My motohack always needs something
Discussion in 'Hacks' started by High Octane, Jul 8, 2015.
  1. High Octane
    High Octane Long timer Supporter
    May 31, 2013
    2,520
    South Dakota
    Well there’s more to come. We’ll just see if anything good comes from this.
  2. steam powered
    steam powered just a regular punk
    Jun 17, 2018
    530
    New Zealand
    Now it all starting to make sense. And FWIW a double row spherical roller bearing is fine with any amount of misalignment as long as the balls are staying within the outer race. There is no advantage in making sure they are aligned.
  3. High Octane
    May 31, 2013
    2,520
    South Dakota
    Throttle bodies getting the old what for.
    Jimr80gs and FLYING EYEBALL like this.
  4. davebig
    davebig Another Angry Hun !
    Jan 19, 2004
    11,039
    Minnesota
    Good plan and they will smell better also, the air bleeds always seem to clog with carbon and crap, everytime you balance them it helps to remove the lrg brass air bleed screw and give them a blast of carb cleaner and compressed air.
  5. High Octane
    May 31, 2013
    2,520
    South Dakota
    I was going to knock out this dent and then get the header ceramic coated. But it looks like there’s a restriction right in the way of by dent knocker outer. So I guess it’s either a eBay header pipe or live with a dent.
    D74FA7E5-98FD-4800-884D-77DA60E9EF8D.jpeg D0A17347-0BE3-4E2C-B614-67B42B06C6B1.jpeg
  6. DRONE
    DRONE Dog Chauffeur
    Oct 1, 2007
    8,995
    Tacoma - ish, WA
    High Octane and brstar like this.
  7. GR8ADV
    GR8ADV Safety Second!
    Mar 7, 2007
    1,789
    Bellevue
    Keep the dent. Remove the restrictor. Not sure where this is? Can you point it out on the bike with the exhaust installed?
  8. DRONE
    DRONE Dog Chauffeur
    Oct 1, 2007
    8,995
    Tacoma - ish, WA
    I think that's in the crossover pipe between the left and right headers.
    Flyin' Monkeys and High Octane like this.
  9. High Octane
    May 31, 2013
    2,520
    South Dakota
    The underside of the crossover pipe on the right side of the bike( left in the pic). I doubt if it’s a performance issue. Just don’t know if I want to pay to have a dented pipe ceramic coated.
    Flyin' Monkeys and GR8ADV like this.
  10. High Octane
    May 31, 2013
    2,520
    South Dakota
    Flyin' Monkeys, MGV8 and brstar like this.
  11. brstar
    brstar Long timer
    Aug 17, 2007
    2,133
    Shoalwater Western Australia
    That restriction reminds me of a scooter a nephew of mine had as a young fella.
    Chinese made 50cc two stroke.
    50kph top speed.
    1st he drilled out the restriction in the exhaust.
    Gained little.
    Then the restricted air intake.
    From about 12mm hole up to I think 16mm.
    Any more defeated the purpose.
    Up to 70kph now.
    Then there were the spacers restricting the variable belt drive.
    90 plus kph and scary as hell to ride with the puny drum brake and feeble suspension.
    It had Yamaha written on the piston apparently so made to Japanese standards.
    Flyin' Monkeys likes this.
  12. High Octane
    May 31, 2013
    2,520
    South Dakota
    My powder coated / ceramic guy works in the family Exhaust Pros garage during the daytime. I bet he could fix it up / cut and weld in an end cheap. Maybe I’ll go to town (30 miles) and ask him.
  13. High Octane
    May 31, 2013
    2,520
    South Dakota
    Pistons? Did someone say pistons? What are these damn things doing here.
  14. redfishguide
    redfishguide Old Dirt Biker Supporter
    Dec 17, 2004
    1,245
    Beaufort, South Carolina
    You could try the ole slide hammer trick. Drill a hole add a screw and see if you can hammer out the dent.
    Or you could cut the pipe right near the dent to give you access to repair....then weld her back together. Easy....:photog
    Jack and Buck
  15. bk brkr baker
    bk brkr baker Long timer
    Jul 19, 2006
    10,533
    The Bluegrass
    My vote , is this a poll ? , is for plugs , compressed air and cherry red stainless.
    Could work , could be an interesting experiment . Could be mildly dangerous.
  16. High Octane
    May 31, 2013
    2,520
    South Dakota
    I texted the pics to my powdercoater. He said his dad can fix it almost perfect before he ceramic coats it. I suspect he’ll cut, hammer, and weld it. I plan to take it to him tomorrow.
  17. davebig
    Jan 19, 2004
    11,039
    Minnesota
  18. High Octane
    May 31, 2013
    2,520
    South Dakota
    I’ll do some more measurements but so far they appear exactly the same. Maybe I already have RT pistons. Is there a specific year RT or RS to use. Gspot hasn’t been much help yet.
  19. davebig
    Jan 19, 2004
    11,039
    Minnesota
    All RT RS S used same piston and cam , GS and R a different piston and cam. on the 11/1 models the center is raised a bit.
    11/1 piston
    GS and R flat top
    It's the small things and the lack of any easy alternatives and they are well made Mahle pistons.
  20. High Octane
    May 31, 2013
    2,520
    South Dakota
    The RT pistons I bought do not look like that. They are flat top. I wonder if there are multiple RT piston designs.
    My GS piston on the left, my new “RT” piston on the right.
