New (to Me) 2000 Kawasaki W650
Discussion in 'Road Warriors' started by The Jerk, Oct 11, 2009.
  1. Caesars_ghost
    Caesars_ghost Air Cooled.
    Sep 13, 2015
    755
    Midwest
    Another awesome write up. Thanks!
  2. abhiram
    abhiram Been here awhile
    Jul 24, 2018
    187
    Oakland, California
    Dope writeup!
    Btw, those handlebar vibrations you mentioned at first, are they less now?
    My bike has similar symptoms, but I am yet to check if there is any play in the forks. So curious :hmmmmm
  3. acap650
    acap650 acap650
    Apr 10, 2006
    1,174
    Western PA
    Great and thorough technical step by step by The Jerk. Have you ever considered writing tech manuals? (Maybe that's what you do-I haven't read all your posts or bio)
    You said if either of the bearings or races are bad replace both, I take that to mean replace the complete bearing - two races and rollers. I do not think it is always necessary to replace both bearings since in my experience only the lower bearing which supports all the weight of the front tends to develop a notch. If there are other defects, rust, pitting etc. on both, then by all means replace both.
    I have done this on a BMW F650GS twin, a bike which tends to notch head bearings prematurely (mine was notched at 12K miles). On this bike there were notch lines on the lower bearing races but the upper bearing looked new so only the lower bearing was replaced. BMW has a novel method for preloading the bearings that involves three steps and requires a torque wrench, easy because bearing preload is done with a 10mm allen bolt. With only the lower clamps torqued and the front wheel installed, initially torque adjuster bolt to 25nm, rotate wheel left to right three times, back off bolt 60 degrees, then apply final torque of 10nm. I do this at every oil change.
    On my W650 all I ever did was check and adjust so that the front wheel, off the ground, would barely fall right and left. At 30K miles bearings were still smooth with no center notch. Some have drilled and tapped the steering head for a grease fitting. That would entail filling the entire space between the bearings with grease. That seems like overkill to me and would result in seeping grease in hot weather and stiffness in the cold.
  4. Sniperx
    Sniperx Long timer
    Jul 1, 2013
    1,212
    Socal
    Oil leak...
    Anyone ever change the oil tube orings? I think it’s leaking from there. From reading the service manual....it’s quite involved. Any ideas?
  5. The Jerk
    The Jerk Bring us some fresh wine!
    Mar 6, 2006
    2,784
    Brooklyn, NY
    I should have been more clear; what I meant by that was that when replacing a bearing, one should replaced both the bearing and its corresponding race. Some people try to take the easy way out by replacing just the easy part (the bearing) while leaving in the old race because it's difficult to swap out.
    Your point about the lower bearing usually getting the worst of it is well-taken; however if I had to go through the trouble of replacing one of the bearings, while I was in there I'd do both. If you must replaced, be sure to source good quality bearings. I think you can still get the OEM ones from Kawasaki though bearings are generally standard sizes. I found the OEM ones to be Koyo brand made in Japan. Other good quality bearing manufacturers are FAG and SKF.
  6. The Jerk
    Mar 6, 2006
    2,784
    Brooklyn, NY
    Yes, seems to be. I took it for a short test ride in the 50-60 mph range where I was having issues before. There was no sign of the vibration there. Another symptom I had experienced was a head shake when decelerating through about 40-30 mph if the bars were held very loosely. I haven't ridden since because I was waiting for a replacement upper fork clamp bolt to arrive. Need to do a longer ride to be sure.
    abhiram likes this.
  7. The Jerk
    Mar 6, 2006
    2,784
    Brooklyn, NY
    Looking at the manual it doesn't look THAT bad - looking at the "bevel gear case removal" procedure starting on page 4-45. As long as you are just looking to replace the o-rings and not doing any further disassembly of the bevel gear system.
    It appears you can do the job without disturbing any of the cam gear backlash settings which would be the big concern.
