1. ** Enter to win a $250 gift card! We want to hear from you, please take this survey **
    Take this survey which covers a range of questions about improving the community, the things that interest you and anything else you want to share with us. All responses will remain anonymous.
    Click here to take the survey
    Dismiss Notice
New 950/990 air filtration system development
Discussion in 'Dakar champion (950/990)' started by alongat, Feb 9, 2019.
  1. crazybrit
    crazybrit Defying any self identifying Super Moderator
    Mar 16, 2006
    9,502
    Portland, OR
    Uh oh, who blew their motor :D
  2. keener
    keener Speed changes you.
    Feb 24, 2010
    2,255
    Toronto, Canada
    lol I knew someone would say that.
    No one blew their motor. I saw a local buddy's bike who was a bit lazy with the filter changes and since, I've been meaning to post something about it here. Keep calm and do your filter maintenance.
    alongat likes this.
  3. Xcelite
    Xcelite Been here awhile
    Oct 6, 2014
    216
    Corner of No and Where.
    Not sure what's worse, the fact that I've been meaning to clean mine since October, or the fact that I haven't ridden that bike since then. :(
  4. Mane
    Mane Been here awhile
    Apr 16, 2002
    885
    Guatemala
    Hey Keener, thanks for the heads up.
    I've done about 2000km on mine, and the surface it's starting to look a bit dry, but on the inside is still pretty tacky. I wonder if it has to with the kind/brand of filter oil you guys are using.
    Before installing the TripleClamp airfilter and did have a UNI prefilter that will hold its tackiness for a lot longer. The filter oil I was using on the prefilter was Bel Ray.
    Do you thing it could be that or it's the engine induction the suck the oil from the airfilter faster??
    Regards,
    Mane
  5. keener
    Feb 24, 2010
    2,255
    Toronto, Canada
    The oil we use is very similar to Bel Ray. If outside is dry, it's time to change the filter. It doesn't mean you have no protection. The inside layera as you said is still oily. The filter is pretty thick at 14mm and with triple layers too. Each layer gets progressively finner in density. It's thicker than your average dirt bike filter and will last long too. It's pretty much the same as what KTM used on their rally bikes. There a lot of surface for filtration too. This means once it's become harder the pull in air from one area of the filter , air naturally is sucked in from the areas. That's loads of protection for your engine, more than the stock filter and pod filters, etc.
    I didn't want to cause panic:) It's just a note that don't ride the whole season without replacing the filter! Pop the seat every once in a while and see if it's still looks and feels oily. Again it has never been easier to replace the air filter on 990/950 with this system.
    braaap! likes this.
  6. Mane
    Apr 16, 2002
    885
    Guatemala
    Ok, understood. Thanks for the advice.
    Regards,
    Mane
  7. Hydra5
    Hydra5 Adventurer
    Apr 5, 2017
    48
    Hey man, so I've got a little riding time with the new set up and I'm noticing that acceleration seems a tad flat in 1st-3rd(in higher RPM), 4th-6th really seem to pull. I overlooked swapping out the Idle Air Jet to 70, any chance that might have anything to do with that?
  8. keener
    Feb 24, 2010
    2,255
    Toronto, Canada
    Yes that could have an effect. Stock is 50 as far as I remember. It's easily accessible since it's on the top of the carb. Give it a try.
  9. Hydra5
    Hydra5 Adventurer
    Apr 5, 2017
    48
    Right on, thanks Keener
  10. Lav1200
    Lav1200 Pig Pen
    Dec 3, 2004
    1,638
    Calgary, Canada
    Just installed my new Triplemoto air filter system yesterday. Won't have a chance to test it until the white stuff disappears, but I do have a question in the meantime. How tight should the two bolts be to hold the filter in place with adequate pressure to form a seal on the bottom? Is there a guideline around how much they should compress the foam on the bottom to ensure a dust-free seal without either damaging the foam or coming loose?
  11. alongat
    alongat Fesh Fesh
    Jan 20, 2010
    4,994
    Windsor, United Kingdom
    The filter bolts have a “step” built in that protrudes through the filter grommets and bottoms out on the filter cage post itself. Make them nice and tight without going crazy and that’s it
    DirtyADV and braaap! like this.
  12. Lav1200
    Lav1200 Pig Pen
    Dec 3, 2004
    1,638
    Calgary, Canada
    Thanks - that worked well. Looking forward to road-testing this setup soon. The fit and quality of it is superb - well done!
    alongat and braaap! like this.
  13. alongat
    alongat Fesh Fesh
    Jan 20, 2010
    4,994
    Thank you!
  14. DirtyADV
    DirtyADV Long timer
    Jan 13, 2007
    4,437
    SWEDEN, Norsjö
    Guess you sent out the updated parts to all early buyers.
    Have yet to install the filter on one poor 990 that was never even started last summer cause of to much other stuff going on in life right now.
    /Johan
  15. alongat
    alongat Fesh Fesh
    Jan 20, 2010
    4,994
    All filter kit updates were shipped to all buyers. If anyone here did NOT receive their update kit months ago then please contact us at info@tripleclampmoto.com
    mountaincadre, bigborett and DirtyADV like this.
  16. michel3vb
    michel3vb Adventurer
    Sep 29, 2017
    61
    Holland
  17. LilYoda
    LilYoda Been here awhile
    May 20, 2013
    447
    I'm going to try Zuber9 once I get the tripleclamp filter (ordered today)
    But if someone else has a recommendation for a map, I'm interested. 2011 ABS adventure, SAS will be removed, O2 sensors also, and exhaust with no catalizer.
    mountaincadre and keener like this.
  18. skuikka
    skuikka Been here awhile
    Jun 23, 2009
    319
    Finland
    For starters, I must say that I am not a fan of aftermarket filters and I do think the stock airbox in 950/990's is great in it's air filtering purpose, makes power nicely and is quiet.
    That said, I use my SE mostly as an enduro bike. It's dusty as something very dusty sometimes. I used go trough 2-4 stock air filters per year. The bike also needs a bit more maintenance than a bike that is treated like a GS and the f...ing black box is allways on my way.
    I've never even considered a aftermarket filter before seeing this one. I still waited a year to read experiences about it and bought one in the spring. I do like it. Quick change, easy maintence, surprisingly quiet. Engineeringwise, I love the design. No excess parts, simple to manufacture and it works.
    The sound worried me a bit but no problem there. It's a tad louder than stock but does not bother me at all. And I like quiet bikes.
    mountaincadre and Boatman like this.
  19. alongat
    alongat Fesh Fesh
    Jan 20, 2010
    4,994
    Thank you - we really appreciate your support and are thrilled you’re happy
    mountaincadre likes this.
