1. eNewsletter Sign Up
New Garmin Zumo 396
Discussion in 'GPS 101 - Which GPS For Me' started by StuartV, Apr 11, 2018.
  1. Oilhed
    Oilhed MarkF Supporter
    Oct 17, 2003
    13,412
    Connecticut
    Thank you. It looks like it’s the same mount but the cases are different. The mount if vertical on one and horizontal on the other.
  2. MoikonaBoik
    MoikonaBoik Imagining whirled peas
    Aug 3, 2017
    41
    San Francisco Bay Area
    Garmin Zumo 396. Worst product in the history of bad products. I've had this piece of crap product fail to operate on half a dozen weekend trips now for one reason or another.
    - Defective charge cable - mail back (at my cost), replace
    - Defective GPS unit - mail back (at my cost) and replace
    - Battery runs flat, fast, while unit is turned off. Charging round-the-clock is mandatory to keep the unit usable. What engineer designed this product to run the battery down while it's turned off?
    But let's not drone on about the hardware. Let's talk about the software. On second thoughts let's not. I would not want this to turn into a rant.
    pidjones likes this.
  3. Amphib
    Amphib A mind is like a parachute....
    Sep 19, 2018
    2,894
    Wnc
    That really sucks. I'm having the exact opposite experience. Got mine a few weeks ago and absolutely love it. I hope you can find a way to make it right. Powered off, battery lasts a long long time. (long press, confirm off).. Short press it just sleeps and battery will drain. Charging while sleeping on the cable is a little long, but in cradle, it charges quickly.
    Where'd you buy it?
    CavReconSGT likes this.
  4. bross
    bross Where we riding to? Supporter
    Nov 10, 2005
    6,803
    Osoyoos, BC
    Mines been trouble free as well at least on our 2 week trip to Utah and back from Canada.
  5. MoikonaBoik
    Aug 3, 2017
    41
  6. Gusfuhrer
    Gusfuhrer n00b
    Apr 14, 2019
    8
    Tennessee
    Just purchased a 396 lmt-s a week ago. Been raining here since so just quick rides to make sure mounting and wiring were good. This is on my KLR also mounted a charging phone cradle for times I might need to use my old phone for a map app. C15B1C32-A161-49B1-A34D-EADF3CE5D043.jpeg
    WalterMitty2 likes this.
  7. WalterMitty2
    WalterMitty2 Been here awhile
    Sep 11, 2019
    150
    Chicagoland Area
    Looks great mounted to the crossbar. I'm thinking of maybe doing the exact same thing if I go with the 396 lmt-s.
    Question, were you able to mount it just as you have it with everything that came in the box, or did you have to purchase any other mounting hardware?
  8. Gusfuhrer
    Gusfuhrer n00b
    Apr 14, 2019
    8
    Tennessee
    Every thing you need to mount it like this was in the box. It’s very stable where it is.
  9. WalterMitty2
    Sep 11, 2019
    150
    Chicagoland Area
    Another question, how are you going to be "connecting" to the 396? Will you be just be viewing, or also listening? If listening, how?
  10. Gusfuhrer
    Gusfuhrer n00b
    Apr 14, 2019
    8
    Tennessee
    I have synced my iPhone and Sena SMH10 to it and all is working pretty good. One complaint I have is the volume when I receive a call is a little lower than the music being played. I need to play with the settings and see if an improvement can be made. If not I will just not sync to it .
  11. WalterMitty2
    Sep 11, 2019
    150
    Chicagoland Area
    How is the Sena powered? Do you just charge it a night (for multi day rides)? And if it is running only off it's own battery, how long will it last?
    Just trying to decided if I need yet another charging point on my small bike.
    Sorry for the all the questions.
  12. Brutalguyracing
    Brutalguyracing Long timer
    May 15, 2013
    3,285
    Long Island New York
    Yes senator system charges by itself
    Can be removed from helmet
    Mine is 4-5 years old and I use it daily year round and battery life is still excellent
  13. Gusfuhrer
    Gusfuhrer n00b
    Apr 14, 2019
    8
    Tennessee
    I get a full day ride from a charge. I have the dash lower to charge it when low. Doesn’t really pull much from battery.
  14. WalterMitty2
    Sep 11, 2019
    150
    Chicagoland Area
    I assume you meant "dash power". What does it need for charging? USB port, or 12v "hole"?
  15. lkraus
    lkraus Long timer
    Dec 15, 2012
    1,291
    Central Ohio
    Try adjusting the volume while on a call. The SMH10 maintains individual volume levels for each source. GPS volume is different from music which is different than calls. The GPS directions can be difficult to set to the desired level as they are often very short.
    Gusfuhrer likes this.
  16. Gusfuhrer
    Gusfuhrer n00b
    Apr 14, 2019
    8
    Tennessee
    I use USB. I know some have a 12 volt hole and use adapter.
  17. bross
    Nov 10, 2005
    6,803
    Osoyoos, BC
    You shouldn't need to charge an intercom from the bike, my wife and I have been using Scala Riders for years (10+), and I just charge them at night along with our phones etc. while on multi day trips. A few times on overseas trips when I couldn't charge them overnight they still had enough battery for 2 days on the bikes. Really depends on how they're being used though Talk Time vs stand by mode. Neither of us listen to music, only for chatting etc. so we probably get longer battery life than if it's "powered on" all the time.
  18. Gusfuhrer
    Gusfuhrer n00b
    Apr 14, 2019
    8
    Tennessee
    Your right, I have never needed to charge my headset while riding if I start with a full charge. . I have had to use the lower dash outlet to charge it when camping or I didn’t have a full charge and on
    a long ride.
  19. Manray
    Manray Killing Time
    Jun 24, 2011
    473
    North America
    I've had the same experience. The problem with the Zumo39X series is the charging cable interface. 2 pins for power. If you have a bike that vibrates a lot where the GPS is mounted, the connection will eventually fail. This could happen in 2 rides or 100 rides. The only solution besides tossing the unit is to get a vibration isolator like the ones Touratech make:
    https://touratech-usa.com/store/Touratech-Motorcycle-Locking-GPS-Mount-Garmin-Zumo-396-LMT-S
    It's an expensive solution but considering how much replacement charging cables are and the inconvenience, it's worth considering. For me, since using the mount, zero issues. This is with the same bike and mounting GPS in same location. If you are thinking the Zumo 59X series using 18 pins for connection is more robust and less prone to the vibration/connection issues, think again. The same issues above also surface for motorcycles that vibrate much.
  20. GearHd6
    GearHd6 Been here awhile
    Aug 2, 2009
    347
    Ashford, CT
    Is there a way to show a colored line on the main map screen of where I've already been? My old Montana would draw a colored line on all the roads I had already traveled on during my ride. I can't seem to make that happen with the 396.
