New Africa Twin Tubeless
Discussion in 'Land of the Rising Sun: ADV Bikes from Japan' started by lamotovita, Dec 25, 2016.
  1. lamotovita
    lamotovita DAMN SNOWBIRD!
    Oct 5, 2007
    2,743
    WA/AZ, USA
    I'd like to hear from anyone who has converted. Right now that's the only thing between me and a new bike.
    I'm NOT interested in debating tubes vs tubeless, my decades of experience with both systems have taught me what is best for my use.
  2. Swedeonwheels
    Swedeonwheels Adventurer
    Mar 19, 2016
    26
    Västerbotten, Sweden
    not sure if it will fit on the africa twin, but you could take a look at the tubliss system http://nuetech.com/tubliss/
    never heard a bad review so far
  3. swimmer
    swimmer armchair asshole
    Oct 9, 2007
    14,844
    Tucson, AZ
    Many have converted their AT to real tubeless. I don't think the tubliss system offers any advantages on bigger bikes that aren't going to run really low tire pressures.
    For those of you that converted, are you running a TL or TT tire in the front? Seems like the front may be harder to find TL.
  4. lamotovita
    Oct 5, 2007
    2,743
    WA/AZ, USA
    Do you have any links to conversions? There are plenty of tubeless 21" tires available.
    The Tubliss system is not applicable to the rim sizes used on the AT.
  5. swimmer
    Oct 9, 2007
    14,844
    Tucson, AZ
    They are buried in the other AT threads. And really, converting the AT is no different than converting the Tiger 800, etc... Most use Outex kit or 3M (1422?) tape without issue.
  6. TeepS
    TeepS Full Circle Rider
    Feb 17, 2006
    452
    Torrance, CA
  7. lamotovita
    Oct 5, 2007
    2,743
    WA/AZ, USA
    I believe those other bikes use rims with a tubeless, or safety bead, type rims, so the conversion will be quite different. I believe the Africa Twin will require new rims.
  8. lamotovita
    Oct 5, 2007
    2,743
    WA/AZ, USA
    #8
  9. swimmer
    Oct 9, 2007
    14,844
    Tucson, AZ
    Just do a thread specific search in either of the two main AT threads and you find what you are looking for. Tape method has been used with success. Maybe @twinrider will chime in since he has done the Outex kit. The whole safety bead issue has been debated in length in various threads in the Equipment section.
    #9
  10. lamotovita
    Oct 5, 2007
    2,743
    WA/AZ, USA
    That did occur to me, I did not find any useful info other than 23psi was the lowest pressure recommended by the British company that offers a tape\sealant conversion.
    #10
  11. cyclopathic
    cyclopathic Long timer
    Dec 23, 2007
    6,087
    If you wanna hear bad listen to my friend. He loved the system until he took bike to shop and had a mech busting tube while dismounting tires. Second it requires drilling 2nd hole in rim. Not reversible.
    To OP: look at YouTube videos of people sealing rims with tape and marine sealant, works very well and cost <$10 per wheel.
    #11
  12. mcmann
    mcmann Adventure Rider Junkie Supporter
    Nov 17, 2006
    3,971
    Jefferson, GA
  13. twinrider
    twinrider Pass the catnip
    Aug 20, 2002
    16,490
    日本
    #13
  14. lamotovita
    Oct 5, 2007
    2,743
    WA/AZ, USA
    That's good to know, thanks. Do you have any idea how low a pressure is safe? The euro company that sells a similar product says 23psi but I don't know how they arrived at that number, or if it's for the front and\or rear.
    Did you install it yourself? If so was that straightforward?
    #14
  15. mkn
    mkn Been here awhile
    Feb 26, 2012
    218
    Colorado
    I converted with the outex kit did not sand down the spokes just cleaned the rims really good and taped over them. Have about 5,000 miles on it no issues what so ever I have not even put a 1 lbs in the tires in a month and a half. Even with the bike sitting for the last 2 weeks because of snow and a really bad cold snap tires are still holding. Do not let the lack of tubeless keep you from buying. I spent 120 bucks can be done much cheaper btw. I love it. I would not air down to 23 but would think 30 and up would work ok depending on your speed.
    #15
    SmittyBlackstone likes this.
  16. twinrider
    Aug 20, 2002
    16,490
    日本
    I had a dealer do the install. The guy at Outex just warned me not to air down too much because it would increase the chance of dinging the rim but didn't tell me any amount. I don't air down at all on a big heavy bike like this, even with tubes.
    #16
    matt67450 likes this.
  17. lamotovita
    Oct 5, 2007
    2,743
    WA/AZ, USA
    Here in the USA I can't imagine that a dealer would assume the liability of such an installation. I would expect American Honda to take a dim view of it as well.
    #17
    TeepS likes this.
  18. mcmann
    Nov 17, 2006
    3,971
    Jefferson, GA
    #18
  19. lamotovita
    Oct 5, 2007
    2,743
    WA/AZ, USA
    With the Outex kit?
    #19
  20. twinrider
    Aug 20, 2002
    16,490
    日本
    Why? A tube tire can blow out faster than a tubeless tire and the AT has no rim lock on the front to keep the front tire on the rim. So it's not like Honda's solution is any safer than Outex's.
    #20
    Blakebird and sinned like this.
