New Long Range LED Aux Lights
Discussion in 'Vendors' started by Off Road Ryder, Nov 5, 2012.
  1. gsuks
    gsuks Long timer
    Oct 13, 2014
    1,600
    wilnis de ronde venen nederland
    now I am confused
    are there 2 sets of new lights
    as you mention 2 inch light with or without DRL
    and also mention Aurora with DRL ( Amber Halo)
    are all the pictures + the Facebook link
    the same lights?
    I thought they were.
    the multi function turn signals do they work without the raider? on the 790
    https://m.facebook.com/story.php?story_fbid=1504289443046814&id=170252996450472 FB_IMG_1574796476861.jpg FB_IMG_1574796557067.jpg FB_IMG_1574438993156.jpg FB_IMG_1574438985374.jpg
    Off Road Ryder likes this.
  2. Off Road Ryder
    Off Road Ryder Long timer
    Mar 29, 2010
    3,938
    Kent Wa
    Yes there are two new 2 inch lights coming out. They are called the Aurora's one with the DRL as shown in the photos and the same 2 inch light without the DRL option. Most photos have been the DRL version, although I do know we took some of the non DRL version.
    The 790 will not require the raider box or any other canbus controller to run anything.. MF turn signals work with no mods or extras as do Aux lights. We will be doing an special on the new lights once we have all on the site etc..
  3. George Hanson
    George Hanson Been here awhile
    Feb 4, 2016
    936
    PA
    So no Black Friday sale?
  4. gsuks
    gsuks Long timer
    Oct 13, 2014
    1,600
    brilliant
    thanks for clearing that up
    I was just thinking
    the mounting bracket that you use for the high position lights that I posted
    the lights are on top
    is it possible to attach the lights to the bottom of the bracket, or will the catch on something?
    would they then as low as the other brackets? FB_IMG_1574895494151.jpg FB_IMG_1574895494151.jpg FB_IMG_1574895360871.jpg
  5. twotyred
    twotyred Practising Recedivist
    Feb 9, 2006
    5,380
    Bruthen Victoria
    I look forward to purchasing a DRL set in the very near future!!!
  6. ebrew
    ebrew Motorcycle A.D.D.
    Nov 4, 2005
    2,156
    Denver colo
    Watching the website for the new DRL lights
    Off Road Ryder and twotyred like this.
  7. ebrew
    Nov 4, 2005
    2,156
    Denver colo
    No sale ?
  8. LarryGS
    LarryGS Long timer Supporter
    Feb 10, 2003
    1,003
    Boulder, Colorado
    “givethanks” gets you 15% off.
    I got a 10 degree light and pair of filters. Saved about $25.:clap
  9. George Hanson
    Feb 4, 2016
    936
    PA
    Ordered the 5.75" headlight unit for my Triumph. Eager to see how it works out, but will take Cyclops up on their offer to return it if it ends up not fitting or not being any better than the stock light.
    Will post photos when I get it installed (in January, most likely).
  10. Off Road Ryder
    Mar 29, 2010
    3,938
    Kent Wa
    You probably could mount on either side of the platform if using the under headlight mount, for the photos we used what we felt best. If I remember correctly we did place the long range lights and maybe the Pegasus lights on the bottom side of the mount. Let me catch up a bit from the long Thanksgiving weekend and readdress.
  11. Off Road Ryder
    Mar 29, 2010
    3,938
    Kent Wa
    Thank you
    Still good through midnight tonight.. The 1st time we have ever really offered a Sale. dealers get pissed off, so other than this time of year we are not able to do so.
  12. Off Road Ryder
    Mar 29, 2010
    3,938
    Kent Wa
    Thank you Sir!
  13. Off Road Ryder
    Mar 29, 2010
    3,938
    Kent Wa
    yes Sir good through midnight tonight code givethanks
  14. gsuks
    gsuks Long timer
    Oct 13, 2014
    1,600
    thank-you
    much aprecciated
    sorry about all the questions
    just want get it right in one go
  15. Off Road Ryder
    Mar 29, 2010
    3,938
    Kent Wa
    No need to apologize, I very much appreciate you asking.
    Here are some shots of the various lights we will be offering in the 790 package, there will be 3 mounts all together. two are done, the steel mounts under the headlight, one is a tad bit longer for the long range lights, the steel mount for the 2 inch and Pegasus lights are about an inch shorter. (the photos show the longer bracket on the Pegasus lights, the shorter one looks quite a bit better) The carbon/nylon mount to the support bar should be in production next week if not sooner.
    lots of photos of different setups, should be on the site very soon. for production we will make sure the studs are not to long like in some photos :)
    The wire harnesses will be included in the kit and are 100% plug and play into existing wire connection points on the bike. no splicing, no cutting, no soldering etc. If you choose the skene option, or no switch option there is a positap to the high beam power wire. The simplest install on any bike we offer a kit for.
    2 inch Aurora with DRL steel under headlight mount.
    2 inch Aurora DRL with Nylon/CF headlight support bracket
    Long range lights mounted up
    Long Range mounts mounted down
    Pegasus lights mounted up
    Pegasus lights mounted down
    gsuks and floalex like this.
  16. ebrew
    Nov 4, 2005
    2,156
    Denver colo
    The kits are up on the site
    I have ordered a set
    Go get them :)
  17. Off Road Ryder
    Mar 29, 2010
    3,938
    Kent Wa
    Thank you so Much ebrew! please let us know what you think. good, bad, ugly or otherwise.
  18. Off Road Ryder
    Mar 29, 2010
    3,938
    Kent Wa
    floalex and gsuks like this.
  19. gsuks
    gsuks Long timer
    Oct 13, 2014
    1,600
    thank- you the Aurora DRL look fantastic
    waiting for all options(brackets) to come up for the 790adv and make my choice and order them through my dealer in The Netherlands Rally-motor.nl
    a note on the multi function turn signals,
    are all the functions available or does that need a Raider for the different functions?
    Off Road Ryder and islano like this.
  20. Off Road Ryder
    Mar 29, 2010
    3,938
    Kent Wa
    Thank you. The raider is not needed for the MF turnsignals they are plug and play on almost any modern KTM.
