    Dismiss Notice
Motorcycle Batteries .. AGM, GEL, Wet, Lithium Iron Phosphate (LiFePO4)
Discussion in 'The Garage' started by _cy_, Jan 20, 2012.
  1. Nosotros Racing
    Nosotros Racing Been here awhile Supporter
    Jan 10, 2020
    995
    Southwestern Illinois
    Nothing but gels in all my bikes for the last 12 yrs or so. Cost about the same as lead-acid, no special charger and lasts twice as long. And no chance of leaks.
    waylongway and JensEskildsen like this.
  2. VonBiker
    VonBiker Work sucks and then you RIDE! Supporter
    Mar 13, 2014
    1,395
    Lakewood, CO
    Huge shout out to Anti-Gravity.
    I have a 5 year old Micro-Start Mini, long after the warranty expired, and the case had swollen and popped up. Still worked ok, just had me concerned.
    The gave me 30% off the price of a new model, so I jumped on that and a new harness for a new bike I bought that allows jump starting from the SAE charge cord.
    The package came today and much to my surprise, there were some extra goodies thrown in. An audio cap and a lantern/light/speaker power bank.
    I really like these great folks. Tremendous service and awesome to deal with.
    Buy their stuff !!
  3. VonBiker
    Mar 13, 2014
    1,395
    Lakewood, CO
    Big shout out to Anti-Gravity.
    I have a 5 year old Micro-Start Mini, long after the warranty expired, and the case had swollen and popped open. Still worked ok, just had me concerned.
    Buy their stuff !!
    WJBertrand and Antigravity like this.
  4. garandman
    garandman Wandering Minstrel
    Feb 5, 2007
    7,900
    Dorchester, MA / Sunapee, NH
    We have an old (2014) PPS. It has a different size charging jack than our newer ones.
    What 120V charger do we order?
  5. Antigravity
    Antigravity Been here awhile
    Sep 6, 2010
    485
    Los Angeles
    It's a discontinued Micro-Start model and unfortunately we no longer offer the replacement charger for the PPS. We apologize for the inconvenience.
    If you give us as call at (310) 527-2330 we can discuss possible replacement options for the unit.
  6. Bakfarht
    Bakfarht Been here awhile
    Nov 13, 2018
    156
    Calgary
    I've used standard lead acid for about 10 years but recently went to AGM. My understanding is that there's no need to trickle charge an AGM over winter, but here's a couple questions for the obviously very well educated battery experts here...
    1. Where I live, "winter" can mean a good 5 months of no riding, can I still just leave it?
    2. If/ when I do recharge, should I take the battery off the bike?
    I'm sorry if this has been covered already, there's just too much in this thread to wade through :)
  7. RonKZ650
    RonKZ650 Been here awhile
    Jun 11, 2009
    983
    Lakewood, CO
    Lots of opinions I'm sure. The way I like to do it is check voltage across the battery every couple weeks when not riding. A fully charged AGM will be about 12.8v. No reason to charge or otherwise "maintain" a battery that is fully charged. If/when your voltage checks at 12.4v or less, that means the battery has dropped to 75% of charge and a good time to put a small charger on for a few hours, then remove.Repeat checking same way all winter and charge only as needed.
    I know there are many that strongly believe in leaving a Battery Tender on 24hrs a day. I don't believe in it myself so many contrasting views.
    ChasM and Bakfarht like this.
  8. Global Rider
    Global Rider Alps Adventurer
    Nov 26, 2001
    3,946
    Canada & the Alps - N 46° 31.714' E 010° 27.212'
    Glad you brought that up because advertisers claim that AGMs have a very low level of self-discharge. That is true when they are sitting on a store shelf and not connected to anything. The trouble is, when they are connected to a vehicle, numerous systems (alarm, ECU, etc) draw current that far exceeds the self-discharge rate of the battery...tens to a hundred of times more. So the self-discharge aspect means nothing when it is connected to the vehicle.
    1. I would at least monitor the battery voltage and charge it when necessary. Better still, connect it to a battery maintainer and not worry about it.
