Need a bigger walk thru interior door
Discussion in 'The Garage' started by Xsv, Aug 10, 2019.
  1. rob1313
    rob1313 Still learning
    Dec 31, 2006
    5,070
    Canada
    If that door is a rated door. And by that I mean designed to hold back a car fire from the rest of your home (not to mention fumes etc) you could have a problem with insurance unless you replace it with a door or assembly of the same rating. That being said it is your home.
    #21
  2. Xsv
    Xsv Going nowhere, fast Supporter
    Sep 11, 2017
    1,030
    Spokane, Washington
    It is an outbuilding that is located about 150 feet from my home. It is a shop not used for living accommodations. The reason a steel door was originally installed is because I had it leftover from house construction
    Yes I did actually rock and tape all the walls and put down a tile (think Walmart) style floor. The couch is something my dogs will sleep on when they are hanging out with me.:clap
    At first glance u could get the impression I live there!
    #22
    rob1313 and DHC-2 like this.
  3. DirtyDaveMO
    DirtyDaveMO Adventurer Supporter
    Oct 10, 2013
    39
    Kansas City, MO
    If you lived by KC I could give you a couple of choices for free doors. My friend is a trim carpenter and asks me all the time if I need a door. I have a few sitting in my shed.
    I'm not a hoarder.
    #23
  4. DirtyDaveMO
    Oct 10, 2013
    39
    Kansas City, MO
    I have a double door in my shop going into the unheated part of my shed. I think it is 5' total and hardly every open the fixed door. A single fixed door will seal much better if that is a factor.
    #24
  5. mnmlst
    mnmlst mnmlst
    Nov 3, 2005
    1,946
    a Pangean remnant
    #25
  6. Xsv
    Sep 11, 2017
    1,030
    Spokane, Washington
    I guess it cold have been worse. I had planned to move all that electrical to the right side of the door, but changed my mind. I’d have all kinds of blank boxes if I extended the wiring. This should work. The king stud will be almost against those single gang boxes. It looks like my opening will be about 45 inches after everything is finished out. Should work to get the bikes in the back!:-)
    Probably frame it out and put in new header tomorrow.
    6E025EB8-8077-4413-918E-2DDF0169A25E.jpeg 23D2352C-E960-4FA7-BEA0-838491524B5A.jpeg A0BF8D90-FE3E-45AA-BFB1-D6EBBEB52A20.jpeg
    #26
  7. Rick1952
    Rick1952 Adventurer
    Dec 19, 2013
    35
    Bay Area
    Looks like that you will need to notch the top left corner of the header and modify the king studs to avoid the electrical or move the electrical going thru the floor/ceiling assembly.
    #27
  8. Xsv
    Sep 11, 2017
    1,030
    Spokane, Washington
    Removing the electrical wasn’t going to happen, so I notched:-) I was able to get the wires to run flat on top of each other to minimize the notch.
    632F5A10-34D6-49B3-831A-2F2361C40251.jpeg 2AB3D495-0613-4356-ABFD-A534A23E61A6.jpeg
    #28
  9. Xsv
    Sep 11, 2017
    1,030
    Spokane, Washington
    I am going to try and mount the door without a header board. Looks like I can drill out about a 1 inch diameter hole the thickness (1/2”) of the sheetrock and use a steel standoff so that I have no pressure (crushing) Sheetrock and should get my door fairly close to the opening. I might try to use some weather stripping to help eliminate some air losses in the winter. The back, smaller portion, of the shop is normally kept at 60 and the larger portion of the shop at 50 degrees during the winter. I will see how it pans out, but your suggestion may be something I hang just for the winter months.
    #29
  10. mnmlst
    mnmlst mnmlst
    Nov 3, 2005
    1,946
    a Pangean remnant
    Be sure to post pics of the blue tarp after you get it up with the office stapler...
    #30
  11. Xsv
    Sep 11, 2017
    1,030
    Spokane, Washington
    Okay???:hmmmmm Quite obviously I am a “blue tarp” and stapler kind of guy
    #31
  12. mnmlst
    mnmlst mnmlst
    Nov 3, 2005
    1,946
    a Pangean remnant
    Just teasin’...
    You should be done by now!
    #32
  13. Xsv
    Sep 11, 2017
    1,030
    Spokane, Washington
    I am a bit slow on the mudding, but it’s slowly coming along!
    #33
    mnmlst likes this.
  14. mnmlst
    mnmlst mnmlst
    Nov 3, 2005
    1,946
    a Pangean remnant
    ... did you insulate around the door frame?
    #34
  15. Xsv
    Sep 11, 2017
    1,030
    Spokane, Washington
    I worked a little back in the small cavity.
    #35
  16. mnmlst
    mnmlst mnmlst
    Nov 3, 2005
    1,946
    a Pangean remnant
    Whatever door you chose, sealing from drafts is what you want to be worried about to keep the heat from creeping out of the warm area
    #36
  17. Xsv
    Sep 11, 2017
    1,030
    Spokane, Washington
    It will be the barn door posted on this thread. The two different parts of the shop are heated via radiant floor heat in 2 zones. I will See how much I am cycling heat in the rear portion this winter and than address it if need be.
    This will be the first full winter of retirement so I will probably spend more time down there. It looks like the slated plastic strips can be done at an affordable price, but we will see.
    #37
    mnmlst likes this.
  18. Yinzer Moto
    Yinzer Moto Long timer Supporter
    Jun 13, 2008
    32,145
    Pittsburgh PA
    With some creativity, you might be able to make the barn door seal fairly well. Position the track is just slightly not parallel to the wall, so as the door opens, it moves away from the wall slightly. Then as the door approaches closed position, it will be moving closer to the wall. Work it so the door finishes fairly snug against some trim. Use some weather stripping if needed. Picture how a van sliding door works.
    #38
    MrBob and gonzomup like this.
  19. Xsv
    Sep 11, 2017
    1,030
    Spokane, Washington
    Unfortunately, hanging without a header board was not going to happen. Nonetheless it is close to being done. Gap is more than I really wanted. (Damn header). Might just do the plastic slates in the winter months.
    C59FFB92-BD8B-4E96-9243-807CDCA6D522.jpeg D39E53B8-2AF1-4419-BB7E-C50BB6952F0A.jpeg E0EA5487-BD1A-4716-8302-57C1627756F8.jpeg
    #39
  20. MrBob
    MrBob In the Pines. Supporter
    Oct 27, 2005
    19,396
    Boulder CO and Tallahassee, FL
    When I installed a frosted glass barn door in a bathroom entry I first horizontally mounted a 8’ long 1”x 6” maple board, glued and screwed, to the wall above the doorway. The barn door hardware fastened to it.
    I was able to get the glass 1/8” away from trim around the door.
    #40
