New part from BMW
Discussion in 'Airheads' started by Prutser, Jul 22, 2017.
  1. Arkwright
    Arkwright Grumpy ole Git
    Sep 1, 2009
    252
    Lincolnshire, Engerland
    So presumably the advance and retard is electronic and contained within the short bean can.
    What does it cost?
    #21
    SmittyBlackstone likes this.
  2. Prutser
    Prutser Long timer
    Aug 5, 2012
    2,073
    The Dutch swamp
    I would have to check the exact price but I thought it was just over 400€
    #22
  3. Arktasian
    Arktasian Feelin the BMEP
    May 23, 2014
    2,220
    BC
    That is a really nice looking item and perhaps adds a better level of timing control over the stock (& getting scarcer) electonic bean can assemblies - but I bristle at prices that climb that high - and my "MacGyver" mode for building a substitue takes over.
    #23
  4. mrclubike
    mrclubike Been here awhile
    Aug 11, 2014
    991
    O'Fallon MO USA
    I think this is a better alternative over the Emerald Island set up that is out there
    I have had 3 EI Ignition module and they all fell short of the 26 degrees of advanced that they were marked
    I only got around 20 deg of advance
    But on the other hand the new Bosch bean can is unproven for long term dependability
    #24
  5. Kiwiabbo
    Kiwiabbo Long timer
    Apr 16, 2014
    1,549
    Taihape New Zealand
    #25
  6. lurcher1000
    lurcher1000 Been here awhile
    Feb 10, 2012
    102
    DORSET
    So you use the standard ECU? If so it means that advance/retard provision must be in the bean can?
    #26
  7. Uke
    Uke visualist Super Supporter
    Oct 9, 2013
    6,178
    HouTex USA
    Visually, it appears to be a different unit from that which Prutser wrote about in the OP.
    Good to know there is a choice, your's being from Siemens and Prutser's from Bosch via BMW.
    Is the Siemens unit plug'n'play other than setting the timing?
    #27
  8. bmwrench
    bmwrench Long timer Supporter
    Nov 10, 2006
    9,049
    The "Siemens" parts look suspiciously like the EI stuff to me.
    #28
    Bulldust and Uke like this.
  9. AntonLargiader
    AntonLargiader Long timer
    Aug 28, 2003
    7,341
    Charlottesville, VA
    It is EI stuff. Maybe the sensors are Siemens and Motorworks is capitalizing - err, capitalising - on that.
    #29
    Uke likes this.
  10. Arktasian
    May 23, 2014
    2,220
    BC
    (Electronic Ignition in Homers case)
    #30
  11. Prutser
    Prutser Long timer
    Aug 5, 2012
    2,073
    The Dutch swamp
    I didn't get a long term test on this one. After stalling my bike out of the blue every time I rode it I took it off to return it to BMW.
    The bike did great when it kept firing. Noticeably better than the old type I was using(which was only one year old)
    #31
    Phreaky Phil likes this.
  12. Warin
    Warin Retired
    Aug 30, 2012
    14,616
    Put new O rings on the old unit and it too will be hard to push on.
    If the unit does not engage correctly it will sit high off the mounting flange, so I think a carefull installer would realise that something is wrong.
    The new unit will be able to be taken apart .. might be held together with glue and a tight fit to make it much harder .. but if it was assembled .. then it can be taken apart, sometimes the first one is a learning experience and then others can be done with less destruction.
    Looks like carrying a spare unit will be much easier now - much less space and you might even have it on top of the unit in use.
    #32
  13. Kiwiabbo
    Kiwiabbo Long timer
    Apr 16, 2014
    1,549
    Taihape New Zealand
    Yup just like standard stuff. Take out the old, install this. All good
    #33
  14. Malindi
    Malindi Zen Adventurer
    Jul 9, 2001
    5,966
    Vancouver, BC
    So does that mean you currently are not using a new one from BMW or did you get a replacement?
    #34
  15. Prutser
    Prutser Long timer
    Aug 5, 2012
    2,073
    The Dutch swamp
    At the moment I'm using my old beancan and returned the new unit to BMW. I hope to get a new one which doesn't cut out.
    For me the new one was just to feel if it was an improvement over the old one.
    #35
  16. Malindi
    Jul 9, 2001
    5,966
    Vancouver, BC
    Thanks, keep us posted ...
    #36
    hippie nl likes this.
  17. Arkwright
    Sep 1, 2009
    252
    We wondered whether it's made by Siemens and Motorworks are now just buying them direct!
    #37
  18. UnclePete
    UnclePete Long timer Supporter
    Nov 13, 2014
    1,076
    Plumas County , CA
    #38
    theDQG likes this.
  19. boxermoose
    boxermoose Regressive airhead Supporter
    Sep 18, 2003
    3,659
    Baton Rouge
    My understanding with the EI cans/ignition modules is the normal single spark advance is 21° and the dual spark advance is 26°
    I put the single spark can on my GS and at full advance the timing marks line-up bang on
    #39
  20. globalt38
    globalt38 "A Fist Full of Throttle" Super Supporter
    Apr 10, 2013
    2,443
    Atlanta
    I've got one on mine - satisfied with it - timing was fairly easy if I remember. It's an Emerald Isle (EI) as well I believe
    #40
    UnclePete likes this.
