[Motorcycle Insight] Grip Puppy Grip Covers - Original & New BIG PAW Sizes
Discussion in 'Vendors' started by prudolf, Apr 21, 2020.
  1. prudolf
    prudolf Motorcycle Insight - USA Importer for Grip Puppy
    Aug 26, 2009
    385
    Pittsburgh, PA
    Motorcycle Insight is the official USA Importer & Distributor for the Grip Puppy brand. As many know the name, some may not yet know where to find them. Others may be curious as to what they are need to find the specifics. We're here to help!
    These Grip Puppies will give more comfort to your ride and will reduce vibrations. They simply slip over your standard rubber grip (no need to remove standard grip) and leave you with a soft, squeezable, tactile grip that will give greater comfort to any bike. Moreover, vibrations are reduced through the grip. Hold very strong when fitted – a simple and very effective solution.
    Grip Puppies will fit all standard grip sizes.
    The standard Grip Puppy will fit standard bars sizes and grips. They are 5″ (12.7cm) long and will fit grips that are 1.25 (3.17cm) to 1.45 (3.68cm) inches in diameter (remember: they fit OVER your standard grips, you don’t need to remove them).
    These Grip Puppies PIG PAW will give more comfort to your ride and will reduce vibrations. They simply slip over your standard rubber grip (no need to remove standard grip) and leave you with a soft, squeezable, tactile grip that will give greater comfort to any bike. Moreover, vibrations are reduced through the grip. Hold very strong when fitted – a simple and very effective solution.
    Grip Puppies PIG PAW are the larger Grip Puppies, designed to fit over 1″ diameter bars on motorcycles from Harley Davidson, Indian, and most metric cruisers. These will fit grips from 1.45" - 1.65" diameter.
    Grip Puppies can be trimmed with a craft knife or similar if needed (using appropriate care!).
    They are great for adding a little extra thickness and comfort to your grips. They will also work with heated grips.
    INSTALLATION INSTRUCTIONS: You do not need an air compressor. Just apply a little soapy water to the inside of the Grip Puppies and slide them over your existing grips. Allow to dry, then enjoy the ride!
    Grip Puppies can be purchased from us direct at MotorcycleInsight.com or ask your local dealer for them.
    For ADVrider Inmates, use Discount Code: ADVINMATE-PUPS to save $2.99 on your set of Grip Puppies or Big Paws!
