New oil return line assembly.....
Discussion in 'Crazy-Awesome almost Dakar racers (950/990cc)' started by Pyndon, Aug 2, 2009.
  1. Pyndon
    Pyndon Long timer
    Feb 4, 2006
    2,829
    Somewhere on two wheels!!
    Ok so my oil return hose 60038061103 has perished and the Katoom spawned another anti-corrosion system by spewing oil all over the engine, in a controlled fashion of course so as to not leave me stranded :D
    The pre-formed hose 60038061103 has now been superseded by 60038064000 which still returns oil to the tank but also links to the right hand side front rocker cover breather.
    Weird....anybody know why they have done this? I'd like to know before just fitting the part, and not only that, the new part is way more expensive....like 52 quid :eek1
    Cheers, Pyn
  2. uk_mouse
    uk_mouse Aquatic adventurer
    Jul 20, 2006
    1,850
    UK
    It does seem odd, given that the oil tank is already vented to the rocker cover.
    FWIW I used fuel hose (pressure rated 10 bar for FI systems) to replace the flexible oil lines on my 950. About £3 a metre, so somewhat cheaper than KTM's version :)
  3. DeeGee
    DeeGee I'm a Yorkshireman thanoz
    Jan 2, 2008
    1,913
    Up North In The UK!
    Look up a company called pirtek, they have franchises all over the UK they'll sort you out with some suitable hose at a fraction of the cost from KTM.
  4. YOGOI
    YOGOI Prick
    Jun 21, 2004
    3,761
    Logan, Utah
    Shoulda stuck with the stock skidder. Its metal isn't hard enough to wear a hole into the oil line. :deal
    :hide
  5. Pyndon
    Pyndon Long timer
    Feb 4, 2006
    2,829
    Yer numptly, it's the rubber oil return hose at the top of the oil tank!! :doh
    :wave Ken
    :D
  6. mookymoo
    mookymoo Mookish Mook
    Aug 26, 2007
    4,428
    Either UK or Australia ...
    I did read some vague mention somewhere that a dealer in the UK was referring to this update as a recall/TSB....
    Anyone know if there is a recent TSB to do with this?
    Where is CPModem when you need him? :ear
  7. YOGOI
    YOGOI Prick
    Jun 21, 2004
    3,761
    Logan, Utah
    :shog :zilla OOPs, Damb, I missed by a long shot.
  8. uk_mouse
    Jul 20, 2006
    1,850
    UK
    A cursory search of the interwebs reveals that the new part is described as "T-Connector with Reduction Ring" but none of the online parts fiches have a picture of it. The part is used on the 2009 Superduke for example but the drawings just show the old style hose.
    #8
  9. claferal
    claferal Been here awhile
    Aug 21, 2003
    157
    Madrid
    The reason is that any bikes had problems with the oil tank. The oil enter was parcially blocked, so the return hose was disconnected to the tank by the overpressure
    #9
  10. Vicks
    Vicks gets stuck in sand
    Oct 4, 2006
    3,395
    gone RTW...
  11. Pyndon
    Pyndon Long timer
    Feb 4, 2006
    2,829
    So, the TSB says that if the tool cannot be inserted into the tank then the new oil tube kit with bypass has to be fitted.
    I mean, my bike has done 60,000 miles so I think if the oil tank return tube was going to block from casting residue, it would have done so before now! My bike is definitely not called up on the list...me thinks.
    Nevertheless, if would appear that when your return hose fails / cracks after 6 years of abuse, you have to fork out for the expensive new hose assembly as it supersedes the earlier one...crazy!
    "Standard hoses may still be used on motorcycles that are not effected" - if you can get a new one.
    Anyway, in short the new assembly just allows the oil an alternative route in the event of blockage of the return tube in the tank casting.
    Pyn
    #11
  12. thugdog
    thugdog Druid Revisionist
    Sep 17, 2004
    396
    For what it's worth, my recent order from http://www.ktmcyclehutt.com/ included that same odd hose, and i was sent the straight version...slightly larger diameter at one end compared to the other (i.e., not the "T" version).
    You see, that weird little hose sometimes gets bent during various oil tank service / removal / loosening, so I just ordered one as a spare (for the spare), before my original hose someday eventually splits.
    #12
  13. YOGOI
    YOGOI Prick
    Jun 21, 2004
    3,761
    Logan, Utah
    Sounds like you should send your spare (for the spare) to Pyndon, insted of rubbing his nose in it. You know, chock it up to good karma or something.
    #13
