1. ** Enter to win a $250 gift card! We want to hear from you, please take this survey **
    Take this survey which covers a range of questions about improving the community, the things that interest you and anything else you want to share with us. All responses will remain anonymous.
    Click here to take the survey
    Dismiss Notice
my most ambitious build - 79 KZ400 basket case - fully disassembled
Discussion in 'Some Assembly Required' started by noman, Jul 11, 2019.
  1. noman
    noman Long timer
    Jun 4, 2007
    3,027
    the sticks, southern vt
    picked up a 79 KZ400 stalled project yesterday, in plastic tubs. came w/large pile of new parts, including a NOS points plate, shocks, Flanders bars, brake pads and shoes, full set of motion pro cables, full athena gasket set, H4 headlight, LED tailight, allballz stem bearings, front/rear wheel bearings, new fork seals and shields, SS bolt kit, more. just found a complete spare head in a tub yesterday. PO is a welder by trade, and fab'd a custom sub-frame and a nice 'glass seatpan. gave me a thumbdrive w/approx 400 disassembly pics and a clymer's too. parts are bagged and labeled. the bad? need to weld on shock brackets and the cases are apart, my first time. $290 on vt craiglist. a year-long project probably, but no hurry.
    shinyribs and Pezz_gs like this.
  2. MATTY
    MATTY BORDER RAIDER
    Jun 23, 2014
    5,349
    England On the Scotish border
    Looks to be a good project, what direction are you going with it, anything in particular?
  3. noman
    noman Long timer
    Jun 4, 2007
    3,027
    the previous owner was headed toward a "flat tracker" build with the F3 tank ( a little smaller), bars, smaller battery, curved LED rear light, modified frame and a fab'd flat tracker seat-pan. it would make sense to me to continue in that direction. i don't mind the look, and prefer it over the brat style. with little weight and going -1 on the front sprocket, performance should be ok.
  4. Beezer
    Beezer Long timer Supporter
    Oct 26, 2004
    10,208
    Anchorage, formerly Spenard (hub of the universe)
    good luck, they are an orphan. there are no pistons, rings, or valves, etc. available from the dealer. the only things they will have are parts that fit something else by coincidence. there is a fair amount of parts on fleabay but that is variable. a good 400/440 forum:
    http://kz400.com/
    I think its these guys, they had some racing tips as well as general knowledge. one thing they were doing is removing the balancer (for racing). there is a quirk in the shifter btw... it will only select 1st or neutral unless the output shaft is turning. there are 3 little ball bearings that block the shifter unless you are moving. I took them out. I built one up (440) with an aluminum swingarm and mono shock and a DR fork.... it was an OK bike but not much power.
    TonyKZ1 likes this.
  5. Grinder74
    Grinder74 Adventurer
    Jun 4, 2014
    37
    X5- and Beezer like this.
  6. TonyKZ1
    TonyKZ1 Long timer
    Dec 15, 2005
    1,275
    Marble Hill, MO. U.S.A.
    Wow, your '78 KZ400 looks great, almost new/restored in fact. My '75 KZ400 never looked that good, it ran fine though.
    Grinder74 likes this.
  7. VX Rider
    VX Rider Long timer
    Dec 11, 2015
    7,234
    Phoenix
    Not that it matters, a quick search shows there are rings, valves, and pistons available
  8. Beezer
    Oct 26, 2004
    10,208
    unless things have changed since I did mine 10 years ago, parts may be listed, but are not available when you go to order. there is stuff on fleabay.
    oh yea.... some of the carb boots were miss-marked at the factory and up is down, so they leak air. also, if the rubber is too hard it can be softened with wintergreen oil. there are threads about it, including one I posted here some years ago
    #8
  9. fast1075
    fast1075 Not a Lemming
    Dec 28, 2013
    2,007
    Flaw'da
    All the KZ models used the "tiny ball bearings" neutral finder. Leave them in for a street bike. It only works sitting still. You will never notice it when riding. If you are racing, take em out, and have the shift drum modified for neutral on the bottom.
    Years ago I was given a KZ400. I used it to putt around the pits at the races. The carbs were ruined, so I made an intake manifold from some copper fittings and installed a random 34mm mikuni I had laying around. Worked fine for my use. One year at Gainesville it got stolen. Hated that I lost a good carb.
    #9
    jays100 and Beezer like this.