    2. If possible. Note though that indoors where it is warm it will self-discharge a bit faster than in a colder environment. If it is below freezing, I'd make sure the battery is fully charged first and then keep it that way. The last think you want to do is charge a frozen battery with any substantial current.
    lexaria and Bakfarht like this.
  9. SoilSampleDave
    SoilSampleDave Dr. Zaius was right!
    Jan 21, 2005
    10,357
    The Delta Ghetto, GA (aka PTC)
    Pretend you are riding it. Every weekend, walk into the garage and connect the QD battery tender leads. Sometime later that day or weekend, disconnect. Simplest method.
    SmittyBlackstone and 250senuf like this.
  10. GS Addict
    GS Addict Pepperfool Supporter
    Sep 24, 2006
    7,496
    Sunshine Coast B.C.
    If you are not going to ride it for 5 months, do what the Manufacturers suggest.
    Fully charge at the end of the season with a proper charger (not a trickle charger)
    Disconnect and come back in Spring.
    SmittyBlackstone likes this.
  11. ramz
    ramz Professional Trail Rider Supporter
    Dec 11, 2006
    2,941
    Salida, CO
  12. ramz
    Dec 11, 2006
    2,941
    Salida, CO
    Battery charges I own and use (not that these are the best or cheapest). None of these is a trickle charger. Information obtained from the manufacturer's web pages.
    Deltran SuperSmart Battery Tender Plus 12-Volt 1.25 AMP Battery Charger $50 April 1, 2008
    Battery Tender Plus 12V - 1.25A. The Battery Tender Plus is a 1.25-amp battery charger designed to fully charge a battery and maintain it at proper storage voltage without the damaging effects caused by trickle chargers. Included is a quick connect harness for hard to reach areas. Temperature compensated to ensure optimum charge voltage according to ambient temperature. Automatically switches from full charge to float charging mode. Battery Tender at 1.25-amp will charge as fast or faster than any 3-amp charger available. Reverse Polarity Protection to ensure user safety. Red & Green Lights Alternately Flash in this condition. Complete 4-step charging program (Initialization, Bulk Charge, Absorption Mode, Float Mode). 10 year warranty. Perfect for all lead-acid, flooded or sealed maintenance free batteries (AGM and gel cell)
    Battery Tender 021-0123 Battery Tender Junior 12V Battery Charger $23 December 20, 2012
    Battery Tender Junior 12V Battery Charger is much more than a trickle charger. It has a brain, is lightweight, compact, fully automatic and very easy to use especially in small spaces. This battery charger will keep the battery fully charged so that it is ready to go always. It has a microprocessor controlled fully automatic charger and maintainer and is designed to extend the life of any lead acid battery commonly used in automobiles, motorcycles, ATVs, personal watercraft, RVs, boats, airplanes, golf carts, back-up generator systems, etc. Any vehicle or battery-operated piece of equipment not used on a daily or regular basis is a candidate for a Battery Tender charger. The advanced technology will bring the battery back to a full charge without overcharging and then float or maintain the battery for an indefinite period of time. The Battery Tender Junior comes equipped with alligator clips and ring terminals for easy hook up. An optional 25 feet extension cord (part number 081-0148-25) is sold separately.
    Battery Tender (022-0186G-DL-WH) 12V 5 Amp Battery Charger $65 August 17, 2016
    The 5 amp 12 volt Battery Tender charger is a fully automatic High Frequency switch mode charger. It has 4 stage charging (Qualification, bulk, absorption and float) When the recharge is complete the charger will float (maintain) the battery for an extended period of time at full state of charge. It is specifically designed for AGM batteries but will easily recharge all lead acid batteries form the small Powersports batteries up to and including large deep cycle batteries for automotive, marine, agriculture, construction, virtually any lead acid battery. It is completely safe and includes a 72 hour timer to prevent further damage to marginal batteries. It is fully approved for the California and Oregon markets. It is a smart charger that you just put on and leave on until you are ready to use the vehicle.
