need help - intermittent starting issues KTM Freeride 350 2012
Discussion in 'The Garage' started by bungle, Apr 23, 2018.
  1. bungle
    bungle Adventurer
    Jul 1, 2007
    17
    Anyone have any experience of starting problems with the Freeride? The bike is harder to start cold but it will start...sometimes. Runs fine once going. Once hot you can shut off to talk to someone mid trail ride and it refuses to restart. I can't work out any other contributing factors. Then only severe repeated bump starting (e.g. bump down a hill, very reluctant to start until eventually it gives in and runs) will get it going. Help appreciated as I don't want to have to take it to a mechanics by numbers garage.
    So far I've:
    - replaced the battery
    - checked all connections in the starter circuit
    - checked valve clearances
    - replaced the spark plug
    - looked for damaged wiring (nothing obvious)
    Over the winter the throttle has begun playing up also. See video for example.
  2. kwb377
    kwb377 It's All In The Reflexes...
    Dec 2, 2012
    726
    B'ham, AL
    The fuel-injected Husabergs (blue KTM's) have a history with fuel pumps and Throttle Position Sensors causing starting/running issues. Might be something to look at...
    spokester and ohgood like this.
  3. YesRush
    YesRush Long timer
    Aug 17, 2014
    2,713
    Va
    Pull your tank side disconnect ,insert fuel pressure guage.Should be about 52 psi.
    Just because you hear the pump it doesn't mean you have pressure .
    Does your throttle body have the pull out hot start choke thing? your high idle sounded like it was pulled out !
  4. Yinzer Moto
    Yinzer Moto Long timer Supporter
    Jun 13, 2008
    32,052
    Pittsburgh PA
    I just replaced my entire wire harness on my Freeride 250 because of wiring failures. I found a wire that was broken under the tank, inside of the loom. I also found a connection on the CDI that was burnt. The CDI was unharmed but the pin on the wire harness was damaged.
    spokester and bungle like this.
  5. bungle
    bungle Adventurer
    Jul 1, 2007
    17
    Thanks, yes it was. The TPS was also off. It's starting more reliably now, but not 100% healthy sounding. I'll try the fuel pressure next.
  6. bungle
    bungle Adventurer
    Jul 1, 2007
    17
    How old is your Freeride 250?
  7. Yinzer Moto
    Jun 13, 2008
    32,052
    Pittsburgh PA
    3.5 years and probably closer to 300 hours than 200.
  8. tread55
    tread55 Adventurer
    Jan 8, 2013
    51
    Greensboro, NC
    You probably already checked for the above issue but thought I'd throw it out there, just in case.
    #8
    spokester likes this.
  9. bungle
    bungle Adventurer
    Jul 1, 2007
    17
    Thanks, yes I've done that one already! Wow 10mins to explain that, now that's thorough video technique :-)
    #9
  10. MJS
    MJS Long timer
    Dec 23, 2005
    2,802
    Off the grid in San Felipe, Baja
    Wife's 350 had starting issues. Could be difficult to start but would then appear to run fine once started. Always started easier with the kick, less voltage drop without the starter. Turned our to be a weak fuel pressure regulator.
    #10
  11. bungle
    bungle Adventurer
    Jul 1, 2007
    17
    That’s what I’m thinking at the moment. Mine is exactly like that, runs fine once going, it’s just getting going that seems to be the difficulty. I changed the in tank fuel filters today with no improvement. I’ve a friend with a tank similar that I’m going to try and plug-in first to test. Did she have to fork out for the whole pump and regulator combo as per the parts microfiche or did she get just the regulator?
    #11
  12. MJS
    MJS Long timer
    Dec 23, 2005
    2,802
    I was pressed for time so dropped it off at ESP suspensions for the diagnosis and fix. So complete KTM replacement pump unit $$$. Which pissed me off as I could of swapped the tank from my 500, figured out the problem and bought just the FPR from ebay or such. Did get the fuel pump assembly back so I have a spare now.
    #12
    bungle likes this.
  13. bungle
    bungle Adventurer
    Jul 1, 2007
    17
    Maybe I'm not searching on fleebay with the correct wording but I can't see many regulator only listings. The £300 full kit is really not filling me with joy!
    #13
  14. MJS
    MJS Long timer
    Dec 23, 2005
    2,802
    Try a Google search for KTM fuel pressure regulator. Lots of results for me.
    #14
  15. woods wizard
    woods wizard Trail Hound
    Mar 15, 2008
    1,239
    Welcome to No.Va...expect delays
    Just in case, don't forget about the filter in the injector inlet.
    #15
  16. bungle
    bungle Adventurer
    Jul 1, 2007
    17
    Thanks. Yes I tried to get it out but it wasn't looking like it would come out without applying too much force. I settled on soaking the whole injector over night in cleaner. Can it be removed without damage? Is it just the same as the inline filter for the fuel hose?
    #16
  17. woods wizard
    Mar 15, 2008
    1,239
    Yes, it should pop right out. It is probably just seated a little tight. No the filters are different .
    #17
  18. bungle
    bungle Adventurer
    Jul 1, 2007
    17
    Do you know if the black plastic cap on top of the filter just pops out by levering the tabs inside with a screwdriver? These are such expensive items I don't want to risk breaking it unnecessarily. I've found replacement filters for this on fleeBay. Thanks.
    #18
  19. woods wizard
    Mar 15, 2008
    1,239
    We are talking about the little cone shaped filter in the injector inlet ? Right ?
    It should come out with a pocket screw driver unless something is different about yours.
    #19
  20. woods wizard
    Mar 15, 2008
    1,239
    #20