  10. 3legs
    3legs Real men ride sidecars Supporter
    Oct 3, 2007
    2,939
    Adelaide,South Oz
    #10
  11. noman
    noman Long timer
    Jun 4, 2007
    3,027
    this is great, thx guys!
    ps looking thru the parts bins yesterday i found a NOS OEM points plate and a spare, complete head. valves/springs/keepers/cam/rockers everything.
    #11
    Pezz_gs and Beezer like this.
  12. fast1075
    Dec 28, 2013
    2,007
    Flaw'da
    I re-read my post. It came across poorly. I like the 400. If the bike I had came with a title, it would have ended up as a café racer. It is a solid engine, and looks good. The one I had looked like it sat 10 years on the seashore, and then was beat with baseball bats. The absolutely most beat up POS imaginable. I can't believe someone stole it except to sell it for scrap.
    #12
  13. noman
    noman Long timer
    Jun 4, 2007
    3,027
    progress update: PO replaced the entire rear section w/a lightweight hoop, then de-tabbed the frame. i had a local welder fab shock mounts, came out pretty good. when the frame is dead level, the rear hoop and shock mounts are perfectly horizontal, with the shocks plumb. i spec'd 1/8inch plate with locating spools. new shocks are shorter than the OEM, so mounting holes lower. not available locally, so i ordered two stainless steel 12x75mm bolts w/hardware. shock preload is adjustable, as is overall length. i can dive the front end by jacking up the rear and dropping triples if there is a need.
    swingarm spacer that acts as inner race for the needle bearings has some corrosion on one end, that was polished up and will keep an eye out for a good, used replacement. needle bearings look and feel fine, so they'll be re-installed temporarily. swingarm and mounting area will be sanded/painted, then i'll re-furb the rear wheel and install that.
    #13
    invisa-bill, Scubawerx and TonyKZ1 like this.
  14. noman
    noman Long timer
    Jun 4, 2007
    3,027
    progress update: triples, swingarm and frame have been sanded and sprayed w/3 coats of flat enamel. Allbalz head bearings and Flanders bars installed. full disass and thorough clean of fork internals, new seals and dust shields, then filled with some w/Belray 20wt i had hangng around. fork lowers were polished to a satin finish. rolled her outside for a pic w/wheels and tank plopped on. was told the tank is from an F3 and kinda like the look so far. engine mounting bolts were polished, but i gotta paint the brackets. next up is polishing the spokes, replacing wheel bearings as needed and polishing the brake panel. note: corrosion on the upper sections of the forks is pretty common on bikes with shrouded forks, i'll prob wrap w/tape or otherwise cover.
    #14
    oic and invisa-bill like this.
  15. Mike944
    Mike944 Adventurer Supporter
    Apr 8, 2006
    66
    Northeast USA
    Personally I'd dump the AllBalls bearings. I put a new set of rear wheel bearings in a KTM and they didn't make it one season. YMMV etc...
    #15
  16. noman
    noman Long timer
    Jun 4, 2007
    3,027
    i've used 'em to upgrade stem bearings for prob 20 projects, gonna keep using them there. i only use name brand stuff for rotating elements, like on wheels. suppliers such as SKF, FAG, Steyr, etc.
    #16
    Mike944 likes this.
  17. fast1075
    Dec 28, 2013
    2,007
    Flaw'da
    Looking good so far. The frame has nice clean lines to it.
    #17
  18. 9mm
    9mm Been here awhile
    Apr 18, 2006
    642
    "Southeast of Disorder"
    the gas tank looks like a F7 175
    #18
  19. noman
    noman Long timer
    Jun 4, 2007
    3,027
    it sure does, PO was mistaken i think.
    #19
  20. noman
    noman Long timer
    Jun 4, 2007
    3,027
    some progress. master cyl and caliper cleaned, pistons and bores polished, all seals still pliable and look as they've been replaced. used synthetic DOT 3D, replaced pads w/EBC organic, no leaks and all is well there. front spokes and rim polished, recent bearings and seals relubed, tire good but outdated and will be tossed. sprocket carrier polished, cush drive cleaned, bearings apparently recent, relubed only. new sprocket on order. full disass and polish of brake panel, new brake pads installed. rear wheel only has 36 spokes to polish. : (
    locking tabs not bent over yet, no cotter pin as yet. all critical fasteners, like those, are loctite'd and torqued.
    don't like the new bars that came with the project, once they're replaced w/shorter and a bit flatter i'll prob go with braided lines.
    #20
    TonyKZ1 likes this.
