Mudflap Mod
Discussion in 'Parallel World (790/890)' started by SEK_Nick, May 10, 2020.
  1. jaumev
    jaumev Long timer
    Jun 5, 2011
    2,110
    Barcelona
    Strange...I think they sell worldwide.
    I will ask them
    #21
  2. ynnck
    ynnck Been here awhile
    Aug 5, 2013
    150
    Belgium
    How are these mudflaps holding up & how clean does the shock stay?
    The Twalcom version looks quite a bit narrower than the 640 DIY version.
    #22
  3. Lill-Erik
    Lill-Erik Adventurer
    Jul 22, 2019
    77
    Sweden
    Since i have put on a longer chain to move the rear wheel further back i have no issues with tyre rub on the mudflap. And the shock stays very clean. And no mud clogs yet.
    #23
    ynnck likes this.
  4. TWG1
    TWG1 Been here awhile
    Feb 16, 2020
    100
    Surrey
    I was looking at this and wondered if it was possible to bond a piece of rubber on the back of the twalcom one to add protection.
    #24
  5. SEK_Nick
    SEK_Nick Been here awhile
    Nov 4, 2015
    343
    Southeast Kansas
    Could you tell us more about the tire rubbing issue?
    #25
  6. Lill-Erik
    Jul 22, 2019
    77
    Sweden
    Well its simple. If you have the tire to far forward you will rub the mudguard and it wont last as long.
    #26
  7. SEK_Nick
    Nov 4, 2015
    343
    Southeast Kansas
    This happens with stock gearing and chain length? At what point in the suspension stroke? Rubs a little or hammers it?
    #27
  8. Brilloman
    Brilloman Been here awhile
    Jun 29, 2014
    434
    Georgia
    Did we ever figure out if twalcom ships to the US?
    #28
  9. ynnck
    Aug 5, 2013
    150
    Belgium
    How do you like the width of the Twalcom flap? Does it rub on the swingarm or shock?
    #29
  10. Yellow Pig
    Yellow Pig Allergic to asphalt! Supporter
    Oct 28, 2004
    9,616
    Thousand Oaks, CA
    Here is my $30 DIY version:
    Used a small piece of Kydex and the OEM hugger mounting points to mount the anti-rubbing protection. 20210206_124219.jpg
    Made a simple metal bracket to mount the KTM 640 Adv mud flap:
    I sandwiched it between the fender and the metal cross bar:
    Yea, yea. I know I need to source a second fender washer for the flap!
    I'm getting pretty decent clearance out of it:
    #30
    BHoward, SHOREBILL, Lill-Erik and 3 others like this.
  11. t3scn
    t3scn Adventurer
    Jan 24, 2021
    28
    Wiltshire, UK
    What’s the black cover you have on the shock there? Doesn’t look like a sock..
    #31
  12. chippertheripper
    chippertheripper motorcycle junkie Supporter
    May 30, 2009
    12,657
    s.e. mass
    thats oem on the 790’s.
    #32
    t3scn likes this.
  13. t3scn
    t3scn Adventurer
    Jan 24, 2021
    28
    Wiltshire, UK
    may, interesting. I wonder it it will fit my 790 Rally :hmmmmm
    #33
  14. Mudguts
    Mudguts when in doubt GAS IT
    Jan 16, 2006
    2,711
    Some were in , lostralia
    Will not fit the rally ,there is no screw hole on the pro shock for it to fit to
    #34
    t3scn likes this.
  15. t3scn
    t3scn Adventurer
    Jan 24, 2021
    28
    Wiltshire, UK
    Thanks, I looked at the KTM schematic and thought that would be the case. Although I wondered if modifying it might work too.
    #35
  16. Yellow Pig
    Oct 28, 2004
    9,616
    Thousand Oaks, CA
    Well, that was a failure!
    Looks like i focused on lower end clearance and didnt properly calculate upper clearance.
    #36
    BHoward and braaap! like this.
  17. ebrew
    ebrew Motorcycle A.D.D.
    Nov 4, 2005
    2,321
    Denver colo
    LOL ..... A++++ for effort
    #37
    TrailTrauma likes this.
  18. Crashthings
    Crashthings Been here awhile
    Mar 11, 2009
    112
    Corinth, TX
    That is not a failure, it was a test, a lesson you learned from.
    #38
    Yellow Pig, BHoward and blackberg like this.
  19. windblown101
    windblown101 Long timer Supporter
    May 17, 2010
    8,139
    Star Tannery, VA
    120 link chain - problem solved.
    #39
  20. Yellow Pig
    Oct 28, 2004
    9,616
    Thousand Oaks, CA
    Running a 15T front so I did gain a bit of clearance.
    #40