    You would want to have all the parts you need on hand - it appears there are 4 o-rings for the bevel drive shaft and it appears there are additional o-rings within the bevel gear case, as well as a gasket for the bevel gear case. Also you have to replace the e-clip and snap ring with new parts.
    There are two additional o-rings on the parts diagram but it's not clear to me that you can get to them without further disassembly of the bevel gear drive. Those are 92055-1593. So I guess the question is whether it's one of the upper or lower o-rings that are leaking or whether it's one of the 4 in the shaft cover. If the latter, that looks pretty doable. If the former, that might be more of a challenge. I can't tell from the manual, but perhaps you would be able to get to and replace those other 2 o-rings once the cam gear driveshaft is out and the bevel gear case is off the engine.
    Parts you would need to do the 4 o-rings in the driveshaft cover:
    92055-1617 - o-ring, x4
    92033-1307 - snap ring, x1
    92033-1306 - snap ring, x1
    11060-1890 - gasket between bevel gear case & crankcase, x1
    670D1507 - o-rings in bevel gear case, x2
  8. Sniperx
    Sniperx Long timer
    Jul 1, 2013
    1,212
    Socal
    Thanks for the reply, but I’m talking about the oil feed and return tubes that go through the head at the rear of the cylinder. I think I’ve got to take the cam off to do it....
  9. The Jerk
    Mar 6, 2006
    2,784
    Brooklyn, NY
    Oh man I totally misread that one. Oh well there's a parts list for anyone with a leaky bevel drive tube :lol3
    That said, taking the cam off isn't so hard.
  10. TBilly
    TBilly Billy
    May 27, 2018
    4
    Dublin,Republic of Ireland.
    Still not sure on the Colour scheme here....?
  11. mattsz
    mattsz moto-gurdyist
    Jun 3, 2012
    1,062
    Coastal Maine
    I was gonna say, "it's grey." But I'm guessing that's not what you meant...
    aside: how did you attach those files - they appear to be stored in an advrider location called "attachments," which I wasn't aware was available...
  12. Sniperx
    Sniperx Long timer
    Jul 1, 2013
    1,212
    Socal
    Does the yahoo page even work anymore? I can’t join or see anything. Why is anyone using that antique anyway....
  13. ORexpat
    ORexpat Oregon Expatriate Supporter
    Jan 7, 2007
    3,842
    West of Seattle . . .
    Works fine for me . . . but then I'm a Luddite . . . .
  14. millenbop
    millenbop Adventurer
    May 4, 2017
    87
    Sweden
    I'm too young to use it.
  15. millenbop
    May 4, 2017
    87
    Sweden
    I like the colour scheme, it's understated. (Personally, I'd get rid of a lot of the extra accessories though).
  16. BravoFox
    BravoFox Twin With a Kick
    Apr 25, 2013
    1,743
    France
    Ahem...
    It's not the color scheme which is the problem man, it's the windshield and top case and TV screens-like mirrors that just kill all the W beautiful lines and proportions. She looks like a family piece of junk as seen on the roads of many third world countries... :fpalm
  17. Speedo66
    Speedo66 Transient
    Jan 14, 2010
    9,435
    Cin City, OH
    I'm too old to use it.
    millenbop likes this.
  18. Caesars_ghost
    Sep 13, 2015
    755
    Midwest
    ...pretty sure that’s an insult to third world pieces of junk. I’d take a ratty two stroke 125 over those mirrors, any day.
  19. BlunderBolt
    BlunderBolt Been here awhile
    Apr 7, 2016
    123
    Stockholm, WI
    It has at tasteful turn signals. Smaller than stock but not so small as to be tastefully unsafe.
  20. ORexpat
    Jan 7, 2007
    3,842
    Some of us use our bikes as tools, not merely toys. Though one could be a wee bit more tasteful in their selection of tool boxes . . . . I got lucky and found some well-used Craven's here in ADVrider.
    I often use mine to commute to the MSF range. Lunch and coffee on one side, rain gear on the other, and the teaching bag in the top case. And I've used the little dear for demos in the MSF Advanced Course.
