new Klim Carlsbad jacket
Discussion in 'Equipment' started by motoinmoab, Feb 10, 2020.
  1. motoinmoab
    motoinmoab Questioning Reality Supporter
    Jul 2, 2011
    151
    Carefree, AZ
    I just got the new for 2020 Klim Carlsbad jacket. I have an older Carlsbad that I've grabbed whenever the weather is cold or the sky's threatening. It's a very good coat. But there are some features to the new one that make it a much better coat, IMO. They fixed all of my complaints.
    Many reviewers have complained about the collar. Me too. The new collar works perfectly. For me. ::YMMV:: I suggest you check it out if you're interested because it fits very differently. It seals around my neck better when I want it to, and it doesn't stab me in the neck when it's opened up a bit.
    The vent zippers are much better. They've used waterproof zippers instead of having flaps over the old style zips. Those flaps restricted the air flow thru the openings quite a bit. These new openings aren't huge, they don't spread themselves wide open, but they flow air much better. Like the old coat, you can reach all front and back vent's zips easily, without needing to stop and take the coat off. And the vents on the sleeves work WAAAY better! The 2 way zips open from the elbow down to the cuff, or up from the cuff to your elbow. They open wide!!!
    One more big difference- both my old Carlsbad and my new one are size MED. The new one is cut much looser. I would say it's almost 1/2 size larger. It's a generous fit, much more comfortable than my old one. I think they cut it bigger because of the change from Level 1 D30 armor to Level 2 throughout.
    Check one out, it's a very different coat, significant improvements. But before you ride with it, make sure you do the standard Klim break-in proceedure: pull out the armor and throw it in the dryer (on air only) with a couple tennis shoes. For an hour. Or longer.
    Rock709, Red liner, Ocho NA and 2 others like this.
  2. keiji
    keiji Long timer
    Jun 19, 2008
    1,229
    Is the fabric behind the arm zips also a part of the gore laminateor otherwise sealed? I really want to like those vents, but I used to have a Firstgear Rainier with that zipper arrangement....and I always got wet. The zippers would always pucker a little bit and leak in a heavy rain, and the fabric behind it would wick the moisture all over my shirt.
    Not sure if the pictures of the 'pre production' ones line up with the actual ones they're selling now.
  3. eddyturn
    eddyturn Eternal Wannabe Supporter
    Oct 27, 2009
    3,256
    Hesperus, CO
    Thanks for the info on the new stuff. Looks to me like it’s really shiny material and maybe kind of krinkly???
  4. motoinmoab
    Jul 2, 2011
    151
    Carefree, AZ
    I pulled the armor out and threw the coat in the dryer for an hour, on no heat. Also tossed in a couple shoes to beat it up. That was enough to give it a nice softening. That's standard for all of the Klim clothing I've bought.
    sirvelo likes this.
  5. blackfriar
    blackfriar Been here awhile
    Dec 10, 2010
    407
    Wisconsin
    I have seen that some Carlsbad jackets are called the 2018 Carlsbad. Are you saying that the one you bought is new and the 2018 is referred to as the "old" Carlsbad jacket?
  6. cblais19
    cblais19 Long timer
    Nov 3, 2017
    2,455
    VA
    There’s a brand new 2020 Carlsbad.
  7. Rock709
    Rock709 Been here awhile
    Jun 20, 2012
    413
    Newfoundland, Canada
    Yup. And price increase too.
  8. Fast1
    Fast1 Twisted Throttle
    Aug 18, 2007
    3,590
    Bridge over Troubled Water
    How does the armor fit your body in the shoulders and elbows in comparison? 2020 to pre-version..
    I noticed the pre-version was not a good fit for my shoulder structure..
    Where do you notice that the jacket is larger in fit on the 2020? shoulders? arms? body? waist?
    #8
  9. sirvelo
    sirvelo Miles to go before I sleep Supporter
    Oct 25, 2019
    50
    Calgary
    Hmm bought the new Klim 2020 Carlsbad Jacket and pants. I have worn a Rukka Gortex set for 8 years and was ready for a change. I did notice how stiff and crinkly sounding the Klim set was and wondered about that. I'll try your suggestion for an air dryer tumble with some tennis shoes - and pray everything holds together. I'll just put in mine and wait on throwing my wife's new Klim Artemis jacket and pants in as well. I can deal with my sorrow but not her wrath.
    #9
  10. sirvelo
    Oct 25, 2019
    50
    Calgary
    Sizing on new Klim 2020 Carlsbad is generous. I am 6 ft tall (183 cm) and 210 llbs (95.2 kg). I normally wear an XL in moto wear jackets but the Large size was perfect. I was swimming in the XL - way too big. The pants fit true to jean waist size (36).
    #10
  11. cwadej
    cwadej Keeper of the truth
    May 20, 2008
    1,546
    San Diego, CA
    After looking and trying on, I'm about ready to buy a Carlsbad jacket. Is there any way to beat the $599 price tag?
    #11
  12. sirvelo
    Oct 25, 2019
    50
    Calgary
    I found the same price everywhere I looked either direct from Klim or a reseller.
    #12
    Rock709 likes this.
  13. MotorcycleWriter
    MotorcycleWriter Vis ad locum
    Dec 1, 2012
    2,795
    $$$ Valley, Utah
    Wha???
    #13
  14. wagley
    wagley Adventurer
    Jul 20, 2018
    48
    Florida
    They offer a military discount if you contact them.
    #14
