New Airhead Project
Discussion in 'Airheads' started by guywithchickens, Oct 10, 2017.
  1. fxray
    fxray Long timer
    Feb 22, 2014
    1,474
    Illinois, USA
    Not really, it lives on in pictures. Here's some of the patina I ruined. I can still look at it whenever I want to:
    #81
    tac650 and Jim K in PA like this.
  2. bajaburro
    bajaburro Ancient Adventurer
    Jan 14, 2006
    2,300
    Huntington Beach CA
    It was a joke.
    #82
  3. fxray
    fxray Long timer
    Feb 22, 2014
    1,474
    Illinois, USA
    ^^^Heh! So was my bike. I do like patina, but my R90 had an overdose.
    #83
  4. guywithchickens
    guywithchickens Been here awhile Supporter
    Nov 29, 2016
    981
    Central CT
    Current state below. Working on removing the alternator on the way to removing the engine.
    There seems to be a lot of oil wetting below where the transmission sits. Also the bottom of the transmission was really oily. Is this the sign of a leak?
    Below is a view of some of the rust on the frame. On a side note, the battery box was pretty rusty so I soaked it in Evap-O-Rust for a day. Rust is gone! Pretty amazing.
    #84
    tac650 likes this.
  5. Jim K in PA
    Jim K in PA Long timer Supporter
    Mar 15, 2011
    4,968
    Pocono Mountains, PA
    Trans leak looks like it might be from the shift lever seal.
    Good news is that it kept the rust at bay! :lol3
    #85
  6. Uke
    Uke visualist Super Supporter
    Oct 9, 2013
    4,600
    HouTex USA
    Frame rust as seen is reason enough to move on from a slosh battery to an AGM. Slosh batteries vent acidic fumes, which accelerates rust proximal to the battery tray.
    #86
    WooPig, brittrunyon and fxray like this.
  7. guywithchickens
    Nov 29, 2016
    981
    Central CT
    Detached all of the electrics from the engine. Pulled the stator, but waiting for the special bolt to arrive to pull the rotor. Got the heads and cylinders off. Amazingly easy compared to other bikes. Appears to be a good deal of carbon on the pistons and heads, which surprised me for 11K miles. Maybe ran too rich?
    For the valves, should I:
    A. Leave them alone (easiest)?
    B. Lap them (I have the tools and have done this before, pretty easy)?
    C. Send to machine shop for valve job?
    Also I read about the pulse air system. Seriously considering just eliminating it per Snowbum's instructions. The steel fittings in the heads were not even hand-tight when I took them out (!).
    Left side:
    Right side: IMG_1330.JPG
    #87
    popscycle, fxray and tac650 like this.
  8. Jim K in PA
    Mar 15, 2011
    4,968
    Carbon is not horrible, looks like lots of short trips, which might be consistent with such a low mile bike.
    Dad was not a racer, I am guessin'? :D
    #88
    guywithchickens and fxray like this.
  9. Beemerguru
    Beemerguru Beemerguru...G/S guy
    Nov 7, 2006
    1,918
    Redwood City, CA
    Put the side stand down, remove subframe, and pull the engine. Then front fender, entire brake system, handlebars, top triple, then wheel and forks.
    Post a pic of the flywheel area so we can see if anything is leaking back there. Tranny...usually neutral switch leaking or blow by from a rear main seal leaking...both of which are easy fixes with the right tools.
    R65 has a unique wire harness, engine, exhaust, and luggage racks. All still available. And they're a blast to ride.
    #89
    guywithchickens likes this.
  10. guywithchickens
    Nov 29, 2016
    981
    Central CT
    I flipped through your site. Good info there, thanks. I'll look more closely, but I think I may have an oil pump leak. I'll replace the oil pump seal and the rear main seal. I'm already this far into the motor.
    Not today, though, going skiing!
    #90
  11. fxray
    fxray Long timer
    Feb 22, 2014
    1,474
    Illinois, USA
    Skiing -- Yikes! That's way too dangerous. Save yourself for something safer. You know, like motorcycles.
    #91
    brittrunyon likes this.
  12. guywithchickens
    Nov 29, 2016
    981
    Central CT
    Pulled the motor. Very straightforward. Had to finesse the jack to get the mounting bolts unloaded. It wasn't even that heavy. Looks like my teardown needs to move further forward...
    #92
    tac650 likes this.
  13. guywithchickens
    Nov 29, 2016
    981
    Central CT
    As requested...looks like clutch dust with oil wetting at the bottom. I'm guessing oil pump o-ring?
    #93
    tac650 likes this.
  14. Uke
    Oct 9, 2013
    4,600
    HouTex USA
    Or RMS?
    #94
  15. guywithchickens
    Nov 29, 2016
    981
    Central CT
    Maybe. I'll replace both seals. Time to start reading up on clutch removal and installation...
    #95
  16. guywithchickens
    Nov 29, 2016
    981
    Central CT
    I wear helmets for both! I've been skiing a lot longer than I've been riding, too. They are very complementary. Skiing is good when riding is bad and vice-versa.
    #96
    globalt38, fxray and Uke like this.
  17. guywithchickens
    Nov 29, 2016
    981
    Central CT
    #97
  18. Jim K in PA
    Mar 15, 2011
    4,968
    Looks like all the gaskets but none of the seals. That might be an oil pump cover o-ring in the set. No front cover or rear main seals.
    Call John and ask him. He's pretty helpful.
    #98
  19. Pokie
    Pokie Just plain Pokie.
    Apr 4, 2013
    4,738
    Fort Collins, CO
    It might be the pump o-ring, the rear main seal or/ and the neutral switch in the transmission. Heck, some of the leak may even be the input seal on the transmission. You need to do more investigation before you start ordering parts. From what I see in your photos, some of the leak/ mess may have been caused by the push rod tube seals as well.
    #99
  20. guywithchickens
    Nov 29, 2016
    981
    Central CT
    Xmas is over, time to get back to bikes...
    I spent some quality internet time trying to figure out what came in my gasket set. Below is my annotated version. The red boxes are the one's I'm confused about, but I'll take expert opinion of all of them. Anyone have ideas?
    tac650 likes this.
