New Garmin Zumo 396
Discussion in 'GPS 101 - Which GPS For Me' started by StuartV, Apr 11, 2018.
  1. ohgood
    Sep 21, 2010
    9,905
    alabama
    Toss the old Garmin, and use the phone. no more Bluetooth, routing, recalculating, track to long, etc issues
    scootertrog likes this.
  2. scootertrog
    scootertrog Jedi Fart Master
    Mar 26, 2011
    1,131
    Missouri USA
    And no wiring mess!
  3. 2WheelieADV
    2WheelieADV Long timer
    Sep 30, 2010
    1,143
    NJ, USA
    I've tried to use the phone but for various reasons it's not the same as a dedicated unit.
  4. HarveyM
    HarveyM Been here awhile
    Sep 10, 2010
    668
    Ottawa, Canada
    You might want to ask on the Zumo users forum: https://www.zumouserforums.co.uk/
  5. GreatWhiteNorth
    GreatWhiteNorth Long timer
    Dec 2, 2009
    5,415
    Winterpeg - site of flatness beyond belief
    Anyone experience problems updating the operating system software AND maps? I bought a new 396 from gpscity.ca on-line - had it in my hands in less than 24 hours from the time I placed the order! I've got 3 other Garmin units, two Nuvis and a GPSMAP64, so pretty familiar with updating and transferring files. I wanted this motorcycle specific unit for its waterproofness, compatibility with topo maps, and the ability to display an imported track line. I did the normal plug it in to my (Windows 10) laptop, registered the device, and used Garmin Express to proceed with updates. The operating system update hung up, so I disconnected, tried again, same thing. After several attempts, I connected directly to router via Wi-Fi, and it updated the operating system, but said go back to PC map update using Garmin Express! So I did that, got 30% thru the map updates (Canada & US City Navigator) and it froze again. I disconnected and reconnected several times, just couldn't get any file transfer progress, even letting it sit connected overnight! With nothing to lose I tried another Wi-Fi update... and it worked! Quirky glitchy shouldn't be happening stuff.
    Other than that, the unit itself seems to be operating fine now.
  6. bross
    bross Where we riding to? Supporter
    Nov 10, 2005
    6,854
    Osoyoos, BC
    Hope you're crossing the border to use your topo maps. The only Zumo that supports the topo Canada maps is the 665. I haven't had any problems updating my 396 and just did the latest firmware and map update through the device itself, while plugged into a usb charger, worked fine and was pretty quick but we have fibre internet to the house.
    GreatWhiteNorth likes this.
  7. GreatWhiteNorth
    Dec 2, 2009
    5,415
    I had no problem installing the Topo Canada maps, and they enabled fine - disable City Navigator, enable Topo... I have an unlocked DVD tho... snagged one at MEC before they stopped selling 'em.
  8. bross
    Nov 10, 2005
    6,854
    Osoyoos, BC
    Interesting, I actually bought a download Topo Canada to install on my 660 and it wouldn't install or enable. Called Garmin and they said the 660 wasn't supported and allowed me to return it. Maybe your DVD copy is the key, glad it works for you.
  9. GreatWhiteNorth
    Dec 2, 2009
    5,415
    Hey Bross, that's interesting. I notice that there are a lot of Garmin units that aren't topo map compatible, or have "limited" topo map support (won't display properly), but the 396 is topo map compatible, why I bought it actually. I found this on-line, at gpscity:
    The Garmin Topo US 24K maps are listed on Garmin's website for the Zumo 396 LMT-S
    https://buy.garmin.com/en-US/US/p/610131/pn/010-02019-00#maps
    The Garmin Topo 24K maps can be found at GPSCity at the following link.
    https://www.gpscity.com/search/q=24k
    When using 2 different map products that overlap in coverage area (City Navigator NT North America an Topo 24K maps), it is recommended to only enable 1 map at a time in the map settings.
    Edit - I found this additional information HERE: "While the zumo devices are compatible with TOPO mapping products (with the exception of European TOPO mapping), they were not designed for optimized use together. For this reason, the zumo may not display as much TOPO detail as an outdoor device would."
  10. bross
    Nov 10, 2005
    6,854
    Osoyoos, BC
    I have the Topo 24K for Western US for when we go south installed on my 660 as that was the unit I owned at the time and usually the one I have mounted on my DR650, we take our DRs when we go south. Don't do a ton of actual trail riding down south but wanted the topo just in case we saw a dirt road that we wanted to follow.
    I had bought the US topo map and installed successfully so I didn't even check to see if the Canada topo was supported??? Why does the US map work but not the Canada map???
    I've kinda moved on from Garmin and actually my Delorme PN-60W as my outdoor gps. I was looking at handhelds when I stumbled on a phone app called Gaia gps. Installed that on my iphone and won't be looking for another handheld gps, this app works so well and is way cheaper than spending $300 on topo maps and $$$$ on another handheld gps.
