New 2018 750/850GS merged threadfest
Discussion in 'Parallel Universe' started by GS-A-Day, Apr 12, 2017.
  1. proeasy
    proeasy Been here awhile
    Aug 23, 2008
    553
    Motown
    Thanks, just want to post the nagging/nuisance issues, as I tend to be a forgiving consumer many times, but this one needs to be fixed by BMW. The clunking one has me perplexed
  2. heatmizr
    heatmizr n00b-tastic
    Jan 5, 2012
    687
    CLT, NC
    I have some clunking too, but I chalked it up to the center stand banging the frame Or chain slap on swingarm. If that makes you feel better.
    If I ever get to ride again I will try to pinpoint it to be sure.
  3. proeasy
    Aug 23, 2008
    553
    Motown
    Thanks to me it seems the center stand has a minute amount of free play (I would say left to right and visa versa) on the shaft it pivots on,,, it is not the sound of the up and down against the rubber stop. it seems to be stamped assembly with no way to tighten/rmove the free play. Again a budy with a 1250 took it for a 500 yard ride and noticed immediately
  4. DustySprocket
    DustySprocket Adventurer
    Dec 11, 2010
    14
    Pretoria, South Africa
    Fitted the BMW extended brake pedal (as found on the Adventure model).
    On my previous 800's I just bended the lever upward (only to have the dealer bending it back during service) using a set of pliers.
    heatmizr likes this.
  5. heatmizr
    Jan 5, 2012
    687
    CLT, NC
    Hey Dusty - tell them its a MOD !
    Can you say where the Adventure pedal winds up on your bike? How much higher, further in or out, etc?
    Oh nevermind, its adjustable, duh.
  6. sfsmedic
    sfsmedic Been here awhile
    Jun 3, 2019
    108
    Southern California
    Thanks.
  7. sfsmedic
    Jun 3, 2019
    108
    Southern California
    2849 miles on the bike. It’s just at 2 months old. Only ride to and from work mon-Thursday. 41 miles each way.
    I pull into the gas station and smell burning oil. See smoke. And get under it to look.
    Waiting for BMW now.
  8. SnoDrtRider
    SnoDrtRider I've been lost here before...
    Mar 21, 2006
    6,948
    South Jersey... Close to the Pines
    What bike is this?
    It doesn't look like an F750 or F850 because of the location of the oil filter....
    Oh sorry... I didn't realize the photos were from under the bike!
    Looks like the oil filter is leaking?
  9. kingkille82
    kingkille82 Adventurer
    Apr 15, 2016
    20
    Austin, TX
    Check to see if your filter is tight
    Phoenix101 likes this.
  10. Phoenix101
    Phoenix101 Long timer
    Nov 24, 2008
    3,822
    Right Side of WA
    betting the problem is here
    SnoDrtRider likes this.
  11. sfsmedic
    Jun 3, 2019
    108
    Southern California
    I checked the filter by hand it didn’t move. Either way I had bmw pick up the bike and drive me home. Let Warranty take care of it.
    But I do think you’re right. Bike being brand new id rather let them figure it out.
  12. SnoDrtRider
    Mar 21, 2006
    6,948
    The filters are recessed into the cases/frame so far you can't get good enough grip on it by hand to make it tight enough... It may seem tight with your fingertips which is all you can get on the filter but that is not enough.
    My guess is the tech at the dealer never tightened the filter sufficiently because he didn't use a wrench on it.
    I have never in my life seen a filter that is so restricted for access as these are and I have been wrenching on all sorts of vehicles for the better part of 62 years.
    As you said it is on the dealer at this point and be sure the "incident" is documented for future problems if they happen.
  13. AdamChandler
    AdamChandler Ascending n00b Supporter
    Feb 29, 2016
    7,756
    Hanover, NH USA
    Yeah if an oil filter comes from the dealer / factory and does that, let them deal with it. If I do it myself and it leaks, well it's probably my fault :p
  14. sfsmedic
    Jun 3, 2019
    108
    Southern California
    Definitely my thought process. I want this documented. I did check the up level and that was good. So I’m confident no internal damage. But still.
  15. heatmizr
    Jan 5, 2012
    687
    CLT, NC
    You had the 'running-in check' (600 mile service) done at the dealer I assume. Did it get taken to the same dealer now?
    I did my own oil /filter right before my running-in check, maybe I should go check mine.
  16. SnoDrtRider
    Mar 21, 2006
    6,948
    Looking at the second photo it looks like the oil filter seal ring is sticking out a bit which is almost impossible since it is in a recess in the filter. I would say the tech never made sure the old seal was not stuck to the engine and there are two seal rings on there.
    I know the original filter on my bike was a real bear to get off at the first service... I don't think they lube the seal at the factory.
    AdamChandler, morfic and Phoenix101 like this.
  17. sfsmedic
    Jun 3, 2019
    108
    Southern California
    Sadly no. I wanted it to go to my dealership because they are smaller and would have this dealt with faster but the way the bmw roadside assistance works they took it to the nearest bmw dealer. I’m a little worried it won’t be taken care of fast and currently this is my only transportation.
  18. SnoDrtRider
    Mar 21, 2006
    6,948
    Could be better off... A different dealer is more likely to be forthcoming with information if another dealer or tech screwed up. Taking it back to the same dealer gives them the chance to cover for the mistake.
    morfic likes this.
  19. sfsmedic
    Jun 3, 2019
    108
    Southern California
    True.
  20. heatmizr
    Jan 5, 2012
    687
    CLT, NC
    My long-term experience with BMW car dealerships is top-notch. The BMW bike dealer in town here also seems pretty good, I would hope that extends to your case.
    Also give them a ring and in a very nice way let them know that it's you're only transportation. I bet they take care of you.
    (I just had BMW do a $6400 repair on my twin turbo V8, on their dime. Ok it was part of a class action suit, but still..)
    AdamChandler likes this.
