New GSA and CB Radio Question
Discussion in 'GS Boxers' started by BoxRunner, Aug 28, 2009.
  1. BoxRunner
    BoxRunner n00b
    Aug 18, 2009
    4
    Hello all, Just picked up my 09 GSA a few weeks ago an love this bike. I have owned several bikes over the years and most recently have been riding LT's and Goldwings but I am planning a trip to the Arctic Circle next year and decided this was the bike! The guys I am going to ride with all have CB's and after attempting to use the search engine I have not been able to find anything on this site so was wondering if anyone has mounted a BMW CB or the J&M unit (same thing I believe) on a GSA? Any help on this would be appreciated. Of course I am sure I will hear a bit about why put a CB on one of these bikes too! Thanks!
    P.S. If there is anyone near me in SC that may be interested in this trip please contact me as I am the only person from SC who is going thus far.
  2. npmako
    npmako John Mako
    Mar 22, 2009
    48
    Ohio!
    are you wanting to use this with an in-helmet com setup?
  3. ubaath
    ubaath Adventurer
    Jun 5, 2007
    96
    Helsinki, Finland
    I use an Alan/Midland 42 handheld CB with a BPA-100 Bluetooth PTT switch in conjunction with a Scala Rider headset.
    The CB radio resides in the topbox, and is draws battery power through a relay.
    It is connected to an external no-groundplane whip antenna which attaches to one of the luggage rack rails.
    This setup works fairly well, although it doesn't get the range that the Goldwing CB setup does.
  4. BoxRunner
    BoxRunner n00b
    Aug 18, 2009
    4
    Thank you for the reply, yes I would like to use an in-helmet setup.
  5. rob
    rob Been here awhile Supporter
    Jun 24, 2002
    405
    Arma, KS, USA
    While I have a GS w/ABS, I have the J&M system on it. The hardest thing was the mount for the head unit. Once I got that, easy peasy. I've got my Zumo 550 with the XM, blue tooth phone hook up, V-1 all piped into my J&M headset.
    I recommend the system.
  6. MLS2GO
    MLS2GO Adventurer Supporter
    Mar 26, 2008
    90
    Village of Loch Lloyd MO
  7. GARider
    GARider Wandering Thru Life
    Sep 8, 2004
    239
    Kennesaw Ga.
    I have a 07 GSA and have the J&M unit on mine, it works great. Have my Zumo with XM running through it. It also has intercom if you ride two up.
    I tried other systems with hand held CB radios and it just didn't work. I guess CB's are not big on the other side of the pond.
    Roger
  8. BoxRunner
    BoxRunner n00b
    Aug 18, 2009
    4
    Thanks everyone for the feedback...for those of you with the J&M units which antenna length did you choose and how is the range on it? Thanks again!
    #8
  9. chromedome
    chromedome Been here awhile
    Mar 25, 2005
    137
    Bryan, Texas
    '09 GSA here, also running the Midland hand-held CB into my StarCom intercom unit. I mounted the CB on the side of my topbox in place of a water/fuel bottle in the TT bottle bracket I screwed on there... The antenna sticks up a little over the top of the box that way. I hard-wired a 12v line to power the radio.
    I've had no problem with noise/interference and the range is plenty good to cover a couple of miles between bikes.
    #9
  10. james996
    james996 Been here awhile
    Nov 5, 2005
    229
    Brooklyn
    I put the firefly antenna on using the licenese bracket mount. Works great. Not sure on the range but I would guess transmits 3 -7 miles. Receives twice that. I have the 2003 model on a 07 GSA 1200. Works great.. I can post some pic 's if you would like..
    #10
  11. rob
    Jun 24, 2002
    405
    Arma, KS, USA
    Mine has the the four foot firestick (sp?) with the license plate mount. Transmitting, line of sight, maybe 5 miles. Reception? 10??
    #11
  12. BoxRunner
    BoxRunner n00b
    Aug 18, 2009
    4
    Excellent, thanks everyone...and yes James996 if you don't mind posting some pics that would be great...
    #12
  13. james996
    Nov 5, 2005
    229
    Brooklyn
    I'll try to post some pics tm when I get home from work..
    #13
  14. rdwalker
    rdwalker Long timer Supporter
    Jan 3, 2005
    2,628
    The Badlands (of NJ)
    Another vote for J&M.
    I use the J&M Integratr IV, residing in my GS tank bag. It integrates (as the name implies) all kinds of audio sources. In my case:
    - Motorola FRS radio
    - Garmin GPS
    - Sirius sat radio
    - switchable with Sirius: aux audio from an MP3 player on a separate cable
    - modded Escort radar detector.
    - Motorola HF-820 (?) Bluetooth adapter for mobile phone.
    My main reason for the setup is that it mirrors my BMW ComSystem (nee J&M) on the K12LT - thus I can use the same cables and the same helmet speakers.
    Here is an important fact I found: only J&M, from the 3 or 4 other brands I tried, puts enough volume into the helmet speakers to get by earplugs.
    I always ride with plugs and only J&M can be readily heard, even with volume not fully cranked up. Other brands required that I give up plugs - not happening.
    Another comment: are you sure about the need for CB? I found that it is past prime time, only wacko lewd self-involved truck drivers persist on it. Nothing useful. Cell phone, now, that is a different idea to be in touch. FRS radio works for a ride with friends - very well.
    #14
