New Thumper: SWM Superdual 650
Discussion in 'Thumpers' started by tangerine, Jan 15, 2015.
  1. kimokk
    kimokk Been here awhile
    Nov 11, 2009
    201
    NOVA
    A picture is worth a thousand words! I found this in the Husky TE-630 repair manual. Why couldn’t SWM just have added this one pic and paragraph?
    CaptnineT and Syanur like this.
  2. kimokk
    Nov 11, 2009
    201
    NOVA
    See my post above. ^^^^
  3. Tarmac Teaser
    Tarmac Teaser Adventurer
    Jun 28, 2019
    59
    Perth WA
    That's a much better explanation than the Swm instructions. Now see if you can find a detailed instruction on valve checking and adjustment.
  4. kimokk
    Nov 11, 2009
    201
    NOVA
    Here you go...
  5. kimokk
    Nov 11, 2009
    201
    NOVA
    Syanur likes this.
  6. kimokk
    Nov 11, 2009
    201
    NOVA
    However, I think the SWM manual says 0.10-0.15 mm for BOTH intake and exhaust clearances. This is different from the TE-630 specs.
  7. cyclopathic
    cyclopathic Long timer
    Dec 23, 2007
    9,762
    Out of curiosity: has anyone taken the 3rd filter out and found any significant deposits?
    I'm not gonna do it bike is too dirty and just did oil change but will ask dealer in Osh along with adjusting valves.
  8. Tarmac Teaser
    Jun 28, 2019
    59
    Perth WA
    Kimokk, Thank you for that. This will make it easier to maintain the bike after the warranty runs out. I just need to buy that spring tool.
    kimokk likes this.
  9. kimokk
    Nov 11, 2009
    201
    NOVA
    Spring tool is cheap. DIY!
  10. Tarmac Teaser
    Jun 28, 2019
    59
    Perth WA
  11. Rotax655
    Rotax655 Aprilia World Meeting
    Dec 10, 2009
    710
    If I can around the world
  12. Rotax655
    Dec 10, 2009
    710
    these are the indications on the valve clearance for the RS650R and are identical to those of the TE630. the minimum value coincides with that prescribed for the Superdual. DISTRIBUTION
    Guy . double overhead camshaft; commanded
    from chain; 4 valves
    Valve clearance (with cold engine)
    Suction. . . . . . . . . . . . . . . . . . . . . . . 0.10 ÷ 0.15 mm
    Drain. . . . . . . . . . . . . . . . . . . . . . . . . . 0.15 ÷ 0.20 mm
  13. Tarmac Teaser
    Jun 28, 2019
    59
    Perth WA
    kimokk likes this.
  14. kimokk
    Nov 11, 2009
    201
    NOVA
  15. Rotax655
    Dec 10, 2009
    710
    in my opinion they report the minimum value below which it is not recommended to go down. a valve with "too much" operating clearance only creates noise. a valve with "little" backlash lower than the values indicated by the manual 0.10 and 0.15 can cause serious damage to the head. also consider that usually with increasing km the game decreases and rarely increases
    kimokk likes this.
  16. Tarmac Teaser
    Jun 28, 2019
    59
    Perth WA
    Considering the rs650r and superdual are the same engine there are certainly some discrepancies in the information being provided by Swm
    E.g engine oil
    Rs650r 2016 requires Motul 5100 semi synthetic 10W50
    Superdual 2017 requires Motul 5100 semi synthetic 10w50
    Superdual 2018 requires Motul 7100 fully synthetic 5W40
    These are the same engines with the only difference being euro 3/4 compliance.
  17. kimokk
    Nov 11, 2009
    201
    NOVA
    @Tarmac Teaser
    Can you ask your dealer what the specs should be? The dealer here in the states told me they haven’t been given a service manual yet from the company or importer.
    cyclopathic likes this.
  18. cyclopathic
    Dec 23, 2007
    9,762
    Are they using the same valves/material? The reason exhaust valve clearances are higher because they run hotter and expand more.
    IIRC SD used titanium valves on one side and Ti has a different expansion coefficient.
    EDIT: yes Ti thermal expansion rate is ~1.5 times less than steel so if exhaust valves are Ti same clearances would make sense.
    kimokk and ratguzzi like this.
  19. Tarmac Teaser
    Jun 28, 2019
    59
    Perth WA
    My dealer is useless unfortunately. If you want to be on the safe side set them at 0.15mm each which will keep them in spec. I suspect if I put the bike in for a valve adjustment they would use the 2017 model specs. There is no service manual currently available to us for the superdual 2018+ only the owners manual.
  20. radmann10
    radmann10 Old fart Supporter
    Apr 29, 2014
    2,848
    Valley of the Sun/hot part of AZ
    Good info, thank you for posting!
