MTB and ADV brakes handing?
Discussion in 'The Perfect Line and Other Riding Myths' started by Dr Bombay, Oct 29, 2019.
  1. markk53
    markk53 jack of all trades... Super Supporter
    Dec 20, 2007
    19,604
    Delaware Ohio
    Because, much like motorcycles, someone built their bicycles that way.
    Same reason why some motorcycles had foot shift, others had hand shift, some on the right, some on the left, some had first gear up - 4 down, some had neutral at the bottom - 4 or 5 up, some had rotary shifting going n 1 2 3 4 n 1 2 3 4, some actually had front brakes on the left when there were foot clutches. Until something becomes regulated, there are no explanations.
    Why do some countries run on the left side of the road while most go on the left side? Some people started it out that way.
    There doesn't have to be any reason. The only reason why most bikes are set up the way they are now is because of federal regulations in a number of countries. I am not sure of it, maybe someone works in a bike shop can tell us if a new bicycle has to have the brakes set up with the front on the left, rear on the right required by gov't regulations.
    #41
  2. Dr Bombay
    Dr Bombay "When you get to a fork in the road, take it" Supporter
    Dec 31, 2012
    25
    Cambridge, MA., US & Montezuma, Costa Rica
    Thanks for all the feedback. Very interesting to read all the comments. Clearly no right or wrong just personal preference. I do find myself pulling left leaver when hard braking on my Tiger, and thus loose engine braking, but its a habit that could be broken. That said, if the winter is long and cold (and I need stuff to do inside mid feb) I may try swapping my 3 MTBs over to right hand front brake and give it a try.
    #42
  3. jonz
    jonz Miles are my mantra Supporter
    Aug 16, 2004
    5,544
    CA dez (it's a dry heat)/West Yellowstone,MT
    Back when bicycle brakes were connected with cables, I used to switch to the moto configuration. Then I loaned a bike to my son who promptly launched over the bars when he thought he was grabbing the rear brake but it was the front. Now, I ride both motos and bicycles often enough that I can make the switch with just a few front brake pumps on the start of the bicycle ride and my brain is reset to bicycle mode. However, for the last couple of years, I've been using a Rekluse clutch with their left hand rear brake setup. That makes it a little harder to switch back to the bicycle configuration but so far, no over-the-bars braking mistakes.
    #43
  4. motu
    motu Loose Pre Unit
    Dec 28, 2001
    6,910
    New Zealand
    I've never had a bicycle with a left hand front brake in my life - is it a US thing ?
    #44
  5. SRG
    SRG Long timer
    Nov 18, 2004
    3,121
    Central Va.
    No solely a US thing (there was an Aussie here who said his bikes have been LHFB) but a 100% a stupid thing.
    #45
  6. Plaka
    Plaka Brevis illi vita est
    Jun 19, 2010
    6,922
    the advantage is that for most people the right hand is stronger. for a cable operated brake that strength is needed because the front wheel has more traction. most of the braking is up front. if you are left handed put the front cable operated brake on the left.
    #46
  7. SRG
    SRG Long timer
    Nov 18, 2004
    3,121
    Central Va.
    Dammit, the post you quoted of mine should say RIGHT.
    Which is the 2 wheeled standard. The only reason it is done differently is that some have conditioned to do so, for no good reason.
    #47
  8. Plaka
    Jun 19, 2010
    6,922
    dyslexics are teeple poo.
    #48
    Dr Bombay and ydarg like this.
  9. Midwesterner
    Midwesterner Adventurer
    Dec 30, 2016
    15
    South Central Wisconsin
    I've been bicycling a lot longer than I've been motorcycling. So for me, switching the bicycle brakes would cause a much bigger problem than it would solve.
    Anyway, I noticed that I have somewhat unconsciously developed a newish mountain bike habit since I started motorcycling. At the beginning of a fast and/or low traction downhill, I will cover the right lever (rear brake) with two fingers and cover the left lever with just one finger. I guess this helps me remember which hand is connected to which end of the bike.
    #49
  10. LuciferMutt
    LuciferMutt Rides slow bike slow
    Aug 19, 2008
    16,570
    New(er) Mexico
    I ride both frequently. I have never once felt the need to switch the levers around. It's just a mindset muscle memory thing -- when I'm on the MTB, front brake is the the left lever and on the motorcycles, it's the right lever. Your mind will flip the switch as soon as you get off one and onto the other. It's not a problem, mostly because both levers on a bicycle are brakes, while only one on a motorcycle is a brake.
    #50
    250senuf likes this.
  11. markk53
    Dec 20, 2007
    19,604
    Delaware Ohio
    Yeah, you know, that thing about the north hemisphere and the south hemisphere. Cross the equator and the brakes switch sides. :lol3
    #51
    Dr Bombay likes this.
  12. motu
    motu Loose Pre Unit
    Dec 28, 2001
    6,910
    New Zealand
    So why isn't my motorcycle brake on the left if that's the case ?
    #52
  13. scottrnelson
    scottrnelson Mr. Dual Sport Rider
    Apr 3, 2006
    2,066
    Meridian, ID
    I swapped my mountain bike brakes over one time to see if it would help - make the right lever the front brake on everything. I've been riding both bicycles and motorcycles for so long that I automatically know which brakes do what on both, so I switched it back after just a few days. I've really never been confused about which lever does what on any of them.
    So it wasn't worth the minor bother to switch in my case.
    #53
  14. Tripped1
    Tripped1 Smoove, Smoove like velvet.
    Aug 6, 2009
    33,237
    Nippon
    Mine doesn't.
    I can't swap between gp and standard shift, and I have the brakes flipped on my bicycles as well.
    #54
  15. eakins
    eakins Butler Maps
    May 29, 2002
    36,765
    Fort Collins, Colorado
    About 15 years ago I switched all my mtb to right hand front brake - Aussie/Moto style.
    My wife and daughter ride this way.
    The bicycle brake lever system is based on a 100+ yr old outdated French system. It's designed for your right/powerful hand to stop the then powerful rear brake.
    Those in the know moved forward years ago.
    #55
    AllSeasonRider likes this.
  16. markk53
    Dec 20, 2007
    19,604
    Delaware Ohio
    Golly neds, ya got me! I owe you a shout if I ever get down under... will it make me left handed? :lol2
    #56
  17. sky44
    sky44 Gummikuh
    Jul 12, 2009
    794
    CO
    Gives me no issues. I've been riding mountain bikes for much longer... The bikes are so different in so many ways that my brain doesn't get mixed up.
    #57
  18. motu
    motu Loose Pre Unit
    Dec 28, 2001
    6,910
    New Zealand
    Well, I'm lefthanded - should I put my motorcycle brake on the left bar so my dominant hand can apply full power to stop ?
    #58
  19. markk53
    Dec 20, 2007
    19,604
    Delaware Ohio
    Only if you are in the the western hemisphere... :confused::jack
    #59
  20. tentative_rider
    tentative_rider Wanna Be On Gravel
    Jul 11, 2009
    1,482
    New Braunfels TX
    I have been riding mountain bikes and motorcycles for decades, but the brake lever location has never affected my ability to ride either one interchangeably.
    #60
