NATO approved tire tools
Discussion in 'Equipment' started by cyclecat, Nov 25, 2002.
  1. cyclecat
    cyclecat half post a day wonder
    Oct 30, 2001
    1,317
    Vadito, NM, USA!
    Anyone try these guys tools?
    http://www.extremeoutback.com/Tire_repair.htm
    The tire spoons look sturdy, and the bead breaker is fairly compact. You can get all the tools and a CO2 inflator with cartriges for a bit over $100. Might be a good deal. They claim to be suppliers to NATO forces.
  2. Waco
    Waco Renegade Sickle Hound
    May 16, 2002
    15,150
    Waco, Texas
    If the tire is off the bead, I wouldn't have much confidence in a CO2 inflater. I assume this is for holes too large to plug?
  3. Mully
    Mully Kineticist
    Jul 9, 2001
    3,769
    The Comstock
    Yes, I had the MC bead breaker/tire iron setup and was unsuccessful at making it work on my GS. The problem is that the bead will pop off in one spot on one side but not enough to loosen the tire (this is on a Tourance) around. It is also tedious to use, requiring 30-40 turns of a nylock nut to draw the breaker arms together, and if tightened down too much, the arms will mar the rim edges. To add insult, inflating a newly-mounted 150/70x17 tire with CO2 cartridges is an exercise in futility: about 15 of `em might get the bead seated and 20psi in. The tire irons are unsuitable for working on these large-section radial tires unless you're a) strong as Jack The Bear and b) don't care about the marring of your rims. Bottom line is that the setup over-promises and under-delivers for use on large radials such as mounted to the GS. It might work satisfactorily on the tires on a KLR or KTM or other dirt bike.....
    I can, however, give my *strongest* recommendation to George & Tamara Carousos, owners of ExtremeOutback: I've bought several items from them, they're good people and fair businessmen with generally good products, and I hope nothing I've said about the bead breaker in any way discourages you all from doing business with them.
    mully
  4. zero-zero
    zero-zero Horny Horned One
    Mar 22, 2002
    2,378
    Vigo, Spain
    Brian,
    You had your chance at the vendor forum, and everyone that cared about it has read your thread there. From now on, you're supposed to enjoy the forums like any other user and not insert references to your product in every post you make. :nono Thanks.
    Of course, I'm no one to tell you this, but trust me, better me than some others... right doods?:):
  5. Brian Doherty
    Brian Doherty Flying Scotsman
    Nov 27, 2002
    18
    Tustin, CA
    My apologies if I violated protocol.
    It seemed like a pertinent area of address for our product on the topic of discussion - no spam intended.
    All the best.