    Battery Tender 6V/12V, 4A Selectable Lead Acid & Lithium Battery Charger and Maintainer. $64 October 24, 2019
    The fully automatic 4 Amp Power Tender is a top-of-the-line 12V or 6V switchable battery charger, perfect for automotive, motorcycle and marine repair and maintenance shops. Float / maintenance function maintains batteries at proper storage voltage without the damaging effects caused by trickled chargers. The integrated smart controller assures that your battery is charged safely and correctly at all times through our ISM (Infinite Sequential Monitoring). The ISM adapts to the battery’s needs hundreds of times per second to deliver the proper amount of charge. With reverse polarity protection and spark-proof operation, you can connect it and forget it!
    TecMate TM-291 OptiMate Lithium Battery Charger $108 February 21, 2013
    Tecmate Blue Ampmatic Optimate Lithium 4s, TM-291, 10-Step 12.8V 5A Sealed Battery Saving Charger & maintainer $126 March 28, 2016
    :ricky
  13. veetwo _tls
    veetwo _tls RENOVATIO:
    Nov 14, 2005
    2,728
    THE MALLEE OUT BUSH IN Sth Oz
    Don't class myself an expert i'm always learning (leave that to the yanks there good at trying claim the fame LOL)
    Just speaking from experience
    Still need to trickle charge AGM just threw out a new AGM as it sat on shelf for 12 mths no trickle held only 16Amp
    As soon my bikes home there on trickle 950SE just replaced the Motobatt AGM after 6 yrs
  14. JensEskildsen
    JensEskildsen Long timer
    Mar 24, 2009
    2,302
    Denmark
    Its not my experience.
    Theres no need to charge a battery every week, the charger should cut of in a matter of seconds doing that, if theres no parasittic draw.
    Have alook at the output of your charger, then time how long the charger runs, and you know roughly how much capacity the charger "filled up" the battery
    lexaria and SmittyBlackstone like this.
  15. keepshoveling
    keepshoveling DNF
    Oct 9, 2014
    4,833
    NYC
    If there’s no parasitic draw is important here. What you want to do with your battery will depend a lot on how much (if any) parasitic draw there is.
  16. veetwo _tls
    Nov 14, 2005
    2,728
    Exactly
    I have a rally tower on 2 x bikes with nav equipment & Accessories on other with isolation toggles there is still a small amount of draw
    Motobatt recommended to put my AGM motobatt batteries at least on trickle once a month if not in use
    As i said i got 6 yrs out my batteries using trickle once bikes are parked home. my bikes are daily rides not weekend toys
  17. Gruesome
    Gruesome Alter Heizer
    Apr 28, 2007
    1,575
    Chicago
    I'm no battery expert. My last AGM lasted nine years, and still has two thirds of its original capacity. It got disconnected & removed from the bike every winter, and fully charged at the beginning of that storage period. No trickle charging.
    1. My understanding is five months should be fine if there is no parasitic drain, i.e. the battery is disconnected from the bike. I recently installed a main switch for this purpose, and posted about it.
    2. I don't think that is necessary, since you are not going to push the battery beyond 14.8V, and the bike electronics should be ok with that.
  18. PNWet
    PNWet Long timer
    Nov 2, 2014
    1,182
    Puget Sound, WA, USA
    In case anyone is looking for an alternative to the Baja Designs 700 mah nicad battery, this one is a direct replacement 2000 mah nimh.
  19. Jungle Man
    Jungle Man I ride motorcycles sometimes.
    Aug 16, 2010
    1,119
    In progress
    I've got a kick start only bike with a big 12v sealed lead acid battery to run the lights and such. Could I get away with just throwing in a Milwaukee m12 lithium battery in its place?
  20. PNWet
    PNWet Long timer
    Nov 2, 2014
    1,182
    Which biked do you have?
    I would think it depends on how you are going to charge it. If you are going to remove it to charge it, I would think that would be fine, though also a hassle. I would not charge a lithium battery directly from the bike unless the battery has some sort of built in charge control.
    SmittyBlackstone and Jungle Man like this.
