New Garmin inReach 2017.
Discussion in 'Mapping & Navigation' started by gjn201, Jan 4, 2017.
  1. gjn201
    gjn201 Wannabe Ranulph
    Jan 10, 2016
    151
    Australia
  2. MtnRoamer
    MtnRoamer Been here awhile Supporter
    Dec 16, 2015
    194
    Oregon
    Maybe I am missing something, but the Explorer+ definitely looks a lot more all-in-one than the previous version (I have the previous model). The maps with my inReach Explorer looks like something out of a color version of an eTrex 10, the ones on this newer model look like full topo maps. What more were you looking for out of an all-in-one device? I also don't see any reason you could not brew up a gpx file in Basecamp or load one created from another source. I do this currently with the previous model and the only major limitation is the 500 point limit (but it will take your gpx and convert down to 500 points). Hopefully the new model supports more than 500 points so that is not needed.
  3. gjn201
    Jan 10, 2016
    151
    Australia
    Does it work with basecamp? Doesn't say it does. Can you load other maps (city nav)? Routes made on device?
  4. MtnRoamer
    Dec 16, 2015
    194
    Oregon
    The Explorer model has always supported the GPX format which Basecamp exports and is the preferred format for most off-road nav. Most of the off-road tracks you will find, Backcountry Discovery Routes, etc, will be in GPX format.
  5. krussell
    krussell Gravel Warrior Supporter
    Nov 19, 2009
    3,778
    Portland, Oregon
    In the specs there is a checkmark for 'ability to add maps.' What that really means remains to be seen.
  6. gjn201
    Jan 10, 2016
    151
    Australia
    Ah, that's not how I use my gpsmap 64. I do all my own routes/tracks in Basecamp using the maps on the device.
  7. MtnRoamer
    Dec 16, 2015
    194
    Oregon
    A track does not care what map is used to create it. You can create tracks in Basecamp, upload them to a inReach Explorer device and then navigate with them. I use an eTrex 20x for navigation, but the Explorer is my secondary navigation device and always has the same tracks loaded that my eTrex 20x does when I depart.
  8. markinthailand
    markinthailand Been here awhile
    May 12, 2014
    925
    Chiang Mai, Northern Thailand
    This looks really good. Any idea when they will go on sale? Also, I'm assuming it isn't a touch screen as well as buttons. Is that correct?
    #8
  9. MtnRoamer
    Dec 16, 2015
    194
    Oregon
    Regarding the maps question:
    "²Preloaded DeLorme TOPO maps are not compatible with other Garmin devices. Other Garmin maps not compatible with this device."
    Pulled from (bottom of page):
    https://buy.garmin.com/en-US/US/p/561269/pn/010-01735-10
    #9
    gjn201 likes this.
  10. gjn201
    Jan 10, 2016
    151
    Australia
    Thought as much. So more or less the same thing in a different case. Poo.
    #10
  11. MtnRoamer
    Dec 16, 2015
    194
    Oregon
    Same thing with the addition of Topo maps on device in a new case. Too bad about not being able to load the Garmin maps.
    #11
  12. DRTBYK
    DRTBYK All Things GPS Supporter
    Mar 26, 2003
    7,918
    47°50′15.8″N, 119°56′21.9″W
    They appear to still be Delorme based but with a Garmin familiar body style: i.e, GPSMAP 64.
    PROs:
    • Delorme Map Library is free: for Explorer+
    • Online MapShare is free
    • Ability to upload pre-planned GPX data to MapShare and download to inReach - as with current models.
    • Much better display!
    CONs:
    • Only Delorme Earthmate Map Products - although they are pretty good.
    • No direct support for importing GPX Track data.
    • No on-device auto-Route creation - no routable maps.
    • No removable storage - but then you don't need any given the limited Waypoint and "route(Tracks)" capacity.
    #12
    PoleRbear likes this.
  13. EnduroRdr
    EnduroRdr Woods Racer & D/S Rider
    Feb 15, 2008
    2,544
    Formerly BR-LA, LR-AR, Houston-Tx, now South MS
    If Garmin advances this to the point it works like my 60CSX, then I would consider upgrading for "all in one" at $499. But till then it's not worth the extra expense. I'll keep my spot subscription for satellite com and 60CSX for nav.
    #13
    Woody2627 likes this.
  14. jojojones
    jojojones Been here awhile
    Jul 21, 2016
    589
    Northeast
    I guess this is a bit of a punt on garmin's part. Did I read this wrong???...this can't import a gpx track? I thought the previous explorer did? I would buy the previous one and live without the better maps in order to follow a track as a back up to osmand and emergency comms....or can you take a gpx track and convert it using maybe gpsbabel to a format that works on this with track navigation?
    #14
  15. jonz
    jonz Miles are my mantra Supporter
    Aug 16, 2004
    4,919
    CA dez (it's a dry heat)/West Yellowstone,MT
    What is the difference between pre-planned GPX data (can be uploaded) and GPX Track data (no support for importing). What is the difference between uploading and importing?
    #15
  16. DRTBYK
    Mar 26, 2003
    7,918
    You cannot directly Import the GPX file into the device or the Earthmate App: e.g, you cannot connect the device to your computer and copy a GPX file directly to the device - as you can with other Garmin devices. You must Upload the GPX data to your MapShare web account and then Sync (download) that data with the device and/or Earthmate App over the internet.
    #16
  17. jonz
    Aug 16, 2004
    4,919
    Ahhhh, thanks for that explanation. More convoluted than I'd like but I could make it work. On Garmin's Facebook page, I asked when it would be available for sale and they wrote there was no release date yet and to sign up for an email notification.
    #17
  18. jojojones
    Jul 21, 2016
    589
    Northeast
    so "in theory" it can follow a gpx track with this extra step and have the same basic functionality as a dedicated gps...thanks!
    #18
  19. Tewster2
    Tewster2 Long timer Supporter
    Jun 17, 2011
    7,344
    DeLand Flatistan
    Just looked at the Garmin site....price went up to $399 to $450...plus subscription...I think I'll pass :dirtdog
    #19
  20. MtnRoamer
    Dec 16, 2015
    194
    Oregon
    You can pick up a used previous gen Explorer for like $250 on eBay (exactly what I did last year). You can pay a small yearly fee to turn the service off and on at will (you will of course pay the normal monthly fee for your chosen plan when it is on). Unless all you need is a PLB all of these types of devices have a service fee. Your needs may be different, but if no devices existed in the used market and I had to do it again I would still buy the Explorer without hesitation.
    #20
