1. ** Enter to win a $250 gift card! We want to hear from you, please take this survey **
    Take this survey which covers a range of questions about improving the community, the things that interest you and anything else you want to share with us. All responses will remain anonymous.
    Click here to take the survey
    Dismiss Notice
My Half A$$ Studebaker Rebuild
Discussion in 'Shiny Things' started by vtwin, Apr 15, 2018.
  1. Nailhead
    Nailhead Inclusion Rider
    Apr 6, 2003
    10,922
    Longmont, CO
    It’s yet another reminder to me that I really don’t know how to do this stuff very well.
    I enjoy the thread, though; watching competence is fun.
    High Hope and vtwin like this.
  2. vtwin
    vtwin Air cooled runnin' mon
    Jan 11, 2005
    9,994
    NorCal
    I told my wife to, "Be careful, I've got a spindle in the freezer." "Which side is it on?" She asked. "On the right". "Ok". My daughter remarked. "Dad mentions a car part is in the freezer and Mom doesn't ask why, just where in the freezer is it. You guys have been married too long."
    Needed to install the Turner seal race.
    More cleaning and painting. worked on the right side upper A arm.
    S3bird, troidus, SafetyThird and 2 others like this.
  3. vtwin
    Jan 11, 2005
    9,994
    NorCal
    I drilled out the rubber for the bushings and cut the sleeve with a rip saw. Then used an air chisel to drive out the outer sleeve.
    That's a lot of work. I think I'm going to find a piece of pipe and cut to fit in between the arms like the factory manual.
    zookster likes this.
  4. vtwin
    Jan 11, 2005
    9,994
    NorCal
    Lower A arm. Someone broke the head of the bolt off and peened the bolt in place. If I ever get the part ordered for my welder, I'll get that bolt out.
    Moved onto to the overdrive. The solenoid is a three wire on the old transmission and the "new" transmission is a two wire. Decided to swap out the solenoid and governor for the original ones.
    Used my bicycle wrench, or maybe it's a mono shock wrench, I forget.
    40mm was too large and the 36mm barely fits. I used to plastic mallet to drive it on. It worked well enough.
  5. vtwin
    Jan 11, 2005
    9,994
    NorCal
    Parts are in, but the overdrive still doesn't seem to work. It's ok, it will get addressed.
    Went ahead and used my new bleeder to bleed the rear brakes. I wanted to get rid of some older brake fluid I had and poured it in and used the bleeder pull it and any garbage through. All the while topping off with fresh clear fluid. Once the older stuff went through and the clear stuff shows up, I shut the bleeder off. I didn't want to waste a full tank of air in my compressor and this tool uses a lot.
    zookster and 42 like this.
  6. Fire Escape
    Fire Escape Long timer
    Apr 13, 2007
    3,934
    NH
    You mention there being a spindle in the freezer
    Wife asks which side
    Daughter knows that a spindle IS a car part
    You are doing something RIGHT!
    Bruce
    Dogscout, Nailhead and vtwin like this.
  7. vtwin
    Jan 11, 2005
    9,994
    NorCal
    Since both kids moved out and if my wife isn't available, I can now bleed brakes by myself. They've all helped with that and pushing cars around most their lives. :lol3
    Stubanger, zookster and Fire Escape like this.
  8. vtwin
    Jan 11, 2005
    9,994
    NorCal
    Sold two sets of wheels yesterday, so I'm flushed with cash.[​IMG] I decided to spend it on the Hawk and dropped by to see Carl and Herman.
    I used the money on these, but it wasn't enough. It was like when I used to go onto the Snap-On truck and spend $200-300 and came away with a handful of tools. I needed these anyway and the money from the wheels helped, somewhat.
    I also went to Alan Steel and bought my floor. Like Michelangelo and a block of marble, I only have to cut away the parts that don't look like the floor.
  9. Nailhead
    Apr 6, 2003
    10,922
    Longmont, CO
    Bleeding brakes on my Dasher was pretty much required of any friend of mine during high school.
    Purcell69 likes this.
  10. vtwin
    Jan 11, 2005
    9,994
    NorCal
    :jack A Dasher! (AKA Audi Fox?) That should be in "Cars Millenials Won't Remember".
    Purcell69 and kbasa like this.
  11. Nailhead
    Apr 6, 2003
    10,922
    Longmont, CO
    It is-- go look. Mine was brown, the second red.
  12. vtwin
    Jan 11, 2005
    9,994
    NorCal
    Ok, cleaning and painting is dreary, but taking one day at a time to do parts is slowly getting it done.
    Leaving the right side upper "A" arm out in the sun to warm up while the bushings are in the freezer, freezing.
    Cutting the support down to the needed length.
    Nailhead and zookster like this.
  13. vtwin
    Jan 11, 2005
    9,994
    NorCal
    That went easier than I expected.
    New snubber in as well. It was a little wider, but a little trimming and it fits fine.
    Time to move onto the right side lower arm. I have to get that broken peened bolt out.
  14. vtwin
    Jan 11, 2005
    9,994
    NorCal
    I actually drilled it centered.:clap
    Well, I learned something, it's not a bolt, but a wedge pin. It's out though and no damage to the lower joint.
    Drove out the lower bushings using the drill out rubber, air chisel bushing method.
    Replacing the sway bar link bushings as well. Painted a bunch of parts today and it's time for dinner.
    zookster, budsboy and SafetyThird like this.
  15. vtwin
    Jan 11, 2005
    9,994
    NorCal
    The springs came in, but they fell short. :-) I posted a query in Tech Talk on the Studebaker Drivers Forum and someone responded that they work fine and even handles better with these Precision (Moog CC655) springs. Looks like they are going in. The photo looks like they are really short, actually only 1 1/2". They are stiffer though.
    Fire Escape and zookster like this.
  16. Nailhead
    Apr 6, 2003
    10,922
    Longmont, CO
    VT, I'd do all your painting for the mere satisfaction of accomplishment. That kind of non-finish painting is to me such a gimme toward that satisfaction that I look forward to it every time.
    kbasa likes this.
  17. vtwin
    Jan 11, 2005
    9,994
    NorCal
    Chris, there are so many defects in the work I'm doing the pictures don't show. :shog Wait until I leave the orange trunk lid on the car.:jump
  18. thumpism
    thumpism Between bikes
    Dec 16, 2005
    7,097
    Richmond, Virginia
    Gold '76 wagon for me. Loved it until it croaked.
  19. vtwin
    Jan 11, 2005
    9,994
    NorCal
    It's Sunday and thinking of going to the Saratoga Car Show. Just checked the dates, oops, it's next Sunday. Ok then, I'll get on to the lower control arm.
    While in between coats of paint, I started fitting the replacement seats and actually able to use one of the reinforced original mounting holes.
    Factory support which allows my Transit Connect seat to be pretty much located perfectly fore, aft and centered, I'm amazed.
  20. vtwin
    Jan 11, 2005
    9,994
    NorCal
    Rear foot is pretty close to fitting in the factory seat belt hole. I may just have to drill a couple of holes in the rail to fit it.
    Right rear hangs in the air, so a bracket will have to be made to fit it properly.
    Right front will interfere with the center console mounting, but the seat is more important to me than the center console. I'll have to fabricate support for the seats on both sides and I haven't even fitted the passenger side with the floor heater. Hopefully, there is enough room for the inner foot to mount.
