My motohack always needs something
Discussion in 'Hacks' started by High Octane, Jul 8, 2015.
  1. FLYING EYEBALL
    FLYING EYEBALL out of step
    Mar 18, 2008
    12,645
    north of seattle
    Looking forward to your desert travels! take care
  2. propforward
    propforward PIE!romaniac
    Jun 11, 2009
    14,673
    Central Minnesota
    Top shelf work as usual. :thumb
  3. High Octane
    High Octane Long timer Supporter
    May 31, 2013
    2,980
    South Dakota
    Before putting the tank and tub back onto the frame after painting I had a few little details to wrap up.
    Fixed a broken grip heater wire
    Eliminated the sidestand lockout switch, I removed the stand already
    Fit the tank with a new fuel pump, filter, hoses, metal quick disconnects
    Prepped the tank plumbing for a auxiliary fuel cell
    Modified my seat latch a bit to make the seat install easier
    I knew the second sidecar brake pedal was a bit too close to the original bike pedal but it was a easy install so I tried it. But in the end now was the time to change it.
    So a bit of acetylene and heat to bend it. With the new bend if felt weak so I added reinforcements. Just in case I get over exuberant in the sidecar brake stomping, you know.
    And a bigger stomper pad for the bike brake.
    Then a bit of welding to add an adjuster to allow setting the peddles at different heights.
    3431AA8E-1C17-4966-B8A0-D324B378FA4F.jpeg DD057AB8-96A4-49C4-B173-69C23D7629F7.jpeg
    I need a couple of SS flat head screws to finish it off, but I think it will workout ok.
    I need to make a couple SS washer/grommets for the front fender yet.
    The tub is back from the painter. I hope to install it today.
    And then I think the list is pretty much done. Well, except for maybe replacing the front shocks. But Christmas has been hard on the finances so they will have wait a bit.
    Jeff 8, Bobmws, MGV8 and 2 others like this.
  4. DRONE
    DRONE Dog Chauffeur
    Oct 1, 2007
    9,635
    Tacoma - ish, WA
    Wow - fancy brake pedal! Nicest one on any GS anywhere.
    Probably only of interest to 1150GS guys, but how did you fix the seat latch?
    And on the sidestand switch, did you just cut it off and solder the leads together, or something more?
  5. High Octane
    May 31, 2013
    2,980
    South Dakota
    Like every thing I do I’d change the brake pedal if I did it again. The mud grooves should have been thru slots, so the mud would drop thru. The tab that sticks out to the side was going to house the thread for the adjuster but then I thought to just put the adjuster on the sidecar pedal.
    The torsion spring I made for the seat latch kept wanting to disengage so I replaced it with a synthetic elastomer spring (cut off tarp strap). And made a stop so the latch stays in position better.
    I cut the plug off the side stand switch wire and soldered the leads together and then plugged it into the bike plug. This way the bike is still stock and a new sidestand switch would plug right back in.
    Blackie’s old tank never looked so nice.
    Bobmws, MGV8, OzCRU and 2 others like this.
  6. DRONE
    DRONE Dog Chauffeur
    Oct 1, 2007
    9,635
    Tacoma - ish, WA
    "Synthetic elastomer spring" :lol3
    This thread is starting to get a little long. I'd totally forgotten that you fabricated your own seat latch to replace that abomination that BMW designed.
    High Octane likes this.
  7. claude stanley
    claude stanley Claude
    Aug 2, 2018
    652
    pa
    Just a thought but imho It is not a bad idea to carry the removed sidestand along just in case as it can be handy at times. We typically leve them on but some don't. Not being critical but it is one of those thing that can become a good 'tool' under some circimstanes.
    MGV8 likes this.
  8. High Octane
    May 31, 2013
    2,980
    South Dakota
    You all thought it was going to black. Didn’t ya? Ha!
    MGV8, draperg1, Bobmws and 7 others like this.
  9. davebig
    davebig Another Angry Hun !
    Jan 19, 2004
    11,583
    Minnesota
    Actually it looks pretty nice, I'd go for some accents black and red for tub and chair :-)
  10. High Octane
    May 31, 2013
    2,980
    South Dakota
    I kinda wish I had painted the beak red. But I have a few ideas.
    I was going to air brush a naked lady on the nose. But I asked the wife if she thought the neighbor girl would pose for me. That’s when she hit me.
  11. DRONE
    DRONE Dog Chauffeur
    Oct 1, 2007
    9,635
    Tacoma - ish, WA
    I think some inverse pinstripes would look pretty good -- red on the bike and black on the chair.
    But, yes, I was totally expecting black on black on black on black. I'm exceedingly pleased that you are finally following my instructions. :lol2
    draperg1, davebig and High Octane like this.
  12. propforward
    Jun 11, 2009
    14,673
    Central Minnesota
    I’d like to explore the naked lady option some more please thankyou please.
  13. High Octane
    May 31, 2013
    2,980
    South Dakota
    To be honest it was going to be black. But when I got to the body shop I saw his red dodge pickup and thus the red dodge paint.
    The tank and fender were already done in black so too late for them. I’m going to ask if I can get the paint code and have a rattle can made up.
    it’s got black bed liner on the bottom, painted red as it turns up the side a couple inches.
    draperg1 and Bobmws like this.
  14. High Octane
    May 31, 2013
    2,980
    South Dakota
    Naked ladies are off the table. For now.
    draperg1 likes this.
  15. propforward
    Jun 11, 2009
    14,673
    Central Minnesota
    That’s OK. I can enjoy them under the table as well as on it.
  16. brstar
    brstar Long timer
    Aug 17, 2007
    2,576
    Shoalwater Western Australia
    You had them on the table???
  17. Pokie
    Pokie Just plain Pokie.
    Apr 4, 2013
    5,981
    Fort Collins, CO
    The gas tank AND the beak needs to also be red!
  18. draperg1
    draperg1 PapaBear Supporter
    Mar 31, 2013
    784
    Martinsville, VA
    Put a rig together for a friend a couple of years ago, similar situation, she had a red chair and a white mule. She named it Peppermint, sooooo.......:-) IMG_20190502_143033205.jpg IMG_20190502_142955711.jpg IMG_20190502_142732380.jpg l
    Bobmws, bete, MGV8 and 4 others like this.
  19. MGV8
    MGV8 Long timer Supporter
    Aug 29, 2010
    1,329
    Canoe BC
    That turned out very nice. I'd leave it but knowing you!!!
  20. Pokie
    Apr 4, 2013
    5,981
    Fort Collins, CO
    I too have a black bike and a red sidecar. I think the colors together look great!
