My first 950 oil change...
Discussion in 'Dakar champion (950/990)' started by Vance, Feb 24, 2006.
  1. Centerline
    Centerline USMC 71'-79'
    Oct 14, 2006
    338
    Republic of Texas
    I jumped to the conslusion/assumption that the screens/plug posts had not been carefully cleaned on their first change. The lower plug and the lower screen are quick and easy to deal with. The oil tank drain can also be opened without removing the left fuel tank. Anyhow it was the lower ones with the most debris, and yes, if they are nearly clean next change, yes it will only be a "quick change.":norton
    #41
  2. Centerline
    Oct 14, 2006
    338
    Republic of Texas
    Am I understanding that the tupperwear on your FJR plays some factor in oil changes.....'cause on my '05 FJR, oil changes are a breeze (maybe 15 minutes) and the tupperwear is not a factor at all, 'cept wiping a bit of oil that drains on a tiny piece of fairing beneath the oil filter??
    #42
  3. Jabba
    Jabba "HOLD THE LIGHT!!!"
    Nov 7, 2002
    13,038
    Just east of the Pine Beatle- Evergreen, CO
    Oil change on the FJR is 5 mins, tops- I was wiring up an aux plug and a fuse panel that weekend- and that entailed removal of a lot of tupperware.
    #43
  4. Centerline
    Oct 14, 2006
    338
    Republic of Texas
    For sure, removal of the FJR tupperware is a puzzle maze what with the order of removal and differing styles of fasteners.
    #44
  5. marin ktm
    marin ktm Been here awhile
    Feb 9, 2008
    334
    Marin County, CA
    I just did my first oil change just like that. At 250 miles. I don't see the need to remove glove box, side panel, gas tank, etc...?
    #45
  6. marin ktm
    Feb 9, 2008
    334
    Marin County, CA
    I did the 15 min idle maneuver too and it seems like the bike is sweet at low rpm creeping now...what a night!
    #46
  7. slide
    slide A nation with a future
    Jul 20, 2003
    21,410
    NM, USA
    I bought a $9 suction device from a local auto parts store. A full oil change is maybe 15 min.
    #47
  8. 9Dave
    9Dave Bazinga!
    Aug 4, 2005
    13,560
    Central Ohio
    So - did you change the filter?
    And do yourself a favor and clean the screen sometime soon. Could save some problems in the future if it plugs up. It's not that hard. You should get to the point where you can have the tanks off in about 5 minutes. Not that hard once you get used to it.
    Dave
    #48
  9. marin ktm
    Feb 9, 2008
    334
    Marin County, CA
    I changed the filter (looked totally clean), cleaned the flat screen (didn't need it). There was one tiny metal fake on the magnetic plug.
    I will clean the oil line screen next time. It does not seem like it will be required to remove the tank or body panels for any part of the oil change. Maybe I am missing something.
    I am taking off in a few hours on an 1800 mile trip down the coast, over to Death Valley for a couple of days, then back. That is why I changed the oil now, at only 250 miles. I will be late at getting the valves checked, but at least wanted to get a look at the filter and get some new oil in there.
    The oil that came out looked kinda wierd...almost like it had some water in it.
    This is shaping up to be the best moto trip of my life...an awsome street bike to get there, and a dirt bike to explore the back roads and trails once I arrive. Could this be the first dual-sport that is actually really competent and fun at both?
    #49
  10. Newbusa
    Newbusa Long timer
    Aug 21, 2006
    1,418
    Qualicum Beach
    I changed the oli and filter on my Sm950 today and had to put in 3.4 liters to register barely over the minimum mark on the tank.And that is with warming up the engine to 4 bars and then letting it sit for a couple of minutes.I put in 2.5 liters just like it said in the manual then a warm up.Still nothing showed, so added another .5 of a liter still nothing,then i added another .4 to put it just over the first line.Of course i did have all the various plugs and filter and screens out for over 1 hour so maybe had a good drain?
    #50
  11. Lost Again
    Lost Again Fresher Meat
    Jun 29, 2007
    274
    Orange,CA
    I did the same thing (once) and now I know better. Do not measure your oil level when you see 4 bars on the temp gauge. The temp gauge only measures the water temp, not the oil temp. I got a similar "low" reading and over filled the oil. Bad mistake. She smoked and cursed me like a little bitch. And I had it coming too. You must warm the bike completely (ride the damn thing for 10 mins.) before you take an oil measurement. On my 950 adventure, I just keep the oil level at the bottom of the stick now and all is well.
    Now you know.
    Also, when the oil is fresh and new, it can sometimes be hard to see the oil on the stick. I used a clean paper towel and slowly drag the stick across the edge of the paper. When the paper gets wet, then you have your reading. Hard to describe, easy to do. Or, you could just get a pair of glasses, like I did.
    Ride on.
    #51
  12. Newbusa
    Newbusa Long timer
    Aug 21, 2006
    1,418
    Qualicum Beach
    Yes, i see what you mean.I was going by the manual for warming up to 4 bars.Maybe i will take a wee bit out:lol3 Like maybe .4 litres.Mine is the SM so i don't have a dipstick but do have a sight tube:D But she ain't smoking now and don't want her smoking in front of my riding buddies:lol3
    #52
  13. cpmodem
    cpmodem Orange Caveman
    Nov 29, 2004
    7,130
    masa yee yah tee 59° 14' 9" N / 135° 26' 42" W
  14. Mr Head
    Mr Head Adventure Hippie Supporter
    Sep 21, 2003
    15,707
    San Clemente, CA
    I just did my first oil change on my new to me 2010 990 R. Jeez, this thing took a lot of fiddling.
    This thread was great though. The 2X4 deal worked the trick. I pulled that aluminum piece of artwork at the front and was able to drain the tank into my catch pan once I propped on granddads old tool box. Found a brand new red rag inside I'd left there back when I went to the track:clap
    I don't want to use it. It is so nice and clean and pretty. :lol3
    Everything went smooth as buddah right up to the point where I was re-filling the oil.
    I'm thinking I should probably not try and put the whole 3 liters in at once, since none is in the motor....:evil
    Then I just kept on pouring....
    Ack! What a fucking mess. OK, maybe four tablespoons of really expensive oil, (Former GS Adventure rider, so I'm cheap).
    :baldy
    Then getting that piece of fine sculpture back on with the crash bars.... A screw that goes through a slot in the crash bars then a big spacer, cause the crash bar almost works then the bit if sculpture, (This POS could be plastic, it is a fucking fairing, it hides the connector to thte battery and my side stand switch thingy), nothing else.
    I'm thinking this bike is really German.:lol3
    I got everything back on, but left the bashplate off, (Weld86, that OEM thing looked like I might break it during this oil change.:rofl).
    Oh, and the drain plug on my oil tank is a 13mm.
    #54
    KMS6 likes this.
  15. DIRTSCOOTER
    DIRTSCOOTER Been here awhile
    Feb 6, 2007
    135
    South Lyon, mi
    Finishing up my first oil change on my 2010 990A, no problems but I bought an oil change kit and I can't figure out where the smallest crush washer in the kit goes.
    #55
  16. Boatman
    Boatman Membership has it's privileges ;-) Supporter
    Mar 9, 2005
    14,472
    Mill Spring, NC
    10x14x1 ? For the plug you remove to access the clutch oil jet.
    #56
  17. DIRTSCOOTER
    Feb 6, 2007
    135
    South Lyon, mi
    Going to look into that, thank you!
    #57
