Need a bigger walk thru interior door
Discussion in 'The Garage' started by Xsv, Aug 10, 2019.
  1. Xsv
    Xsv Going nowhere, fast Supporter
    Sep 11, 2017
    1,227
    Spokane, Washington
    If I had trim that would fill some gap. I originally drilled through the Sheetrock and was going to use spacers (washers) in an effort to not use a header board and not crush The Sheetrock. Almost worked. Unfortunately it hit about 1/8 of an inch below the top of my bottom plate on the second floor. I could have either trimmed off a little at the bottom of the door or tried to hit studs which would have required drilling additional holes in the rail.
    Took the easy route :-)
    589230B2-60B4-4B55-A9FE-A865AA9D920A.jpeg 352DE323-DA47-47F2-A03C-00C866816452.jpeg
    #41
  2. MrBob
    MrBob Distant Supporter
    Oct 27, 2005
    21,083
    Betwixt.
    Trim makes it work. Privacy was important here.
    That piece of glass cost 1400.00. Working with it was a little nerve-wracking.
    #42
  3. Xsv
    Sep 11, 2017
    1,227
    Spokane, Washington
    Nice work. I can only imagine :-)
    #43
  4. MJS
    MJS Long timer
    Dec 23, 2005
    2,851
    Off the grid in San Felipe, Baja
    I can relate. When I was starting out I was hired to hang a 5 figure antique chandelier in a well known actor's beach house. Local electricians didn't want to do it. Bit nerve wracking but scaffolding and 4 guys got it done. Best part was no suprises. And with risk comes reward. :jkam
    OP, nice job on the door.
    #44
  5. Texas Aggie
    Texas Aggie Been here awhile
    Jul 17, 2010
    207
    Nanjing, China and sometimes..... Dallas, Texas
    I had somewhat similar situation with a gazebo and found using several door sweeps in vertical applications worked well for me. I used a 4 of the brush sweeps in bronze. Not as nice
    as the trim but easy to install and works fine for my application without getting any complaints from my wife....
    #45
  6. Yinzer Moto
    Yinzer Moto Long timer Supporter
    Jun 13, 2008
    36,185
    Pittsburgh PA
    Why can’t you install trim to close the gap?
    #46
  7. Xsv
    Sep 11, 2017
    1,227
    Spokane, Washington
    The gap is just a little over 1 inch. If I trimmed it out I would still have a strong 1/2”gap. Aesthetically it looks great. It might look even better if I pick up some trim and distress it and stain it, but that still will leave me with a 1/2 gap.
    There is a variety of ways to address the remaining gap with weatherstripping, etc.
    If I decide to do this (for the winter months) https://www.amazon.com/Strip-Curtai...EQDN69NFGXC&psc=1&refRID=Q07AHBAP4EQDN69NFGXC
    I really don’t need to do anything else.
    #47
  8. Yinzer Moto
    Jun 13, 2008
    36,185
    Pittsburgh PA
    Who says trim has to be 1/2” thick? If you want to stay at 1/2”, then apply something to the backside of the door to make up that difference. Distressing and staining to match the door.
    #48
  9. Xsv
    Sep 11, 2017
    1,227
    Spokane, Washington
    I guess I am just thinking about the normal thickness of commonly purchased lumber.
    I’ve not thought about furring out the back side of the door.......hmmmm
    What could I use (that’s not cost prohibitive) for a 1 inch thick trim? Rip a 2x4?
    #49
    Yinzer Moto likes this.
  10. Xsv
    Sep 11, 2017
    1,227
    Spokane, Washington
    6221ABCF-2B6F-43F0-BEEC-515EAFD8272E.jpeg Geez....I am overthinking this....I just found another option online.
    #50
  11. Yinzer Moto
    Jun 13, 2008
    36,185
    Pittsburgh PA
    That looks nice.
    You could probably attach some door sweep material to the backside of that, where it will not be visible.
    #51
  12. mitchapalooza
    mitchapalooza Rider is Air-cooled Supporter
    Sep 1, 2010
    452
    Castle Rock, CO
    #52
  13. Xsv
    Sep 11, 2017
    1,227
    Spokane, Washington
    Thanks! Hot water and a floor drain......essentials for a home shop!:clap
    #53
  14. Xsv
    Sep 11, 2017
    1,227
    Spokane, Washington
    #54
    rokon140 likes this.
