Moto Guzzi V85 TT
Discussion in 'Moto Bellissima: All Other Dualsports' started by cabanza, Nov 7, 2017.
  1. DesmoDog
    DesmoDog Desmo was my dog. RIP big guy.
    Jun 25, 2009
    1,159
    Michigan, USA
    Which connector are you refering to? The one I'm talking about has two posts and is there to power the (uninstalled from the factory) USB under the seat. But I'd be fine plugging into that one instead.
    I thikn the other two I referred to (red and grey) are an OBD port (red) and the connector for the MIA box (grey).
  2. 30yGS
    30yGS Adventurer
    Dec 22, 2011
    94
    Townsville, Qld, Australia.
    There is a USB kit (2S000315) which looks like it will plug straight into the connector and then plug into the tool tray aperture
    Night_Wolf likes this.
  3. Mozman16
    Mozman16 Been here awhile
    Mar 16, 2009
    100
    Sydney Oz
    I've had to do mine and it's dead easy, assuming you can find a nice flat road to sit between 29-31 km/h, no more, no less, for however long it takes to 'calibrate' :muutt
  4. Grinnin
    Grinnin Forever N00b Supporter
    Dec 10, 2005
    7,049
    Maine
    I can't think of a flat road within 50 miles.
    That's not usually a complaint.
    DesertPilot likes this.
  5. Bent-Rim
    Bent-Rim Adventurer
    Sep 28, 2019
    11
    Larkspur, Calif.
    ^I'll bet Red Green could rig up a treadmill to do your calibrating on.
    Grinnin and DesertPilot like this.
  6. KRGaijin
    KRGaijin Adventurer
    Jun 29, 2020
    48
    Texas
    Yes, that's the one I'm talking about -- the one for the under-the-seat USB connector.
  7. McGoff
    McGoff Adventurer
    Apr 22, 2017
    46
    Sydney
    this was on a facebook group, it shows an optional USB outlet fitted to the bike
    I don't know anything about it, it may be a factory option
  8. KRGaijin
    KRGaijin Adventurer
    Jun 29, 2020
    48
    Texas
    Yes, that's exactly it. The plug is there; this picture shows the optional USB part plugged into that socket and then mounted in the mounting spot. All the bikes have that socket, but none of them come with the USB port already installed, that's something you buy separately.
  9. DesmoDog
    Jun 25, 2009
    1,159
    Michigan, USA
    Ahh... now I see what you mean. I had only seen pictures until I looked for it on my bike and saw this:
    Then I went fishing and found the it dangling behind the sidecover. Pulled it out and saw that yep, there is a connector I could use there.
    But where does one buy just those pins? I'll google it but have to think unless I can find them locally it'll have to wait until I'm ordering something else from anywhere that has them.
    Anywhos, thanks for the info, I'll put it to use eventually!
    EDIT: I ended up ordering a bunch of pins, seals, and even a couple connectors from Digikey. Shipping was $4.99, and it's worth that to not have to leave the house and search for them. What the heck, now I can make leads for numerous things, like, um, well... you know, all that stuff that needs power. Ah crap. I just realized I forgot to add the third size of pins for larger wires. D'oh!
  10. DesertPilot
    DesertPilot Long timer
    May 18, 2014
    1,058
    Mountain View, CA
    Got the report from the claims adjuster, made an appointment with the shop, arranged a truck, and if all goes well, the bike goes to the shop on Monday :clapUnless something unexpected turns up, the work would be replace one fork, engine bars, instrument cluster, brake pedal, and some plastic, and do some minor stuff. WIth luck, they'll have it fixed just in time for the next pandemic lockdown...
    OtterChaos, mnuttall87 and MrKiwi like this.
  11. KRGaijin
    KRGaijin Adventurer
    Jun 29, 2020
    48
    Texas
    Glad you found it. You're not the only one, I've heard from a couple of guys with Travel models who thought they didn't have the connector at all. On mine it was attached to the side of the battery tray, like you saw in that first picture, but I guess at least some left the factory (or the dealership) with it just dangling loose down the side. My understanding is that every bike should have one.
  12. relayer4u
    relayer4u Been here awhile
    Mar 26, 2018
    133
    Henderson, NV USA
  13. BOOTLACE
    BOOTLACE Bikie Scum. Supporter
    Dec 24, 2005
    12,025
    Methane Central..(Sth Gippsland)
    Be interested to hear the costs of some of that stuff. Particularly the TFT unit......
  14. MrKiwi
    MrKiwi old enough that I should know better Super Supporter
    Oct 16, 2009
    16,331
    New Zealand
    Having Oxford heated grips fitted to my goose today. When I rode it to the dealer this morning it was only 5 degrees C, looking forward to not having cold hands anymore.
  15. DesertPilot
    May 18, 2014
    1,058
    Mountain View, CA
    They may only have to replace the mounting bracket, but if I find out, I'll let people know.
  16. 30yGS
    30yGS Adventurer
    Dec 22, 2011
    94
    I have just recalibrated mine after replacing a rear tire (puncture damage), went to a flat straight road near home, set it to calibrate, got up to about 30, the screen said maintain constant speed and it was done in about 2 seconds. :-)
  17. MrKiwi
    Oct 16, 2009
    16,331
    New Zealand
    Alright, this is a lot better. I like the wider diameter handles too, easier with my long fingers.
  18. Night_Wolf
    Night_Wolf Leg Humper
    Feb 17, 2006
    9,940
    Lat: N 90°00'00" Long: N/A
    I knew my Travel was supposed to have the connector, but I couldn't "find" it initially. Had to pull the battery to grab it; friendly fella in England is sending me a connector with bare leads so I can use it to "trigger" the relay of the Eastern Beaver 3 circuit fuse panel.
  19. motomoda
    motomoda Long timer
    Apr 23, 2016
    2,166
    Oz
    Exactly. It's neither hard nor arcane in its implementation. Choose the function in the dash, ride the bike, it doesn't take far, when the indicator stops flashing? Job done!
    DesertPilot, Reddog* and MrKiwi like this.
  20. BlueBluer
    BlueBluer Adventurer
    Mar 24, 2014
    38
    Dijon - France
    The brand name of those connectors is Supaseal and you can get them easily of all sorts of websites - there is also a crimping tool for them that's really handy if you are going to mount a few of them - can be done with thin pliers but not as neatly. As for the USB kit ... what a ripoff ! I saw it at 71€ on Ebay.... for a connector and a USB socket (and maybe a fuse....). I'm sure it could be assembled for about 15$
    Something like this (14$) ... a bit of DIY ...
    Night_Wolf and DesertPilot like this.
