New Thumper: SWM Superdual 650
Discussion in 'Thumpers' started by tangerine, Jan 15, 2015.
  1. MM2020
    MM2020 Adventurer
    Sep 22, 2020
    44
    Pacific Northwest
    Yes, it does. Air filter oil has that color. At least mine does. I suppose you could open it up and squeeze/drain it a bit. Careful when tightening the cover bolts. There have been several reports on this forum of them being easily over tightened and spinning loose inside, resulting in a major pain in the neck.
    mrsdnf likes this.
  2. panchogarrancho
    panchogarrancho Been here awhile
    Aug 19, 2009
    274
    Nicaragua,Miami
    Very much so
  3. MotoSly
    MotoSly Been here awhile
    Oct 11, 2019
    153
    East Flanders, Belgium
    Well i just love titanium in general. and because i had to go to M10 i tought " why not go titanium"..
    mrsdnf and MM2020 like this.
  4. MotoSly
    Oct 11, 2019
    153
    processed.jpeg Gave her a new look :) pretty happy with it
    mrsdnf likes this.
  5. MM2020
    MM2020 Adventurer
    Sep 22, 2020
    44
    Pacific Northwest
    MotoSly likes this.
  6. MM2020
    MM2020 Adventurer
    Sep 22, 2020
    44
    Pacific Northwest
    Haha! Fair enough...
    MotoSly likes this.
  7. cyclopathic
    cyclopathic Long timer
    Dec 23, 2007
    9,583
    Would never do anything but black fender.. don't wanna get blinded by own headlight in the dark.
    MotoSly likes this.
  8. MotoSly
    Oct 11, 2019
    153
    i get that, and it doesn't cause i blacked out the windscreen ;)
    cyclopathic likes this.
  9. cyclopathic
    Dec 23, 2007
    9,583
    Hopefully won't be on terrain where you have to stand.
    After a 60mph deer touchdown I personally developed dislike to riding in the dark, so this is usually not a problem, but as saying goes it isn't a problem until it is. Wrong turn, unexpected terrain, flat can put you where you didn't expect to.. be safe.
    MotoSly likes this.
  10. MotoSly
    Oct 11, 2019
    153
    I totally agree, i don't ride the dark for fun.
    But it is also my commuter, and that means early mornings are dark or when i go home it also gets dark in winter times.
    That's why i made it better for dark rides. ( installed a 2300lumen LED on the front, cause the original light is a joke )
  11. kimokk
    kimokk Been here awhile
    Nov 11, 2009
    201
    NOVA
    Has anyone had an issue with the shock absorber adjuster jabbing your left calf while standing? Is there anyway to rotate or relocate this adjuster?
  12. MotoSly
    Oct 11, 2019
    153
    hm
    mm...no never had that problem . and i already did 20K on mine, with allot of offroad.
    Do you have a picture? cause it sounds like it's more outward and or forward than it should be...
    Rotax655 likes this.
  13. kimokk
    Nov 11, 2009
    201
    NOVA
    I will post a pic later when I get home. Thanks!
    MotoSly likes this.
  14. CapeG650X
    CapeG650X Been here awhile
    Mar 28, 2009
    266
    Kalgoorlie
    I just moved the reservoir to the inside of the bracket.
    kimokk likes this.
  15. kimokk
    Nov 11, 2009
    201
    NOVA
    Thanks, but won’t that interfere with the shock movement? Or gas tank? Seems kind of tight in there. I will give it try later.
    42D136D0-A50E-41C3-9DA0-DB09C0A61402.jpeg 709BDC53-2636-4293-AF74-E12ECAF3E346.jpeg BF8164D0-CEEC-43CB-988F-0AE556581581.jpeg
  16. cyclopathic
    Dec 23, 2007
    9,583
    What year is yours? The earlier ones had adjuster mounted in such way that it would stab into calf; the trick was to undo and mount it slightly deeper.. like they did on later ones.
    EDIT: skip to 5:30 mark. IIRC Paul had an earlier vid on preload dial but I can't find it
    Here it is
    Rotax655, mrsdnf and kimokk like this.
  17. MotoSly
    Oct 11, 2019
    153
    Fuelpump broke. This pos bike is going.. cause it's nothing but trouble.
  18. mrsdnf
    mrsdnf Long timer
    Feb 8, 2019
    1,222
    Lost between the Dandenongs and Yarra Valley
    What part of the fuel pump is at fault?
  19. cyclopathic
    Dec 23, 2007
    9,583
    There were a couple ozzies back in 2018 which had fuel pump failed due to filter clogging and overheating in TJ due to bad fuel.. knowing that I put fuel sock. Other common fuel pump failure is contact corrosion/burn but I have not heard about that on SWM.. typical on aging BMWs. Also usually not a good idea to run tank dry often as it can cause pump overheating too.
    MM2020 likes this.
  20. DavAmb
    DavAmb Been here awhile
    Apr 10, 2015
    121
    10 Mins from PI
    Bought a new battery (MotoBatt MBYZ16H) yesterday as the original had croaked after 2 years of on-and-off top-up charging. Bloody tight fit! But she cranked-over ok and burst into life no problem. I'll get out for a run in the next couple of days.
    MM2020 likes this.
