New 950/990 air filtration system development
Discussion in 'Dakar champion (950/990)' started by alongat, Feb 9, 2019.
  1. nk14zp
    nk14zp Long timer
    Feb 24, 2010
    2,881
    Maine
    After I saw it I decided it wasn't something I wanted to try. Like others I'm not a fan of pod filters. And like alot of people I don't need more HP. Looking forward to seeing something new with us riders and our needs figured in from the start.
    #61
    alongat and Boatman like this.
  2. Boatman
    Boatman Membership has it's privileges ;-) Supporter
    Mar 9, 2005
    14,682
    Mill Spring, NC
    Was it pod filters or a panel filter? I tried pods when I first got an LC8,,,, didn't like the setup. Then fabbed a box that took a panel filter, it went in the trash pretty quick.
    #62
  3. nk14zp
    nk14zp Long timer
    Feb 24, 2010
    2,881
    Maine
    It was a set of stepped oval plates that sandwiched in a filter like most us cars had in the 70s. You know open the hood and it has a wingnut on top of the filter housing. One bottom then filter then top plate with one or two studs holding it together. Not sure how it mounted other than how the plates are with a Rotti etc. I too am not a fan of everything being only supported by the vel stacks.
    #63
  4. nk14zp
    nk14zp Long timer
    Feb 24, 2010
    2,881
    Maine
    It was a crude attempt or hell I don't know it could have been the prototype to the DNA kit. It looked sorta like this but crude with a napa car filter. AK-KT9MK1-S3.jpg
    #64
  5. alongat
    alongat Fesh Fesh
    Jan 20, 2010
    4,987
    Windsor, United Kingdom
    Those look like the motohooligan kits.
    #65
  6. nk14zp
    nk14zp Long timer
    Feb 24, 2010
    2,881
    Maine
    Same idea. I think the date was 06 or so. But that last TBI 08 fucks with my memory....... A LOT. lol.
    #66
    alongat likes this.
  7. Cowtowner
    Cowtowner Been here awhile Supporter
    Dec 21, 2010
    657
    Calgary
    I’m waiting to see this air cleaner.
    I used some of the space where the OEM air box is for my starter relay and a fuse block so am running a foam filter but maintenance is a little painful.
    #67
  8. alongat
    alongat Fesh Fesh
    Jan 20, 2010
    4,987
    Got a photo of where you put those components? Overall footprint of our filter system is smaller than the ITG and it’s biased forward slightly rather than being centred over the length of the carbs / throttle bodies (hint: tall filter body even for the SE) :)
    #68
  9. nk14zp
    nk14zp Long timer
    Feb 24, 2010
    2,881
    Maine
    Will you be offering a "snap out glove box kit" for the ADV?
    #69
  10. alongat
    alongat Fesh Fesh
    Jan 20, 2010
    4,987
    No sir - can’t think of any way to improve on what Rottweiler made for the snap out.
    #70
    nk14zp likes this.
  11. 2 SPOT
    2 SPOT bring the rape whistle
    Dec 14, 2005
    7,055
    Payson AZ
    it just keeps getting better, guessing it wont be ready for sale and shipping before a 9 day trip i'm doin next week, no, i wont put off a ride,, good thing it wont be my last ride:lol3
    #71
  12. alongat
    alongat Fesh Fesh
    Jan 20, 2010
    4,987
    No, sorry - need to wrap up testing and go to production...
    #72
  13. Cowtowner
    Dec 21, 2010
    657
    Calgary
    Here’s a pic. Starter relay is visible on the right. The small fuse box isn’t - it’s in the top frame triangle on the left side - to access it you just cut a zip tie to the frame and pull it out so I need to have the room in front of the air cleaner to access it.
    #73
  14. alongat
    alongat Fesh Fesh
    Jan 20, 2010
    4,987
    No issue at all with where you’ve got them relocated.
    #74
    Cowtowner likes this.
  15. 2 SPOT
    Dec 14, 2005
    7,055
    Payson AZ
    i wasnt being serious about that part:D but i am looking forward to what will be available from ya, and i'm happy guys like you are still interested in developing new hotness for our older girls:ricky
    #75
  16. albani
    albani Been here awhile
    Jan 3, 2017
    237
    SF Bay
    I dig your relay relocation, did you finagle the stock starter cables or did you make new ones?
    I came up with a solution that's 3d printable that reduces the fasteners from twelve to two. (wip so no files yet)
    Paying attention to this thread and very interested in seeing the results.
    #76
    nk14zp likes this.
  17. alongat
    alongat Fesh Fesh
    Jan 20, 2010
    4,987
    Can you share once you’ve got the design?
    #77
    nk14zp likes this.
  18. nk14zp
    nk14zp Long timer
    Feb 24, 2010
    2,881
    Maine
    How about stocking a few for one stop shopping? I'm 67.472% kidding as I have an idea that that is a lot of work for little to negative gain on your end.
    #78
  19. Cowtowner
    Dec 21, 2010
    657
    Calgary
    I made new cables from welding cable as the battery is relocated under the seat where the ABS used to be. IIRC the +ve and -ve cables aren’t any longer than OEM but they are a larger gauge now. Then regulator is behind windscreen on right side where horn used to be.
    #79
  20. FenceJumper09
    FenceJumper09 Been here awhile
    Oct 2, 2014
    554
    Birmingham, AL
    Interested!
    Just purchased a 2011 990 SMR
    Do you think your idea will fit the SMR?
    #80
