Right on - thanks - the hondo clamp looks like worthy investment - was unclear to me if there is an option to integrate with a big squeeze? May be getting an ipad mini.
We are now offering the bottom cables with the SAE plug and BMW DIn plug for only $10 more this makes it a truly plug and play solution.
I received my powerpuck today. There was a delay with delivery because of the smoke here in Canberra. Australia Post had ceased doing deliveries for a few days. I am hoping to get it installed either today or tomorrow. I will be using it with a Kyocera Duraforce Pro.
I'm installing my power puck I've got a fuse block so have cut off the fuse holder. The fuse that came with it is 3amp, I only have 2 or 5, my Garmin GPS had 2. Am I ok to use 2 or 5? If so which one is the better one. Or do I need to get 3?
5 would be better, but try the 2. If it draws too much, it'll blow and you'll just have to replace it.
My Powerpuck arrived and it looks awesome but I have an issue. I went to unscrew the mounts to put them in the inner screw holes and the first screw was so tight my hex wrench head broke off in the screw. The other screw on the same side came out with the help of a heat gun (the other side's screws were fine). What can I do to get another screw to replace the one with the Hex head wrench tip stuck in it?
Just to let everyone here know, he reached out and was very responsive. Happy customer. I must say the unit it MUCH more beefy than I expected. Thought it was a bit pricey, but seeing it in person makes me realize I really am getting my money's worth. EDIT: FYI, just found out the whole kit is made in USA. Now I'm more than willing to spend the cash.
Anyone else having trouble with their iPhone 11 charging with the new 10w version of the Powerpuck? I installed the connector on two bikes and it won't charge on either. Not sure if it is an Apple thing or maybe I just got a faulty puck...
It works great with my 11 Pro. One thing that you need to remember though is that the charging coil is not in the middle of the phone, it's closer to the top. Try sliding the phone down in the mount a little bit to line up the charging coil with the puck.
I need to ask this question so I don't do something stupid in the future. The old v1.5 powerpuck had an inline voltage regulator/reducer to take the voltage (into the coils) down from 12v to 5v. I noticed the new one doesn't have this. Do the V2 inductor coils receive the full 12v?
Close but it’s a bit more than that. The v1.5 has a 12v to 5v converter inline to reduce the board voltage to 5v and thus the coils to 5w. The v2.0 has no voltage converter inline as the boards are native 12v and provide the charge at 10w they also are self downgrading capable to charge 5w and 7.5w for devices unable to accept 10w. We don’t recommend any modification of the over molded puck that cuts or opens the molding in any way and removing the inline quick disconnect on v2.0 voids our 1year electronics warranty. Additionally cutting the v1.5 cord above the voltage regulator voids the warranty as well as it is severely departing from the original design of manufacture.
