Moto Guzzi V85 TT
Discussion in 'Moto Bellissima: All Other Dualsports' started by cabanza, Nov 7, 2017.
  1. speedysheep
    speedysheep Been here awhile
    Sep 16, 2005
    342
    Indianapolis, IN
    I rotated my bars forward a tad, so they work better while standing. The bars just touch the bag at full lock. Not really an issue.
  2. Reichegg
    Reichegg Adventurer
    Sep 16, 2006
    58
    Netherlands
    Okay, thank you 'Speedysheep' for the answers!
  3. guzzijason
    guzzijason Adventurer
    Mar 25, 2021
    97
    Philadelephia
    Or, Euro4 (E4) vs Euro5 (E5).
    Yeah, the new 11MP ECU is also shared with some Aprilia models. Each new generation of ECU gets harder an harder to crack. I figure I'm just going to plan on leaving my '21 exhaust/fueling stock until maybe next year, which will hopefully give tuners some time to figure out more options.
    __Jason
    Cal likes this.
  4. TimmyTheHog
    TimmyTheHog Been here awhile
    Jan 11, 2017
    506
    Surrey BC Canada
    Thanks! just happened to found it before you linked it!
    It def has a lot more information...but like you say, there are still things missing.
    Ya, I know this doesn't make a motorcycle bad, but it does put a sour taste in my mouth as I am a manual junky, and I like to know what I am getting into IF and WHEN I have to deal with stuff on the road.
    P.S. do you know what the torque value for the Engine Drain & Transmission Drains are?
    P.P.S. Funny how V7iii Engine manual says 22NM for Oil Sump Drain & Filter Cap, 27NM for Gear Box Filler Cap and 30NM for Gear Box Filter Cap. Meanwhile everywhere else I keep on reading saying these are too high...?
    Anyway, I am digging into nitty-gritty now...
  5. GerardW
    GerardW Been here awhile
    Apr 2, 2019
    113
    Port Elizabeth
    As I'm very new to MG and specifically this bike, it has a 'drone' in the engine at low gears below 3000revs. You feel it through the pegs. No strange noises. Smooth in all gears above 3000. Feels a bit strange. Is that what it should feel like ?
  6. KeithGB
    KeithGB Adventurer
    Jan 16, 2006
    17
    Buckinghamshire UK
    What tyres/tires are using, knobbly treads can be noisy at certain speeds or lean angles.
    Pbro63 likes this.
  7. Jayell
    Jayell Been here awhile
    Oct 11, 2012
    418
    Pickering, Ontario, Canada
    Give it more Rs. Mine is never below 4000.
    RedHawk47 and twowheeledgator like this.
  8. TimmyTheHog
    Jan 11, 2017
    506
    Surrey BC Canada
    Rev More
    None of my Guzzi likes it below 3K...usually run them @4 or more.
    only time I have to go below 3 is in a super slow traffic.
  9. Jayell
    Oct 11, 2012
    418
    I pay attention to torque values on things like wheels, brakes, forks, etc.
    For drain and fill plugs? I don't care. Snug, and no more.
  10. ducwad
    ducwad Livin' the dash Supporter
    Jul 23, 2004
    360
    Duvall,WA USA
    Same here. Thanks for taking the bullet here @RedHawk47 and saving us from learning the same lesson the hard way!
  11. ScottTheFalcon
    ScottTheFalcon Been here awhile
    Aug 14, 2017
    244
    Brisbane AU
    I can confirm the same for '21 models, thank you both.
    While in there I became intrigued by this other connector - the 3 way super seal with only the 2 outer contacts used and nothing plugged into it:
    Unknown - anyone?
  12. SCExpat
    SCExpat Ex-expat
    Dec 31, 2009
    933
    Nampa, ID
    Diagnostic port to read error codes. Use this to connect Guzzidiag with the right cable.
    Pbro63 likes this.
  13. DesertPilot
    DesertPilot Long timer
    May 18, 2014
    1,548
    Mountain View, CA
    Matrix Generator. When enough V85 TTs are in the right position, someone in Mandello flips a switch and everything in this universe shifts over to the Guzzi Universe.
  14. ScottTheFalcon
    Aug 14, 2017
    244
    Brisbane AU
    Really? I was sure that is the red (from memory) DT looking plug near the ECU under the seat. Pretty sure anyway :)
  15. SCExpat
    SCExpat Ex-expat
    Dec 31, 2009
    933
    Nampa, ID
    You may be right. I do not have a V85 yet......but it sure looks like the diagnostic plug. What else could it be???? Could there be one for the ECU and one for all the dash electronics????
    A quick search and I found out that the V85 uses a different connector for the ECU diagnostic plug. https://www.lonelec.co.uk/Motorbike...ke-Adaptors/Euro5-6-Pin-OBD2-Adaptor-ISO19689
    So what is that connector used for???
  16. ScottTheFalcon
    Aug 14, 2017
    244
    Brisbane AU
    If I'm lucky, oh so lucky - it'll be a high beam signal I can use. Oh that would be nice :)
    I'll put a meter on it next time I'm in there and flick some switches...
  17. jrt
    jrt Been here awhile
    Nov 3, 2005
    305
    St. Louis
    There is at least one Centenario (sp?) here at the nationals. Someone from Kentucky. The color scheme looks nice in person.
    Cal likes this.
  18. Magile
    Magile Long timer Supporter
    Apr 11, 2005
    1,182
    HVL, NC
    I wouldn't mind something completely different...like this...
    " A limited edition, ultra-exclusive track-inspired machine modeled on Battle of the Twins racers, the Ghezzi & Brian developed MGS-01 remains about as exotic as Guzzis get by way of its 121bhp, Cosworth-bedecked engine, top spec Brembo stoppers, Ohlins suspension and carbon fibre bodywork... Around 150 were built in total"
  19. Night_Wolf
    Night_Wolf Leg Humper
    Feb 17, 2006
    11,152
    Lat: N 90°00'00" Long: N/A
    Heated grip connection possibly
  20. Night_Wolf
    Feb 17, 2006
    11,152
    Just about everything from this thread & the FB Group(s) worth finding/searching for, is contained on those pages. I went through my PDF copy of the service manual & did screen captures for the Torque Values, as it seems to be a question that pops up regularly
    TimmyTheHog likes this.
