Multifunction switch screw F850gs
Discussion in 'Parallel Universe' started by bobwolff68, Aug 2, 2020.
  1. bobwolff68
    bobwolff68 Adventurer
    Nov 26, 2013
    96
    San Jose, CA
    2019 F850GS - I went down in some pretty powdery/silty talc-like stuff and now my starter/cut-off switch is super hard to press in any direction. No problem, right? Just undo the screw in the bottom of it and remove it. Even the repair manual says "remove PT2.5x6 screw" ... but I can't seem to figure out what size or style the screw is. It LOOKS like it is a hex and the "PT2.5" seems to indicate 2.5mm hex, but it doesn't fit. Nor does any metric hex, torx, or even non-metric hex wrench. GAH.
    Anyone have any experience removing this darned thing?
  2. rcb78
    rcb78 Been here awhile
    Dec 17, 2017
    109
    San Jose, Ca
    Don't know about the 850's, but my old 800 was a super tiny torx head and the switchgear assembly looked identical to your picture. Something like a T5 or a T7.
  3. bobwolff68
    Nov 26, 2013
    96
    San Jose, CA
    Thanks, @rcb78 for the 'push' towards Torx. I had a hard time getting a good visual on the darned screw but I could have SWORN it was hex. You were correct it is TORX and the answer is TORX T9. Mystery solved and now I can get to blasting the dust and crud out of there and put a little graphite in for good measure.
    rcb78 likes this.
  4. rcb78
    Dec 17, 2017
    109
    San Jose, Ca
    I used a little dielectric grease on mine.
