New (to Me) 2000 Kawasaki W650
Discussion in 'Road Warriors' started by The Jerk, Oct 11, 2009.
  1. Sniperx
    Sniperx Long timer
    Jul 1, 2013
    1,212
    Socal
    Anyone have a working link to the yahoo page? The W650/800 riders page doesn’t work for me. I push “join” and a little “loading” tab blinks at the top and that’s it. Other groups will bring up a join page, but not this one. I’ve tried iPhone and Mac both safari and chrome....
  2. Sniperx
    Sniperx Long timer
    Jul 1, 2013
    1,212
    Socal
    Ok....WTF....seriously....
    I went from a link from captain jakes...and gave the join button one last mash. Well fuck me sideways....it worked.
    There’s a reason the world abandoned yahoo.....
  3. Caesars_ghost
    Caesars_ghost Air Cooled.
    Sep 13, 2015
    755
    Midwest
    The Yahoo group used to be fairly lively a few years ago judging by the archives. Now it’s pretty dead, with only a few posts per month. I guess that’s what happens when a bike is pushing 20?
  4. BravoFox
    BravoFox Twin With a Kick
    Apr 25, 2013
    1,748
    France
    As you certainly have noticed ORexpat, none of my steeds are really trailer queens either. :lol3
  5. ORexpat
    ORexpat Oregon Expatriate Supporter
    Jan 7, 2007
    3,843
    West of Seattle . . .
    Nope, haven't seen either featured in "Cafe Racer" or winning ribbons at the local custom bike show. But parked in front of interesting places, or ridden on small tours, yep! Keep it up, young feller . . . . .
    :hide
  6. BravoFox
    Apr 25, 2013
    1,748
    France
  7. Chuck Pryce
    Chuck Pryce Been here awhile Supporter
    Feb 1, 2006
    560
    western n.c.
    There is one on Asheville’s Craigslist, no affiliation with the seller
    mitchxout likes this.
  8. mattsz
    mattsz moto-gurdyist
    Jun 3, 2012
    1,062
    Coastal Maine
  9. ORexpat
    Jan 7, 2007
    3,843
    Dimpled tank, non-OEM turnsignals, some other damage that the seller says he'll fix, for a price. That front dimple and the presumably broken OEM front left turnsignal are exactly what happend to mine before I bought it.
  10. BravoFox
    Apr 25, 2013
    1,748
    France
    I wouldn't buy a 20 year old bike with only 900 miles.
    If it's a scam, you get screwed. If it's the real mileage, you get screwed even worse.
  11. BravoFox
    Apr 25, 2013
    1,748
    France
    MW56018-155_156_W3_3_1024x1024.jpg 18301338_1703323439694383_6724079950446482304_n.jpg IMG_E0477.JPG
    Scoozi and Tritwin like this.
  12. Sniperx
    Sniperx Long timer
    Jul 1, 2013
    1,212
    Socal
    Can you change the jets on these without pulling the carbs? It’s probably not fun, but can it be done? I got a set of pipes and headers for 120$ and I’d like to strap em in there.
  13. The Jerk
    The Jerk Bring us some fresh wine!
    Mar 6, 2006
    2,784
    Brooklyn, NY
    Yes you can. As you said, it's not fun, but it can be done. You can change the pilots & mains without pulling the carbs. Can also swap out the needles without pulling the carbs either, but you will need to pull the tank for that.
    Basically you just need to drain & drop the float bowls. Tricky parts are getting to all the float bowl screws and disconnecting/reconnecting the accelerator pump linkage without having 3 hands. You will also need a small screwdriver/bit to remove/install the pilot jets. I use a smaller-than-normal (I.e. smaller than 1/4") screwdriver bit in a socket with a 1/4" drive ratchet.
