New Thumper: SWM Superdual 650
Discussion in 'Thumpers' started by tangerine, Jan 15, 2015.
  1. Creechure
    Creechure Adventurer
    Jun 30, 2019
    55
    Melbourne
    Hit a more adventurous track yesterday, Just thought it would be meandering through the Bush but it ended up being about 5 or 6 back to back 45 degree + climbs and descents. The bike pulled up each of them like a tractor.
    Even managed to get some air off the berms in the track. Suspension was a little soft for that!
    mrsdnf and Richarde1605 like this.
  2. Creechure
    Jun 30, 2019
    55
    Melbourne
    Shortcut through the fire trails didn't go as planned.
    More off road today and the bike holds up fantastically, and is very forgiving. 1200kms in the last 3 days and the only time the bike fell over at the end of today after it was sat on the side stand for 5 mins or so.
    CapeG650X and Richarde1605 like this.
  3. cyclopathic
    cyclopathic Long timer
    Dec 23, 2007
    9,580
  4. Rotax655
    Rotax655 Aprilia World Meeting
    Dec 10, 2009
    680
    If I can around the world
  5. cyclopathic
    Dec 23, 2007
    9,580
    Nope. Just normal riding on public tajik roads.
    From what I can tell there was a defect weld on right side of support and the mount is under-enginered for ADV use in general.
  6. fortrider
    fortrider Been here awhile Supporter
    Oct 6, 2005
    964
    Homeless
    Not good to see that photo. Hopefully will get shown to SWM and reengineered.
    Dutch idiot likes this.
  7. Rotax655
    Dec 10, 2009
    680
    Did you have a lot of cargo on board while traveling? how many kg or pounds?
  8. Syanur
    Syanur Been here awhile
    May 11, 2012
    189
  9. cyclopathic
    Dec 23, 2007
    9,580
    I'm about 65kg and carry ~35kg so 110kg + riding gear not too unreasonable. I did catch a few especially big potholes just because you can't avoid all of them.
  10. cyclopathic
    Dec 23, 2007
    9,580
    Soft except for rotopax; ditched top case a while back. Haven't had on scale guessing ~35kg. Bike 2.5mo old just above 12k/20000km.
  11. mrsdnf
    mrsdnf Long timer
    Feb 8, 2019
    1,221
    Lost between the Dandenongs and Yarra Valley
    Is that the rear shock top mount?
  12. cyclopathic
    Dec 23, 2007
    9,580
    Yes
  13. mrsdnf
    mrsdnf Long timer
    Feb 8, 2019
    1,221
    I'll have to keep an eye on it.
    Your riding all up weight is about my body weight alone.
    Have you been in contact with SWM?
  14. cyclopathic
    Dec 23, 2007
    9,580
    I have sent this to factory; just got back to civilization a few hours back. Had been riding along the border with Afghanistan for a couple days now. Good thing it happened where it did would have been worse if it happened in the middle of nowhere.
    Yes check it regularly the ECU is just above it. Mine got nicked but still works. And yes it will be a bitch to get shock out you have to take exhaust apart.
  15. mrsdnf
    mrsdnf Long timer
    Feb 8, 2019
    1,221
    Thanks cyclopathic. All the best for getting it repaired. Did they ever find out why your bike was cutting out at high RPM?
  16. cyclopathic
    Dec 23, 2007
    9,580
    No I called dealer at Osh (hopefully will get there eventually) and it doesn't sound like they will be helpful. Will have to wait until I get back to Europe which may happen next year.
    Maybe I should get a job as SWM tester..
    mrsdnf likes this.
  17. Rotax655
    Dec 10, 2009
    680
    the rest of the bike in what condition is it? Has the bottom of the run also caused the battery holder to break?
  18. vsaltao
    vsaltao Been here awhile
    Oct 14, 2013
    229
    Portugal
    damn..... another guy that did a big trip also had a crack there (he reinforced it and was able to finish the trip) . I dont think the te630/rs650 frame is being able to support that type of weight (generelay the subframe breaks on those before you have time to break that part...).
    My rs650 is ok but i never put that type of weight on it (also the bike is ovral alot lighter so less stress on that part)
  19. Creechure
    Jun 30, 2019
    55
    Melbourne
    Hmmm, makes me re-think treating my bike like an enduro in the fire trails.
  20. cyclopathic
    Dec 23, 2007
    9,580
    Battery/holder is out of the way and won't be affected. It's the ECU which will be in the harms way and the cross bar it's mounted on.
    Rotax655 likes this.
