1. ** Enter to win a $250 gift card! We want to hear from you, please take this survey **
    Take this survey which covers a range of questions about improving the community, the things that interest you and anything else you want to share with us. All responses will remain anonymous.
    Click here to take the survey
    Dismiss Notice
MT5001 5 inch Android Motorcycle GPS Navigation Waterproof IPX7 with WiFi, Bluethooth, FM
Discussion in 'GPS 101 - Which GPS For Me' started by ygal, May 1, 2017.
  1. losminos
    losminos n00b
    Jul 2, 2011
    5
    Bratislava, Slovakia
    Could you reccommend which display is more handgloves friendly ?
    Fodsports has capacitive one and Prolech has a resistive display.
    I have a normal leathher gloves which have no special capacitive touch areas.
  2. Neil_The_Wheel
    Neil_The_Wheel Long timer
    Mar 6, 2006
    1,060
    Idaho
    Resistive works with all gloves, capacitive requires specific gloves . Resistive needs a firmer touch .
    VmaxChuck likes this.
  3. MalcolmReynolds
    MalcolmReynolds Adventurer
    Apr 2, 2018
    51
    Colorado
    So is the concensus now that the new 1gb with 16gb storage 5" is good enough for prime time instead of sinking money into a Garmin or other motorcycle specific gps? What is the current recommendation?
  4. Mr. M
    Mr. M huh?
    Dec 20, 2011
    62
    Wageningen, The Netherlands
    My recommendation: Buy a rugged smartphone. I am very content with the Ulefone Armor 5.
  5. connermacleod69
    connermacleod69 n00b
    Aug 19, 2017
    5
    Luxembourg
    Hi,
    I'm still using the MT5001 after changing the display.
    I resolded all cables and changed some of them with "softer" cables.
    One of the pins (ground or 12V) was totally disconnected (cable/soldering point broken)
    As navigation apps I'm using
    Navigator https://play.google.com/store/apps/details?id=com.mapfactor.navigator
    and
    Kurviger https://play.google.com/store/apps/details?id=gr.talent.kurviger.pro
    without any problem.
    OSMAND just "kills" the device with its heavy energy consumption, at least an older version. Did not test the newest versions.
    I also have a CAT S60 which has a lot of GPS problems (signal loss)
    Serge
  6. Mr. M
    Mr. M huh?
    Dec 20, 2011
    62
    On my device (1 GB RAM) Osmand+ runs fine. My sons and I use the device quite often.
  7. Zynth
    Zynth Adventurer
    Sep 16, 2013
    26
    I have the mt5002; pretty ok when first playing with it.
    Did anybody succeed in changing the default "home app"?
    - It is very annoying that I can not use one that is configurable
    - I want it -at least- to start a different navigation app than iGo...
  8. Moshaholic2
    Moshaholic2 PCUT
    Apr 16, 2018
    304
    Utah
    Any updates from users?
    I have the Karadar MT5001 . Sure its not the fastest but it works .
    My issue is the power coming on and off when in the mount (gives the warning to stay on or power off). Usually it will rattle and stay on without me having to tap it. But, it has done the count down and shut off on me while riding.
    Any idea where to look for the loose connection?
    Are the springs on the pins not strong enough for off road vibrations? The mount looks sealed. I had planned on opening it up and touching up the solder points. But, it look like I'd have to break it to access the wires??
  9. turtlespeed
    turtlespeed Been here awhile
    Feb 15, 2016
    454
    NJ
    HI, CAn you connect your phoen to theMT5001. if yes, does your GPS show sms, phone etc. notifications from your phone?
