new auxillary gas tank
Discussion in 'Hacks' started by draperg1, Feb 20, 2018.
  1. draperg1
    draperg1 PapaBear
    Mar 31, 2013
    318
    Martinsville, VA
    IMG_20180220_122307402.jpg IMG_20180220_122452135_HDR.jpg IMG_20180220_123311282.jpg Ridn3 bought a aux gas tank on line and brought it down to my shop to mount. He got a what I think is a great buy on a 4gal tank with all the fittings but what we felt was a little much on the mount. Have now mounted the tank with a quick release using hitch pins. All that is left to do is run the lines. I'm gonna leave that to him since all the plastic has to be removed so as to get to the gas tank. It came with all the fittings for a gravity feed system. With this and his history of gas mileage he should now be able to get out of the county without stopping for gas!:jack
    phreakingeek, Ridn3, Bobmws and 3 others like this.
  2. Strong Bad
    Strong Bad Former World's Foremost Authority
    Oct 29, 2007
    9,083
    Omicron Persei 8
    Is that a fuel cell, with foam inside a bladder and all?
  3. Bobmws
    Bobmws Curmudgeon At Large
    Jun 6, 2005
    3,105
    Same trailer, different park, FL
    Is that a tip-over vent on top (check valve)? I would remove it and run a vent hose down below the body work. On my cell, theat type of vent wouls allow a bit of gas to escape when the tankk was full.
    Ridn3 likes this.
  4. Ridn3
    Ridn3 Lopsidd
    Feb 18, 2015
    295
    S.W. Virginia
    No. It has foam but no bladder.
    Strong Bad likes this.
  5. Ridn3
    Ridn3 Lopsidd
    Feb 18, 2015
    295
    S.W. Virginia
    Thanks for the info. We were debating whether to use a tip over valve or not. It came with a 1/2- fuel line for a vent. We are going to change that to a 3/8 clear line.
  6. Bobmws
    Jun 6, 2005
    3,105
    As long as it's on the hack, there's no good reason the keep it, unless you anticipate a Drone move.......:-). Although I don't believe he anticipated that either.
    Ridn3 likes this.
  7. Valk rider
    Valk rider Adventurer
    Oct 16, 2016
    77
    Fort Smith, Arkansas
    I have that 4 gallon tank (painted black) also but strapped to a base that mounts to my rear rack with 2 knobs underneath to allow quick removal. I haven't removed it since mounting the hack. Real simple gravity plumbing. I removed the foam that was in it.
  8. Ridn3
    Ridn3 Lopsidd
    Feb 18, 2015
    295
    S.W. Virginia
    This came mounted to a base that supposedly fit an 1150 GS or RT but wouldn't come close to fitting the RT side racks. When I find out what it fits, I'll sell it. We do a lot of traveling so I wanted to keep the tail trunk. Was yours plumbed into the fuel plate under the tank?
    #8
  9. Pokie
    Pokie Just plain Pokie.
    Apr 4, 2013
    3,036
    Fort Collins, CO
    I made about a three gallon tank that I frame mounted on the front. I like riding a bare bike but need a little weight on the front, especially when I hang all my gear on the back. The tank comes off pretty easy as it's held on with rubber straps that hook to the frame.
    #9
    Ridn3 likes this.
  10. Valk rider
    Oct 16, 2016
    77
    I made the base to fit the rack. It's just wood with short wood rails to contain the tank. Straps are polished aluminum. The bike is a 98 Honda Valkyrie BTW so plumbing might be different. But yes, the line from the aux tank runs to a tee under the main tank through a valve to isolate the aux tank. I normally use the aux tank first then turn the main tank petcock to on. Because I'm slightly paranoid about running out of gas I carry a gallon container in the a saddlebag.
    #10
  11. Ridn3
    Ridn3 Lopsidd
    Feb 18, 2015
    295
    S.W. Virginia
    Looks really sharp. We are debating painting it black or putting a duffle bag over it. Do you have the aux tank vented?
    #11
  12. Valk rider
    Oct 16, 2016
    77
    It is vented but just through the tip over valve that came with it. No vent line to under the bike. i like the look of a duffle bag like some of the cylindrical tanks come with.
    #12
  13. Ebayru
    Ebayru Adventurer
    May 13, 2014
    41
    My solution for the lousy gas mileage of my rig. I now have 9 1/2 gal capacity. The 5 1/2 gal tank is only about $40 on eBay.
    #13
    Tracks and Ridn3 like this.
  14. DRONE
    DRONE Dog Chauffeur
    Oct 1, 2007
    7,200
    Chambers Bay, WA
    Wait, Bob, I don't think "a Drone move" is actually a thing. I believe the proper term is "parking in an inverted position."
    #14
    Hi-De-Ho, brstar, Bobmws and 2 others like this.
  15. claude
    claude Sidecar Jockey
    Mar 17, 2002
    5,756
    Middleburg, Pa. (Snyder County)
    #15
    draperg1, Tracks and Hi-De-Ho like this.
  16. brstar
    brstar Long timer
    Aug 17, 2007
    1,309
    Shoalwater Western Australia
    Isn't that just a minor variation on angle parking?
    #16
    Bobmws likes this.
  17. rantingsmith
    rantingsmith Quadrilingual blacksmith seat of pants engineer
    Feb 27, 2017
    247
    UK for now but not from here
    No, it's more like total commitment to the 180 degree wheelie.
    Nothing worth doing is ever easy.
    1983 XV750SE CAFE/BRAT - 1981 TR1.1NCENT PROJECT - 1982 XV750/920 upgrade SIDECAR PROJECT w. WATSONIAN MONACO CHAIR
    #17
    brstar likes this.
  18. Ridn3
    Ridn3 Lopsidd
    Feb 18, 2015
    295
    S.W. Virginia
    #18
  19. Bobmws
    Jun 6, 2005
    3,105
    I'd wager Claude's tank is baffled and/or foam filled. It's not his first rodeo! And the pannier looks to be supported by the sidecar framework. ;)
    #19
    Hi-De-Ho likes this.
  20. Strong Bad
    Oct 29, 2007
    9,083
    Omicron Persei 8
    Gasoline weighs between 6.3 to 6.9lbs/gal so 7.5gal would be just over 47 to just under 52lbs. I agree that it is a pretty good load on the pannier mount, but I did the CDR with a pannier loaded and a 2 gal Rotopax mounted to it with zero ill effects found. The weight is distributed between the Tug and the Tub, not equally but not all on the Tug. I've made plenty of fuel tanks in my day (including 100+ gal tanks for sail boats) and if the baffles are properly made and placed sloshing is not an issue.
    #20
