Need a bigger walk thru interior door
Discussion in 'The Garage' started by Xsv, Aug 10, 2019.
  1. Xsv
    Xsv Going nowhere, fast Supporter
    Sep 11, 2017
    1,037
    Spokane, Washington
    My shop is 60 x 30. The front area is 38 x 30 with 15 1/2 foot ceilings. The rear is 22 x 30 with 8 foot ceilings. It is heated with radiant floor heat with different zones front and rear. I typically keep the rear area warmer in the winter and having 8 foot ceilings makes it a bit brighter to work in. The two areas are separated with a 3-0 man door.
    I’d like to be able to move my motorcycles to the rear to work on in the winter, but they are too wide to go through the door. I’d like to have about 42” to get the bikes in and out. I have room to the right of the current door to make it wider. (Will have to move light switches)
    So what is the most economical way to do this non-standard door size?
    I was leaning towards making my own barn door and hanging it. Any other ideas?
  2. gsweave
    gsweave Yinz, blinkers are on, JACKWAD! Super Supporter
    Apr 2, 2005
    22,457
    The Paris of Appalachia
    Mahogany Grain 42"X80" Traditional Dutch Entry Door. 9-Lite SDL Frosted Glass. Jeld-Wen A5944. Split Finish, Factory Painted
    Amphib and Eatmore Mudd like this.
  3. Xsv
    Sep 11, 2017
    1,037
    Spokane, Washington
    I appreciate the suggestion, but am guessing this doesn’t meet the “economical “ part of my solution
    gsweave likes this.
  4. lkraus
    lkraus Long timer
    Dec 15, 2012
    1,227
    Central Ohio
    I used a double door for the woodworking area of my garage, 72" wide. The second door has been useful, but I really only need it about 2-3 times a year. I can still use the "swing area" behind it to store movable items, usually the shop vac and trash can. A 42" door needs a lot of area to open.
    You might look for used doors at your local Habitat ReStore to keep the cost down.
    Arbolmano and ozmoses like this.
  5. ArielNut
    ArielNut Been here awhile
    Mar 8, 2015
    107
    Somewhere in the hills
    Hard for me to tell if that is a bearing wall or not...If it is a bearing wall you will need to put a longer header in. As you mentioned, the wiring needs to be relocated so you might as well carry the header over to the next wall stud (approx 16") and put your sliding barn door on...
  6. Xsv
    Sep 11, 2017
    1,037
    Spokane, Washington
    There is a second floor above the rear portion of the shop so this is a bearing wall.
    Is there a normal distance that the barn door hangs away from the wall? I am guessing with the radiant floor heat the gaps really don’t matter as much.
    The other side of the door would prohibit me from doing a double door as there is a closet (under the stairs) on one side and a bathroom door on the other.( sorry I should have included that in the original post)
  7. DonM
    DonM Do-dah Do-dah Supporter
    Jan 13, 2008
    2,680
    Atlanta, GA
    How about a removable panel of plywood just screwed into a frame with a door strike for the existing door. Barn door would be ideal if you have space to slide to one side.
    brgsprint likes this.
  8. Xsv
    Sep 11, 2017
    1,037
    Spokane, Washington
    Often things that occur in the shop is a testing ground for things at the house. Looks like I can build a distressed pine barn door (I have the room) with hardware for about $100. Will post up when it is done!
    #8
    Yinzer Moto likes this.
  9. the_gr8t_waldo
    the_gr8t_waldo Long timer
    Feb 28, 2006
    2,742
    tacoma warshington
    what ever you do, you're going to have to address the header..if it were me, I think I'd hang a barn slider type..
    #9
  10. tomrux
    tomrux Been here awhile
    Sep 18, 2010
    817
    northside Briswegia
    What about a smallish pocket slider?
    Cheers Tom R
    #10
  11. markk53
    markk53 jack of all trades...
    Dec 20, 2007
    18,053
    Delaware Ohio
    FWIW I had a 42" door on my garage, worked great rolling bikes in and backing out the door. Bikes were an 83 GL1100 naked Wing, CB750SC Nighthawk S, and KLX650C. I heartily recommend a 42" door size, it was close, but no problem. A 48" would be cool, but that's some serious space requirement.
    We just used a pre-hung metal framed garage access door. Perfect. Fact is if I built a house I'd put in a 42" entry door in it so furniture would be easier to deal with in moving, etc. Amazing what an extra 6" in width allows.
    #11
  12. Yinzer Moto
    Yinzer Moto Long timer Supporter
    Jun 13, 2008
    32,289
    Pittsburgh PA
    Are there concerns about fire rating or fumes getting through that opening? It looks like the current door is metal with a seal.
    #12
    trumpet and the_gr8t_waldo like this.
  13. Yinzer Moto
    Jun 13, 2008
    32,289
    Pittsburgh PA
    Also, is that a shower valve to select the water temp of the hose water? Brilliant.
    #13
  14. Xsv
    Sep 11, 2017
    1,037
    Spokane, Washington
    That door was left over from when we built the house so it was just available, but good eye on your part!
    #14
  15. Xsv
    Sep 11, 2017
    1,037
    Spokane, Washington
    Yes it is. I planned well on that, just not on the door:dirtdog
    #15
  16. Dave in Wi
    Dave in Wi Long timer
    Feb 25, 2007
    2,519
    Madison WI (40 Square Miles Surrounded By Reality)
    I’m late to this thread as it looks like your decision is made. A couple of disadvantages of barn type doors. They take up a lot of wall space beside the opening to allow it to open. With the size of your shop it may not matter, but in smaller spaces the wall space might be at s premium. The other thing is, there is not a good way to get a seal. Air, fumes, dust and noise may have easy passage. Just a few things to keep in mind.
    #16
  17. Xsv
    Sep 11, 2017
    1,037
    Spokane, Washington
    I have plenty of wall space. I hear you on the seal. I see where some people have used weatherstripping, although that is not in my plans.
    It is typically just me in the shop and I don’t think this those issues will be to big of deal for this application. Maybe I should make my opening the same size as I would need for a 48 inch double door....just in case I hate the barn door.
    Oh well for now I am pressing forward with the barn door with a fresh load of lumber I just bought from Home Depot......time to go distress it a bit:jack
    #17
  18. muddywater
    muddywater Untermenschen
    Oct 1, 2007
    2,854
    East TN
    #18
  19. muddywater
    Oct 1, 2007
    2,854
    East TN
  20. Xsv
    Sep 11, 2017
    1,037
    Spokane, Washington
    New wood purchased, distressed (was actually fun), cut and assembled with glue and “wrought nails”. Will be several weeks before I enlarge my door opening, replace header, move electrical to new location and hang door. Will post Picts when finished.
    1524B6F2-B40A-4ED2-97CE-18003720D913.jpeg 7A34008B-0CD0-4F62-83A3-9440D53F7DD4.jpeg 71C0D0FF-7609-49E2-BBE3-DD6079F4FFD6.jpeg
    #20
    Yinzer Moto and muddywater like this.