  11. GreatWhiteNorth
    Dec 2, 2009
    5,415
    Bross, supposedly these Backroad Mapbook maps, preloaded on microSD cards work well - they are expensive tho:
    https://www.backroadmapbooks.com/gps-maps
  12. bross
    Nov 10, 2005
    6,854
    Osoyoos, BC
    I have access to those on that Gaia gps app.
  13. commando57
    commando57 n00b
    Apr 10, 2018
    1
    central Virginia
    How do I reset fuel range if the box doesn't pop up?
  14. randingo
    randingo Voted "Class Lounger"
    Aug 24, 2015
    707
    The dog house
    Another significant issue in using the TOPO with the 396 is that you cannot simply toggle between topo or city map like you can on handhelds. That’s a royal PITA went you are in the middle of nowhere and are trying to figure different ways to get from your current location to somewhere out in the boondocks where you’ve never been before.
    FYI, you cannot display both city map and topo at the same time on the 396.
  15. GreatWhiteNorth
    Dec 2, 2009
    5,415
    I've not even taken my unit out on the road yet, just playing with it in the house... I just turned the unit on, checked map settings, found no maps enabled!? Yet it displayed the streets in our neighborhood OK, so that's gotta be City Navigator (you'd think). I enabled Topo Canada maps again, ensuring City Navigator & Foursquare were disabled, worked fine. Maybe it defaults back to City Navigator or something? Quirky device.
  16. randingo
    Aug 24, 2015
    707
    The dog house
    When I bought the 396 from Tourtech, I took the salesman's word that it would do what I was wanting to do, over a Montana, at face value. I wanted a unit primarily for off road use.
    After digging into the workings of the 396 (many hours) and comparing it to a friends Montana, I have determined the Montana is FAR better for off road use, resulting in me sending the 396 back. I am looking forward to getting a Montana and loading City Navigator on it.
    In many cases, I think the 396 would work better for street riders, but it still has what I consider user interface issues. Ultimately, the deal breaker for me was finding out the 396 will not display highway names to the level of a Montana when both are running in City Navigator mode. At first I thought it was just me not knowing how to set it up, but Garmin tech support walked through it with me and determined the same thing. I knew I was going into uncharted water in determining if the 396 was the new cost effective offroad unit, so I just chalk it up to a learning process.
  17. CavReconSGT
    CavReconSGT Just the right amount of evil.
    Jul 7, 2011
    1,440
    CT/NH
    I have both. I purchased the 396 for overland travel in less isolated areas than I was in when doing the North road and trips to James bay and the trans-Lab highway etc. I loved the 600 for those trips. The 396 seems, so far, very well suited for use on the highways and byways I will be taking from CT to Deadhorse and Tuk this spring/summer. I use to add many of the Topos to the 600, something I will not likely be doing on the 396. The advantage for me on the 396 is the built in bluetooth support. Something I had to rig to have that ability on my 600. I like the connection to the phone which will be a nice addition on the upcoming trip in areas with cell data coverage. I have added the OSM map sets to the 396 just like I had done with the 600 and they seem to run fine for me. The two Garmin base mapsets seems to have most everything I need but I just wanted to try them out and they seem fine to me. Road detail seems fine to me also. Going through the most obvious, you do have the map detail setting set to the highest setting correct? Also changing the zoom so it might be different than the 600, does that make any difference in the road names? I'm sure you have probably tried this also but I just thought I would mention it. I consider them two different animals. I love the 600 and will not sell (unless I come across a cheap 680) it but I think for the upcoming trip the 396 is actually going to be a better unit for me.
    KR
    randingo likes this.
  18. randingo
    Aug 24, 2015
    707
    The dog house
    Yeah, those were the first 2 things I checked
    CavReconSGT likes this.
  19. trumpet
    trumpet Group W Bench
    Aug 2, 2008
    3,428
    Connecticut
    Just a FYI, if you've just unboxed your garmin and the recurring login/language screens are annoying, take it for a quick drive around the block once it acquires the satellites.
    Mine was pissing me off as it wouldn't 'stick', did what garmin suggested and the issue cleared. Just wanted to share.
    Also found that the smartphone comm app is annoying as hell. Constantly beeps and dings. Worst thing is there is no 'off' for it other than uninstalling it when not in use. Otherwise it is on all the time and being a draw on your smartphones battery.
  20. lkraus
    lkraus Long timer
    Dec 15, 2012
    1,380
    Central Ohio
    I agree that Smartphone Link needs to allow more control of the functions. I don't really need small-craft weather warnings when I'm near the ocean.
    You can keep the app from running if you don't need it, without uninstalling. Tap the settings "gear" on the upper right, under Battery Usage, select Settings - Optimize battery performance, then uncheck Bluetooth Auto-Connect. Start the app manually when you will need it, or reactivate Auto-Connect when you will be using the Garmin more intensively.
