New (to Me) 2000 Kawasaki W650
Discussion in 'Road Warriors' started by The Jerk, Oct 11, 2009.
  1. The Jerk
    The Jerk Bring us some fresh wine!
    Mar 6, 2006
    2,784
    Brooklyn, NY
    No hammers please! If you need a hammer it means you missed something. :D
    BravoFox nailed it, you really need two 12mm Allens for this job. I have two 12mm Allen sockets which I can put on two breaker bars. One to apply a counterhold while I loosen the other one. One of the 12mm Allens is part of the axle while the other one is basically a nut that threads on to the other end of the axle.
    Keep note (or refer to the manual) which way the axle goes in and also note that the spacers are different widths so keep note (or again, refer to manual) as to which one goes on which side when putting it back together.
  2. jimbo-drxc
    jimbo-drxc Adventurer
    Aug 4, 2015
    14
    Devon, England
    Many thanks - I don't think the workshop manual explained that very well (could be me). 12 mm Allen key just ordered.
    BravoFox likes this.
  3. Speedo66
    Speedo66 Transient
    Jan 14, 2010
    9,441
    Cin City, OH
    Cut a piece off your Allen and hold with a wrench.
  4. mattsz
    mattsz moto-gurdyist
    Jun 3, 2012
    1,062
    Coastal Maine
    ^ This. They fit good in a 12mm socket, too!
  5. The Jerk
    Mar 6, 2006
    2,784
    Brooklyn, NY
    Does anyone have any thoughts/feelings on the humble disc brake anti-squeal shim?
    Does anyone even know if this is a Kawasaki part? It's not shown on the parts diagram. I *think* this was on my original pads when I replaced them with EBC, so I moved it to the EBC pads. This time when I rebuilt my caliper, I left it off. I have not had any pad squeal with or without the shim and on closer inspection it looked like one of the tabs may drag a little bit on part of the caliper so I decided to try it for a while without the shim (easy enough to put back in if needed).
  6. BravoFox
    BravoFox Twin With a Kick
    Apr 25, 2013
    1,748
    France
  7. ChairmanMaose
    ChairmanMaose OneLessCar
    Feb 23, 2017
    2,025
  8. BravoFox
    Apr 25, 2013
    1,748
    France
    Beautiful October....
    mitchxout, Tritwin and Scoozi like this.
  9. mattsz
    Jun 3, 2012
    1,062
    Coastal Maine
    Beautiful, as always!
  10. BravoFox
    Apr 25, 2013
    1,748
    France
    Thanks :thumb
  11. mattsz
    Jun 3, 2012
    1,062
    Coastal Maine
    But watch out for whatever heavy vehicles are making a mess of that road...
  12. ChopperCharles
    ChopperCharles Long timer
    Jun 7, 2006
    7,450
    Durham, NC
    When a truck fails through there and comes off a turn, I've seen the tow truck plant itself into the pavement while using the tow cable to pull the trailer sideways -- after liberally oiling up the wheels and pavement. This creates two big divots in the pavement where the truck digs in. I don't know what this part is called, but it digs into the pavement near the apex. This then needs to be repaired. Perhaps a truck or two got stuck recently.
    I have a video of that from 2006 or so... unfortunately with a shitty camera (It was 2006 they were all shitty digital cameras back then). I might have even posted it in this thread ages ago.
    Charles.
  13. abhiram
    abhiram Been here awhile
    Jul 24, 2018
    187
    Oakland, California
    Hi all,
    Is there a trick to pulling the spark plugs out of thier recessed holders?
    I was able to use a ratchet with a 16mm sprocket to unscrew them, but they wouldn't come out.
    Gave up and torqued them back to spec.
    FYI, I don't have the toolkit that came with the bike. I am using a spark plug socket, I bought off Homedepot.
  14. pjensen641
    pjensen641 Long timer Supporter
    Jun 1, 2006
    2,552
    Boone, IA
    I use a magnet meant for retrieving dropped parts. But the spark plug socket should have a rubber element that grabs the spark plug too.
    abhiram likes this.
  15. mattsz
    Jun 3, 2012
    1,062
    Coastal Maine
    The OEM toolkit socket has an interior sleeve for grip. The magnet probably will work; or maybe you could get some sort of thin foam or something and roll a layer into your socket to accomplish the same...
    abhiram likes this.
  16. abhiram
    Jul 24, 2018
    187
    Oakland, California
    Cool! Thanks for the quick reponse guys.
    Will give your suggestations a go this week!
    Cheers!
  17. mitchxout
    mitchxout Long timer
    Jan 24, 2004
    1,983
    Asheville, NC
    If you have a piece if small fuel hose, you can fit it on top of the plug after it's loose but not unthreaded all the way. Then carefully unscrew using the hose extension.
  18. mattsz
    Jun 3, 2012
    1,062
    Coastal Maine
    ^ this, too. I've done it with clear plastic tubing left over from my beer brewing days...
  19. jimbo-drxc
    Aug 4, 2015
    14
    Devon, England
    Knee grips - can you fit the early fat type onto later tanks with the slimmer grips? Do they have the same brackets with captive nuts?
    Got my fat ones on ebay but a prospective buyer says his tank doesn't have the brackets. Thought they were interchangeable.
  20. The Jerk
    Mar 6, 2006
    2,784
    Brooklyn, NY
    Owner's toolkit still available! Only $91.72! :D
    (actually though it is a pretty good toolkit especially relative to what comes with bikes nowadays)
    abhiram likes this.
