My motohack always needs something
Discussion in 'Hacks' started by High Octane, Jul 8, 2015.
  1. draperg1
    draperg1 PapaBear Supporter
    Mar 31, 2013
    736
    Martinsville, VA
    No matter what change you decide to make you need to be willing to scrap and start over, at least that's what I tell myself.:baldy
    BJMoose, Strong Bad, Bobmws and 2 others like this.
  2. Pokie
    Pokie Just plain Pokie.
    Apr 4, 2013
    5,695
    Fort Collins, CO
    It doesn't matter what I make, I always end up with "extra" pieces left over. It's all a part of building.
    brstar and draperg1 like this.
  3. Strong Bad
    Strong Bad Former World's Foremost Authority Supporter
    Oct 29, 2007
    12,416
    Omicron Persei 8
    That's what we call "A work in progress".
    davebig, brstar and draperg1 like this.
  4. High Octane
    High Octane Long timer Supporter
    May 31, 2013
    2,945
    South Dakota
    I thought I’d see the real world effect of raising my lower shock mount. Just as I thought, it increased the steering effort. Not a lot but noticeable. It did give me a bit more ground clearance but I don’t like the trade off. I’m going back.
    BJMoose, draperg1 and MGV8 like this.
  5. davebig
    davebig Another Angry Hun !
    Jan 19, 2004
    11,529
    Minnesota
    :hmmmmm Hmmm your as bad as I am ! If I had your talents and equipment I'd never be satisfied with anything :-) Its going to be a long winter Octane !
    BJMoose, draperg1, MGV8 and 3 others like this.
  6. High Octane
    May 31, 2013
    2,945
    South Dakota
    Just just got back from a test ride. I’m declaring the swing arm and shock mounts to be now done. Ready for powder coating.
    onto the next thing....
  7. High Octane
    May 31, 2013
    2,945
    South Dakota
    Just a placeholder for things to come.
    65FF6947-13A1-4A41-A55F-1FE6EC84A864.jpeg C1A67FE3-8A16-418F-9E52-883328A06BC1.jpeg 872BB64F-A044-4DC1-877E-63BFB0DB070B.jpeg
    draperg1, Bobmws, OzCRU and 4 others like this.
  8. claude stanley
    claude stanley Claude
    Aug 2, 2018
    643
    pa
    leading link braking.jpg JUST SOME FOOD FOR THOUGHT
    Honda-50, draperg1, Jeff 8 and 2 others like this.
  9. High Octane
    May 31, 2013
    2,945
    South Dakota
    When the notes say upper length compared to the lower link; are they comparing the brake stay to the leading link? I’m confused when they compare upper link to the lower link. What exactly are they comparing?
    by the way the k1600 wheel carrier mod is from Ad Donkers via MikePa. I’m
    Not smart enough to have figured that out.
  10. steam powered
    steam powered just a regular punk
    Jun 17, 2018
    926
    New Zealand
  11. High Octane
    May 31, 2013
    2,945
    South Dakota
    The post numbers don’t show on my iPhone but if I have the correct post, the pic is with the wheel almost jacked off the ground. The brake stay is actually pretty horizontal when the wheel is on the ground. And even better now that I’ve bought longer stay bolts ( but no pics).
    draperg1 likes this.
  12. claude stanley
    Aug 2, 2018
    643
    pa
    Just think of the brake rotor spinning with the wheel when underway. Then think of the brake caliper stopping the rotor ( extreme thought but the idea is the same) .....
  13. steam powered
    Jun 17, 2018
    926
    New Zealand
    Guessing that once your weight is on the seat the stay is close level and brake dive isn't a problem.
    BJMoose, draperg1 and High Octane like this.
  14. Strong Bad
    Oct 29, 2007
    12,416
    Omicron Persei 8
    Thinking about dive or rise of the front end under braking here is article about my buddy Preston Petty's patented "No Dive" system. If you can get the Factory Team riders like Broc Glover at Yamaha, Roger Decoster at Suzuki, Carl Cranke at KTM, and Brad Lackey at Honda to use it. Of course you have to remember that these were all pre-disc brakes bikes. https://motocrossactionmag.com/mxas...astic-part-from-the-man-who-invented-plastic/
    The 100 and 125cc Sachs bikes that all came with LL forks, were known for rising when using the front brake.
    High Octane, draperg1 and norton(kel) like this.
  15. claude stanley
    Aug 2, 2018
    643
    pa
    One of the main advantages to what we call 'floating calipers' if to be able to control anti dive to a realistic level. Fixed calipers will create a lot of anti dive which compromises the rubber to the road traction under many circumstances. There is only so much traction available at the contact patch of the tire where the rubber meets to road....fixed calipers can create a front wheel lockup especially on loose or wet surfaces. Once that happens one is at the mercy of the situation . Floating calipers when setup well help prevent this.
    draperg1, Jeff 8 and Strong Bad like this.
  16. High Octane
    May 31, 2013
    2,945
    South Dakota
    Gyro Gearloose. Going to have to remember that one.
  17. High Octane
    May 31, 2013
    2,945
    South Dakota
    Swing arm all powder coated and mounted.
    I also made a rack for added gas. This will be the home of a fuel cell but for now I’ll stay old school and use cans. The white one is for woody’s water, we’re headed to the desert next month.
    The tub is away at the painter. It’s going to get all shinny and cool.
    draperg1, Bobmws, propforward and 2 others like this.
  18. DRONE
    DRONE Dog Chauffeur
    Oct 1, 2007
    9,510
    Tacoma - ish, WA
    Lemme guess. You bought Dave's yellow and black Adventure saddle and are painting the tub to match.
    Got it in one. :rofl
    draperg1 and Jimr80gs like this.
  19. davebig
    Jan 19, 2004
    11,529
    Minnesota
    No such luck shipping to SD would have been too cheap :fpalm people only buy my shit from the other end of the world :fpalm
    draperg1 and Bobmws like this.
  20. High Octane
    May 31, 2013
    2,945
    South Dakota
    But
    He’s caused enough trouble around here. :-) Although I could use a new seat.
    Blackie’s old tank was getting stripped of it’s decals this morning when I dropped of the tub.
