My eZuma project (Elektra)
Discussion in 'Electric Motorcycles' started by MJSfoto1956, Sep 16, 2018.
  1. MJSfoto1956
    MJSfoto1956 Been here awhile
    May 12, 2017
    488
    Boston, MA
    Recently I was able to acquire an electric 2017 Chinese Zuma clone via Craigslist. The price was right and I was ready to bite the bullet. This bike is typical of Chinese eScooters in that it uses a fairly common 72v 2000w motor/controller platform, which limits it to 30mph top speed and 25mile range. I plan on upgrading this sorry excuse for an electric motorcycle into my go-to errand bike capable of 60mph/50mile range.
    I'll start with a photo from day 1 -- directly after picking up via Craigslist. Notice the heavy use of decorative plastics and decals. Not to my taste. Those will have to go. I like my bikes naked!
    So 24 hrs later, my busy hands were happy to remove the extraneous decorative plastics and decals. Note: it was easy to remove the decals: 20 secs each with a heat gun was enough to loosen 'em up, then just peal away. This "bare bones" state is where I begin the journey.
    Another thing you might have noticed: this clone is a full 6 inches longer than a true-to-form Zuma/BWs. I now have more leg room than an SMAX! ;)
    RCmoto likes this.
  2. MJSfoto1956
    May 12, 2017
    488
    Boston, MA
    First things first. One must understand the wiring you are dealing with. I spent about 2 hrs cleaning up the tangled mess that goes for Chinese wiring in these bikes. (Note: the photo below was taken AFTER I cleaned it up! :p ). At this point, I actually think I understand how most of it works! More to come...
    The other thing you discover is that the Chinese "engineers" are sending 72v up to the handlebars! ("We don't need no stickin' relays!") =|
    EvrythingAwesom likes this.
  3. MJSfoto1956
    May 12, 2017
    488
    Boston, MA
    Sketch of likely future dash, showing PowerVelocity software running on 7" Samsung Tab A mounted horizontally. Also showing positioning of CycleAnalyst V3 mounted below for scale.
    voltsxamps likes this.
  4. RCmoto
    RCmoto Long timer
    Mar 7, 2014
    2,827
    US of F'ing A
    Love the project, thanks for sharing!
    EvrythingAwesom and MJSfoto1956 like this.
  5. MJSfoto1956
    May 12, 2017
    488
    Boston, MA
    I'm pretty close to finalizing the choice of motor, controller, and overall wiring diagram. Here's where I am today:
    RCmoto and Tarmac Kid like this.
  6. ctromley
    ctromley Long timer
    Oct 18, 2012
    1,089
    PA
    Not sure what your plans entail, but one easy way to do a conversion to lithium is to get LiFePO batteries in standard lead-acid sizes. I know the common U1 battery is available this way, maybe whatever your bike uses too?
  7. MJSfoto1956
    May 12, 2017
    488
    Boston, MA
    The next 9 months:
    1. Finish rear-end body/suspension mods
    2. test
    3. Update Controller + wiring + rear disc caliper (leaning towards PowerVelocity, but still on the fence)
    4. test
    5. Update Motor + 160/60-14 rear tire (leaning towards QS 273 V3 8kW 14" hub)
    6. test
    7. Update Battery pack
    8. test
    9. upgrade to braided SS brake lines
    10. Repaint body panels/frame, add windshield, etc.
  8. Lesharoturbo
    Lesharoturbo Nerdly Adventurer
    Mar 23, 2009
    2,978
    Austin TX
    Some of these battery packs do not meet the same density you can get from individual cells. They have a few cells in a case that is the same physical size as a standard battery, but the box is not "full" of LiFePo cells. Building your own pack is almost always the best meeting for these projects .
    #8
    MJSfoto1956 likes this.
  9. MJSfoto1956
    May 12, 2017
    488
    Boston, MA
    More importantly: on a scooter, more so than on a motorcycle, space is at a premium. This is why LiPo is still high on the list in spite of lingering issues regarding fire.
    M
    #9
  10. MJSfoto1956
    May 12, 2017
    488
    Boston, MA
    My plan for rear tire/hub motor which will result in an increase from 12" rim to 13" rim to which I plan on installing a 150/70-13 Pirelli or Michelin scooter tire. The difference in size is striking which you can see from the two photos.
