New 950/990 air filtration system development
Discussion in 'Dakar champion (950/990)' started by alongat, Feb 9, 2019.
  1. crazybrit
    crazybrit Long timer
    Mar 16, 2006
    8,888
    Portland, OR
    Thanks. Ok ordered.
    keener likes this.
  2. Mane
    Mane Been here awhile
    Apr 16, 2002
    844
    Guatemala
    Order placed here too, looking forward to it!
    keener likes this.
  3. seralat
    seralat Been here awhile
    Jun 5, 2010
    118
    Berkeley, CA
    I've got mine sitting in the garage, but I don't know when I'm going to be able to install it. So frustrating :~)
  4. GezwindeSpoed
    GezwindeSpoed Long timer
    Jan 15, 2009
    1,014
    The land of the Dutchmen
    After a few rides in the hot European summer the little storage is still in good shape. The black thing is a tube.
    Also found out the carbs were out of balance. Hopefully this will cure the surge at low throttle opening.
  5. alongat
    alongat Fesh Fesh
    Jan 20, 2010
    4,904
    Windsor, United Kingdom
    Are your rubber diaphragms in good condition too? No cracks, etc?
    GezwindeSpoed likes this.
  6. GezwindeSpoed
    Jan 15, 2009
    1,014
    Yes, i checked and cleaned them upon installation of your air filter. They had a lot of Algerian sand around.
    majle and alongat like this.
  7. Bearded Hooligan
    Bearded Hooligan Moto Addict
    Mar 30, 2004
    1,098
    Flat, Hot & Humid South GA
    Finally had a chance to get out and put in a good ride. Mixed paved backroad, dirt, sand, wheelies and even a 100mph blast on the dirt. I got 30mpg. The 690 that was with me, got 55mpg for comparison. This was over 100 mile ride. Did another 125 miles that was much more dirt and deep sand and some interstate. Havent checked that mileage yet, next morning the battery was dead.
  8. gearheadE30
    gearheadE30 @LC8Adventures Supporter
    Jan 20, 2012
    2,159
    Indiana
    For whatever it is worth, my jetting and mileage has been identical to the ITG filter I was running previously. Interestingly, the bike seems to run a hair cooler - the TrailTech gives me radiator temperature in degrees. My only guess is that the smaller form factor of the filter allows a bit more air to flow through the radiator and around the engine. Still heat soaks pretty bad if you go on a rip through the woods, park, and try to restart 10 minutes later, but that is the nature of the beast with these open intakes. Overall though, I am impressed so far. Will be testing dust ability this week at the KTM rally!
  9. Bearded Hooligan
    Mar 30, 2004
    1,098
    I noticed mine running cooler with this filer over the stock and I haven’t even done the lower temp fan switch yet.
    alongat likes this.
  10. GezwindeSpoed
    Jan 15, 2009
    1,014
    When needing to stop at checkpoints during a rally in the sand dunes I left the power on by killing the engine (dumping the clutch) so the fans could continue blowing while no more heat is formed by the engine.
    Have fun on the KTM rally!
  11. Errhead
    Errhead Low Miles!
    May 22, 2011
    110
    Stumptown, Pacific NW
    Has anyone installed this on a 990 adventure converting from the stock system? There is a sensor (income air temp?) that will throw an error code when disconnected from the probe installed in the top of the stock airbox. A mount for the fuse box would need to be fabricated and the large electrical connector at the base of the snorkel would have be mounted somewhere. None of these are particularly difficult but I'm just curious if anyone has done it yet.
    Edit: I read the installation instructions and now see that Alongat has already made an accommodation for the air temperature sensor. Brillant.
    DirtyADV likes this.
  12. alongat
    alongat Fesh Fesh
    Jan 20, 2010
    4,904
    The 990 filter system has provision for the air temperature sensor - you simply bolt it into our baseplate instead of the top of the stock airbox. There will be no error codes, etc.
  13. alongat
    alongat Fesh Fesh
    Jan 20, 2010
    4,904
    And nothing changes with your fusebox and how that mounts...this system literally replaces your airbox but everything around it remains intact.
    mountaincadre likes this.
  14. Errhead
    Errhead Low Miles!
    May 22, 2011
    110
    Got it! Air temp sensor in baseplate, snorkel goes away, fuse box still mounts in glove box lower section, saves 1 hour in valve adjustment as a bonus!
    Ordered!
    syky27 and keener like this.
  15. Bearded Hooligan
    Mar 30, 2004
    1,098
    @alongat received updated parts this morning, thanks for sending those out that is top notch service. Do you have have info or pics on what exactly needs to be replaced? Havent looked at the bike yet since its packed and ready for a long weekend. Heading out Thursday. I hope to be able to swap those parts tonight.
    Mane, gastone and DirtyADV like this.
  16. GezwindeSpoed
    Jan 15, 2009
    1,014
    Did you also receive the mail? I think it is pretty self explanatory if you see the parts.
  17. Bearded Hooligan
    Mar 30, 2004
    1,098
    Yeah, it was. Just was killing time at work. Package was at home and was trying to get a head start before seeing what was in the bag. Took all of 5 minutes to complete and barely even got my hands dirty. :lol3
    alongat likes this.
  18. GezwindeSpoed
    Jan 15, 2009
    1,014
    So you you wore gloves :D
    alongat, Xcelite and Bearded Hooligan like this.
  19. Hydra5
    Hydra5 Adventurer
    Apr 5, 2017
    32
    Hey, not sure if I missed it but, I haven't read anything regarding what the base plate and filter cage are made of.
  20. alongat
    alongat Fesh Fesh
    Jan 20, 2010
    4,904
    Laser cut and cnc aluminum.
