New Thumper: SWM Superdual 650
Discussion in 'Thumpers' started by tangerine, Jan 15, 2015.
  1. jumper12
    jumper12 n00b Supporter
    Apr 23, 2016
    9
    oregon
    Where is the neutral safety switch located? My manual does not show it in the electrical components section.
    I'm guessing that the switch on the clutch lever is involved.
  2. Rotax655
    Rotax655 Aprilia World Meeting
    Dec 10, 2009
    713
    If I can around the world
    check this part number. the neutral gear signal comes from 8000A6751
  3. cyclopathic
    cyclopathic Long timer
    Dec 23, 2007
    9,766
    Follow the link in post by Mr Moose below, the answer is likely there.
  4. dready bear
    dready bear Been here awhile
    Jun 8, 2009
    312
    somewhere in scotland
    Hi all.
    After a wee bit of advice.
    Im over in New Zealand (where bikes tend to cost more sadly) and I've been offered a brand new (2019) SuperDual T with $2000 off, so $11,000 nzd, $7600 usd, £5500. With all the panniers etc from the dealer.
    I've previously done 120,000km round the world on my custom f650 Dakar but sadly I dont have it in NZ.
    Anyway,
    1- how reliable are the SD's?
    2- I will want to fit 21/18 as I do offroad as much as possible, can I just fit husky wheels?
    3- what are the top offroad and road mods I can do
    4- any preventive measures I could do for reliability etc
    5- best weight savings mods.
    6- any exhausts that fit or single can setup
    7- should I just buy the Tenere 700 :shog
    Newton_McMarv likes this.
  5. Newton_McMarv
    Newton_McMarv Adventurer
    Nov 30, 2018
    19
    Germany
  6. mrsdnf
    mrsdnf Long timer
    Feb 8, 2019
    1,252
    Lost between the Dandenongs and Yarra Valley
    This is a picture I took of one of the head stem bearing. Not sure if its top or bottom though.
    Suncoaster and Rotax655 like this.
  7. Rotax655
    Dec 10, 2009
    713
  8. DavAmb
    DavAmb Been here awhile
    Apr 10, 2015
    139
    10 Mins from PI
    The blokey article backdrop looks a bit sus...
  9. mrsdnf
    mrsdnf Long timer
    Feb 8, 2019
    1,252
    That's a picture and article about me. :-)
    Suncoaster likes this.
  10. DavAmb
    Apr 10, 2015
    139
    10 Mins from PI
    Ah! That's why it looked familiar!
  11. Hallbag
    Hallbag n00b
    Jul 20, 2018
    1
    Alice Springs
    I have a 2018 Superdual T, and it has the 43mm Fastace forks.
    mrsdnf likes this.
  12. MotoSly
    MotoSly Been here awhile
    Oct 11, 2019
    164
    East Flanders, Belgium
    just buy a T7.... the SD has allot of problems when it comes to reliability... + parts for the T7 are so much easier to find.
  13. Victorspecial
    Victorspecial Adventurer
    May 8, 2021
    10
    Bend, Or
    I'm struggling with removing the rear wheel. The manual says it just drops out but that is not my experience. The brake caliper is in the way and I can't see how to remove it with the wheel in there. Any advice? Many thanks.
  14. Victorspecial
    May 8, 2021
    10
    Bend, Or
    Ok, I wish I'd tried one more time before posting. Feeling stupid:shog
    roookie1, rvt, MotoSly and 1 other person like this.
  15. Daza750
    Daza750 n00b
    Feb 12, 2021
    3
    Brisbane, Australia
    Thought I would post an update to this saga. SWM told the workshop that they could not supply an engine and they would have to order all the parts separately and build it themselves, seriously! It ended up being a seized crankshaft. After 4 1/2 months the shop managed to convince SWM to supply a complete motor from the factory. Yes that right, the bike has been in the workshop for 4 1/2 months. And better yet, expected delivery of the new engine is early December. That will be 7 1/2 months in the workshop by then. Now starting down the complaints process to try and get a refund.
    MotoSly likes this.
  16. MotoSly
    Oct 11, 2019
    164
    i had to get a new engine at 18000km..... bike also was in the shop for 3 months. SWM is just a no go anymore if you want reliable bike and service...
  17. mrsdnf
    mrsdnf Long timer
    Feb 8, 2019
    1,252
    Does anyone know why their engines failed?
    @Victorspecial How did you end up getting the wheel out? I let the air out of the tube and the wheel comes straight out.
    MotoSly likes this.
  18. MotoSly
    Oct 11, 2019
    164
    The oil mesh filter exploded inside the case.. leaving nothing but pieces of metal inside the case.
    Got a brand new engine after 3 months of going back and forward between dealer and SWM for waranty etc... And the new engine also had those half ass oil mesh filters inside it.
  19. mrsdnf
    mrsdnf Long timer
    Feb 8, 2019
    1,252
    Thanks MotoSly.
    Has anyone checked their clutch basket? Dealer said they have not had any issues.
    MotoSly likes this.
  20. AMGrrr
    AMGrrr Adventurer
    Feb 25, 2019
    65
    Melb Australia
    Hey guys. Have a bit of an issue with my Sup Dual X after it was sitting for a while. Went for about 7 months without starting it. After that it was very difficult to start. Clearly off fuel so drained the tank and put fresh fuel i with injector cleaner.
    Have used a tank of fuel with injector cleaner in it and still have cold starting issues. Have also disconnected the battery for a few hours but that made no change.
    On a cold start I'll hold down the starter and it'll crank over sort of slowly and won't start (battery in good condition amd on a Ctek battery temder). I'll have to hit the kill switch on amd off to reprime the fuel punp amd try again. Sometimes I need to do this 20 times before it starts. Sometimes it turns over like it's starting, then dies. Takes ages to start.
    Hot starts are instant, like cold starts used to be before the off fuel.
    Any tips?
    Cheers
