1. ** Enter to win a $250 gift card! We want to hear from you, please take this survey **
    Take this survey which covers a range of questions about improving the community, the things that interest you and anything else you want to share with us. All responses will remain anonymous.
    Click here to take the survey
    Dismiss Notice
New Thumper: SWM Superdual 650
Discussion in 'Thumpers' started by tangerine, Jan 15, 2015.
  1. mrsdnf
    mrsdnf Long timer
    Feb 8, 2019
    1,103
    Lost between the Dandenongs and Yarra Valley
    Sorry, I cant help with that.
  2. DavAmb
    DavAmb Adventurer
    Apr 10, 2015
    72
    10 Mins from PI
    Can anyone help out with the best Barkbuster part numbers/kit for the SDX? Is the "Storm" for the SM650R the closest thing? Or is there a Husky kit that's the best option? I could get the bits underway while there's not much else to do.
    (I'm assuming the lockdown will end and that they'll lift the medical suspension on my license... some day...)
  3. mrsdnf
    mrsdnf Long timer
    Feb 8, 2019
    1,103
    DavAmb and Suncoaster like this.
  4. DavAmb
    DavAmb Adventurer
    Apr 10, 2015
    72
    10 Mins from PI
    Thanks maaaaate!
    mrsdnf likes this.
  5. L_Bomb
    L_Bomb Strewth and blimey
    Jan 21, 2013
    227
    Perth Straya
    My clutch hose ripped out of the master cylinder in a low speed tumble with Rox risers. I took the broken hose and fitting to a brake shop and they knocked up a new one 100mm longer than stock
    cyclopathic and mrsdnf like this.
  6. bigbobby
    bigbobby n00b
    Aug 28, 2013
    3
    Queanbeyan
    I was going to go for 75mm but 100mm would free it up nicely.
  7. MotoSly
    MotoSly Adventurer
    Oct 11, 2019
    78
    East Flanders, Belgium
    No, but the clutch cable does.
    So you have to reroute it or put a longer one on.
  8. mrsdnf
    mrsdnf Long timer
    Feb 8, 2019
    1,103
    Suncoaster likes this.
  9. MyRedStrom
    MyRedStrom Adventurer
    Nov 11, 2006
    28
    Wasatch back, Utah
    Hi all. New 2020 SD-T owner here. Traded in my 2017 Africa Twin DCT for it. The Superdual is much better for the kind of riding I like to do, and I needed something lighter for sure. I had previously ridden a Husky TR650 that I *really* liked and the SD was a perfect fit for me.
    My first question is about installing a power socket. I pulled off the panel under the windscreen, where the manual refers to a 12-volt power supply connector. The manual just says "Connect the device using the relevant connector." So what's the "relevant connector"?
    The wiring diagram shows two wires to an "additional power supply", but the connector that's really there has 6 wires. Here's a pic:
    It looks almost, but not exactly, like an AMP 070 Econoseal-J Mark II Series Sealed Connector, if that helps. Thanks for any pointers.
    MotoSly likes this.
  10. mrsdnf
    mrsdnf Long timer
    Feb 8, 2019
    1,103
    Rotax655, WolfNman and Suncoaster like this.
  11. CapeG650X
    CapeG650X Been here awhile
    Mar 28, 2009
    234
    Kalgoorlie
    I just run mine off the battery with an inline fuse. I use usb sockets with a switch, most are backlit so need to be able to switch off when not in use.
  12. cyclopathic
    cyclopathic Long timer
    Dec 23, 2007
    8,787
    There's a regular connector behind I have posted location and link to Amazon where to buy them.. around July 2019. The connector in picture is OBDI for programming if I am not mistaken.
  13. MM2020
    MM2020 Adventurer
    Sep 22, 2020
    15
    Pacific Northwest
    Bought my SDX last December and have been following this thread for a while. Enough with the lurking, I guess.
    MyRedStrom, you have to dig a little deeper to find the right connector:
    I ended up snipping it off and replacing it with a 2-Pin SAE quick connector.
    mrsdnf likes this.
  14. cyclopathic
    Dec 23, 2007
    8,787
    Rotax655 and mrsdnf like this.
  15. MyRedStrom
    Nov 11, 2006
    28
    Wasatch back, Utah
    Found it! Thanks Cyclopathic and MM2020. It was buried on the left side. Proceeding to order the connector for 12-volt outlet now.
    Edit: Actually, this looks like a better match (two pins instead of one): https://www.amazon.com/dp/B08579V5ZJ
    MM2020 and Rotax655 like this.
  16. cyclopathic
    Dec 23, 2007
    8,787
    The ones I referred are the ones on my bike and they fit 100% this is from my amazon order history. I made a 4-way spider with heated grips, phone charger, electric gear and cigarette lighter connected to it individually.. used 5 sockets in total but it lets me disconnected each individually if something goes wrong, no soldering while traveling.
    MM2020 and mrsdnf like this.
  17. MyRedStrom
    Nov 11, 2006
    28
    Wasatch back, Utah
    Very cool - I'm going to steal that idea!
    Sorry I haven't read back through the whole thread yet - did you beef up your stator or do anything to support the increased power load?
  18. cyclopathic
    Dec 23, 2007
    8,787
    No just LED everything (except for turn signals) to get more headroom. Heated grips (link below) come with voltmeter in full winter mode I have to kill some load when I come in town to avoid discharging battery.
    https://www.amazon.com/dp/B00NYBZ4CQ/
    You would probably want to replace 5A fuse too.
  19. mrsdnf
    mrsdnf Long timer
    Feb 8, 2019
    1,103
    Removed the air filter housing to see where the wiring ran for the voltage regulator. I'll post pictures up later of the wiring, needless to say it could have been run in a more appropriate place.
    I noticed the rubber air outlet of the airbox to the throttle body had a much reduced diameter to it compared to the throttle body intake side. I could not find a picture of the husky to compare it with. Looks like it could be to reduce air intake noise for emissions. Not sure I'm game to enlarge the rubber boot outlet to match the throttle body.
    MotoSly, Syanur and Rotax655 like this.
  20. mrsdnf
    mrsdnf Long timer
    Feb 8, 2019
    1,103
    I've got an upgraded regulator coming along with a Lithium battery. I will also upgrade the earth wiring while I'm at it.
    The wiring to the standard regulator runs across the lower airbox mount bracket so is sandwiched between the bracket and airbox. I'm not sure this will cause any long term damage as there is no movement there but just doesn't look good. It can be re routed behind the bracket where there would be no chance of it being damaged.
    Theres no damage to the loom in the above picture. Its just very squashed and dirty from oil out of the airbox.
    MotoSly, Rotax655 and Suncoaster like this.
