oct 17, 2011
    304
    Pittsburgh, PA
    They were some ones off eBay that I had on my 990, no idea what brand, sorry.
    Jayell likes this.
  8. OtterChaos
    Nov 28, 2007
    2,540
    Grover Beach, Ca
    I'll check for leaks tomorrow but my crossover seemed to fit well. As for tubeless I used the outrex kit and it worked sorta on the rear tire but I pulled it off as I didn't like the way I did the area where the seams met and the front tire never worked well so I'm just going to run tubes for now.
    Forgot to add that I balanced the rim without a tire installed, it wasn't that far out but I used three 1/8oz weights to balance it out.
  9. jwdub
    jwdub Long timer Supporter
    Oct 2, 2005
    1,343
    SW Washington
    Jayell,
    I think I'll need some lube to muscle it on as it takes quite a bit of force just to get it on 1/2" after reducing the diameter to about 1.012.
    Torquemada likes this.
  10. Torquemada
    Torquemada Been here awhile
    Aug 12, 2007
    118
    TX
    I use air like this guy.
    Night_Wolf likes this.
  11. Jayell
    Oct 11, 2012
    241
    You're out less than ten thou now, it should go on quite easily once you get it started.
    I had almost 0.050" difference with mine. No lube, no glue. It'll go on with some effort and determination.
  12. Jayell
    Oct 11, 2012
    241
    Great idea for standard rubber grips, that's how I do it, too.
    I don't think it'd work with Oxford heated grips, though, as they're far too rigid and will not yield under compressed air.
    Night_Wolf and Torquemada like this.
  13. s-flow
    s-flow Adventurer
    Jun 18, 2011
    47
    Sweden
    Im also continuing to hunt down the cause of the "hop".
    Very exited about the mistral report, any change in ride characteristics?
    My rear wheel is now checked and rebalanced so both front and rear wheel is good, all mecanics still have some ideas about it still beeing some oddity with the front tire..
    so should I get a third tire of another brand or go straight on the fork.. not decided yet.
  14. XT Traveler
    XT Traveler Long timer
    Jul 11, 2007
    1,718
    SW Ohio
    Did you have to remap for the Mistral?? And if so what map did you use?
  15. tsak8
    tsak8 Adventurer
    Sep 22, 2010
    30
    Athens,Greece
    Nice job!
    How much weight did yoy get rid of?
  16. jwdub
    Oct 2, 2005
    1,343
    SW Washington
    RE: Oxford Grips. I used compressed air to remove the stock grips. However, the new edition of the Oxford grips are not rubber on the inside -- they are made with hard plastic and air is not going to expand it. In the past, I've made up my own from Symtec and just reused the stock grips along with a Heat Troller.
  17. OtterChaos
    Nov 28, 2007
    2,540
    Grover Beach, Ca
    No remap and as far as I know there isn't a remap available for the bike yet, the lamda sensors are located before the crossover so there should be minimal change to the ride. Have yet to ride the bike with the new exhaust, should be able to do so today. Oh and almost forgot I did NOT buy the V-TWIN booster thing they advertise alongside the exhaust, no way am I putting something like that on my bike.
    Sorry I didn't have a scale available to test it out. Just hefting them side by side there was noticeable weight savings but not as much as I though there would be, I think the muffler (I bought the carbon version) provides the biggest change in weight and the cat isn't as heavy as I thought it would be.
    Utrider1, tsak8 and TNWalker like this.
  18. jwdub
    Oct 2, 2005
    1,343
    SW Washington
    otter chaos, can you post a sound track for the Mistral? I assume that you just installed the slip on. OOPs, I see now that you also removed the cat.
  19. the_babaji
    Oct 10, 2011
    1,190
    Ontario, Canada
    AF1 racing was not able to fulfill my order with the latest shipment that just came in. Next shipment is 4-6 weeks away.
    Guess I'm gonna have to roll my own.
    Could you post the instructions for the install of the grips. I'd like to see how they routed them.
  20. OtterChaos
    Nov 28, 2007
    2,540
    Grover Beach, Ca
    Here is what I got for the Moto Guzzi heated grips
    Both grips have internal tubes so install should be a snap. You actually replace the entire throttle housing, might explain the high cost. Also included are two new inserts for the handlebars. No instructions included even if the packing list says it is included. I searched 2S001435 Moto Guzzi and found a link to an online PDF of the instructions.
    dedave likes this.