    #10
  11. EvrythingAwesom
    EvrythingAwesom Long timer
    Mar 30, 2016
    1,406
    Bahamas
    Be careful with 72V DC which can allegedly cause heart-arrest if the current goes thru your body, by touching a plus on one hand, and a minus on the other hand.
    #11
  12. Lesharoturbo
    Mar 23, 2009
    2,978
    Austin TX
    When they send the 72V up to the handlebars, it is always just one side, either plus or minus. Otherwise, you end up with a short circuit and a fiery battery, which drastically shortens the battery life.
    Your are correct, anything over 60VDC is considering unsafe and should be handled appropriately.
    #12
  13. ctromley
    ctromley Long timer
    Oct 18, 2012
    1,089
    PA
    Actually, I've heard enough different versions of what constitutes lethal voltage that I don't know what to believe. The engineers I (virtually) hung around with during the EV hobbyist days couldn't agree on whether it was 36 VDC or 48 VDC. I had a 120 V pack in my car, 1/2 front and 1/2 back, that could be separated by big Anderson connectors. There was another Anderson in the middle of each half-pack, so when working in there I could quickly and easily ensure there was never more than 30 VDC potential on anything I was working on.
    When the automakers toyed with "42V" systems, their thinking was based on the "50 volt limit used as a guideline for electric shock hazard." (per Wikipedia, yet another version of a lethal "limit"). They are actually 36 VDC nominal systems, with charging voltage going up to 42 VDC. A 72 VDC nominal lead-acid system can go to 88 V during charge, higher if the charger is temp compensated and you're charging at low temps.
    Keep the high voltage stuff away from passengers. I don't care if it's just one side. A single failure (ground fault) can make it lethal. Always use two protection schemes. No exceptions. Running and charging are two different scenarios - the 'two protections' rule applies to both independently. And just because you can't know what cheapie manufacturers will do, make sure they didn't run everything at 72 V and ground the pack to the frame. I would hope no one would be that stupid, but you can't be sure. EVs need isolated packs.
    #13
  14. MJSfoto1956
    May 12, 2017
    488
    Boston, MA
    That's my thinking. That's why I've spent so much time on the wiring diagram, keeping the 72v isolated from the 12v. (see previous post)
    #14
  15. EvrythingAwesom
    Mar 30, 2016
    1,406
    Bahamas
    Did you find a successful BMS for these LiFePo4 cells?
    #15
  16. EvrythingAwesom
    Mar 30, 2016
    1,406
    Bahamas
    LiPO???? My understanding is that they only have 100 charge cycles and in the Endless Sphere thread, many fires and gutted garages/homes.
    #16
  17. MJSfoto1956
    May 12, 2017
    488
    Boston, MA
    No doubt. There are plenty of Einsteins out there who think they know everything. I did say "high on the list", not "top of the list" btw.
    M
    P.S. if you overcharge your lithium batteries then they won't last a season. The key with 3.6V lithium-ion batteries is to charge at no more than 4.1v max (LiFePo obviously less). Only a handful of "those in the know" do that.
    #17
  18. Lesharoturbo
    Mar 23, 2009
    2,978
    Austin TX
    More like 300-500 cycles, depending onon dep of discharge even up to 1000 cycles to reach 70% of initial capacity. Much more to "kill" the battery completely.
    Thermal runaway is a real issue and requires meticulous battery care and packaging to reduce the risk of over temp, over charge, and puncture. But, Lipo are really light, relatively cheap and fairly high energy density, so they are used in these applications.
    #18
  19. MJSfoto1956
    May 12, 2017
    488
    Boston, MA
    FYI, I'm leaning towards NO BMS. Yup. I'm serious.
    First watch this video and then discuss:
    Michael
    #19
  20. EvrythingAwesom
    Mar 30, 2016
    1,406
    Bahamas
    "regardless of chemistry" -- well, my 18650 desktop charger goes to 4.2VDC. Sorry, as someone who charges Lithium regularly, and an once-owner of Lithium 'cycles, Lithium Ion (not LIFEPO4) batteries won't fully charge unless you go to 4.2V. Do damage evident.
    The data is in Battery University.
    #20