    Here's a view from the bottom so you can see what's what. This is of course carbs removed and on the bench. I have one float bowl removed in this pic. For your purposes of course you would not need to worry about removing the rubber hose connecting the two float bowls. Just drop both float bowls with the hose connecting them. The accelerator pump is only on one carb and comes out attached to the float bowl. The float bowl screws are easy to strip so take your time and ensure you have the screwdriver bit fully seated in the screw. Don't overtighten when re-installing.
  14. The Jerk
    Mar 6, 2006
    2,784
    Brooklyn, NY
    I'm planning for a front brake caliper rebuild, seems I'm getting some slight symptoms of a dragging brake...and also I noticed that the service manual calls for the caliper piston fluid & dust seals to be replaced every other time the brake pads are replaced (!!)
    I'm quite certain that 20 years on I've got the original fluid & dust seals and I think things are just getting a little sticky. So I'm going to take the opportunity to replace all the rubber parts at the caliper.
    For the knowledge base: looking at parts vendors, it appears that Kawasaki has NLA'd both the front caliper assembly and front brake disc for the W650.
    W650 Caliper Assembly: 43041-1709-DJ
    W650 Brake Disc: 41080-1462
    Both are listed as no longer available.
    However, it appears that most if not all of the individual caliper parts are available so rebuilds are still possible with OEM parts. Just for kicks I took a look at the W800 parts fiche and compared part numbers with the W650 caliper parts and they are all identical. Therefore it would appear that if you needed a complete caliper, you could buy the W800 caliper and it would bolt right up. I think based on the description it appears that the finish might be different, as the W800 caliper is described as "black." I would also bet that the W800 disc would bolt up to the W650 but I don't know for sure. At any rate, here are the part numbers:
    W800 Caliper Assembly: 43080-5028-DJ
    W800 Brake Disc: 41080-0014-33J
    As for a rebuild, you can buy everything you need for less than $50.
  15. ORexpat
    Jan 7, 2007
    3,843
    Jerk, I've rebuilt that front caliper too. There's a small photo spread earlier in the thread.
    Both sets of seals are readily available from any Kawasaki dealer.
    I also fitted an EBC rotor. Works really well.
    Additionally I had a stainless steel brake hose built at a local hydraulic hose fabrication facility. Wasn't very expensive; probably less than ordering online. And I watched them test the hose to 3000 psi, much more than they'll ever see from my old fingers!
    That front brake rebuild was a revelation. Brakes are excellent now. I'd call this a highly recommended project.
  16. clinton11
    clinton11 Adventurer
    Dec 8, 2015
    52
    West Virginia
    I want to say thanks to Jerk for the great write up on the head bearing greasing. Really awesome guide, I'm sure I'll be referencing it soon.
  17. mattsz
    Jun 3, 2012
    1,062
    Coastal Maine
  18. BAGSTR
    BAGSTR One Project a Day
    Jul 8, 2006
    697
    San Diego
    Hey People,
    I have a Left Side engine cover in a box for 18 years. ( minor Scratch caused me to replace it ) A few other take-offs from new; front brake line, mirrors and maybe a bit more.
    Any interest here?? San Diego area.
    Bagstr
  19. bringenufgun
    bringenufgun Been here awhile
    Oct 9, 2010
    876
    apparently halfway to motorcycle hell
    new to me:
    Scoozi, TBilly and mitchxout like this.
  20. pjensen641
    pjensen641 Long timer Supporter
    Jun 1, 2006
    2,557
    Boone, IA
    Well, Royal Einfeld just announced US pricing and availability on this.
    47HP 650 twin. Very similar to the W650 (no need to comment on reliability etc, I understand).
    Looks like we shall see if the W650 equation was just a bit to far ahead of its time! To me, the new Bonnevilles are in a class slightly above this and the original W650 in terms of complexity/cost/performance with the 900 twin being pretty close though.
    http://www.motorcycledaily.com/2018...with-north-american-pricing-and-availability/
    Question will be, is the cost difference or other intangibles enough to draw someone to these vs a 900cc Bonnie?
