NEW Trailtech Voyager Pro - speculation and rumour
Discussion in 'Mapping & Navigation' started by iggs, Oct 17, 2014.
  1. mfaoro
    mfaoro Been here awhile
    May 29, 2008
    243
    the Cascade foothills, WA USA
    What’s the ETA on turn-by-turn over Bluetooth?
    Get this and I will happily throw my Zumo through a window.
    I love not having to constantly look at the GPS.
    mauroarriagada and ohgood like this.
  2. td70
    td70 Adventurer
    May 16, 2017
    19
    Will the billet protector have the same attachment points as the one for the Voyager? Will I be able to mount it where the factory mount point is, in front of my head clamp on my KTM? Thanks in advance for your response and keeping us all updated.
  3. TThelper
    TThelper Adventurer
    Dec 13, 2013
    45
    No, as we use AMP spacing for RAM mount compatibility. There are 4 mounting bolts instead of the Standard Voyagers 2. The protector sandwiches between the Voyager Pro dock and whatever 4 bolt AMP spec mount you choose to use.
  4. klinquist
    klinquist übergeek
    Apr 7, 2008
    1,360
    San Jose, CA
    Looks like I over-tightened the retention hex screw with the supplied hex key.... and stripped it... so now the voyager pro is stuck in the mount.
    Looks like I'll have to drill it out!
  5. ohgood
    Sep 21, 2010
    7,809
    alabama
    turn by turn has been very carefully avoided in conversation so far .... :-(
  6. TThelper
    TThelper Adventurer
    Dec 13, 2013
    45
    We are working on it and should be a firmware release in the near future. We are testing it to make sure it is solid and what we want. I have no firm date for you at this time.
  7. ohgood
    Sep 21, 2010
    7,809
    alabama
    it's gonna sell a lot of units.... :-)
  8. TThelper
    TThelper Adventurer
    Dec 13, 2013
    45
    We understand and it is high priority for us. Thanks.
    ohgood likes this.
  9. mfaoro
    May 29, 2008
    243
    That’s great to hear.
    A question for you: last year, I bought the Griptwister tour/tracks for circumnavigating the Olympics.
    The tour depends on being able to see both the track and associates waypoints.
    Because the Garmin Zumo (my GPS) requires you to convert a track into a route it loses the waypoints (at least that’s how I remember it). I had a hell of a time navigating that route and depended on my friend who was running an old Garmin 60csx.
    Does your GPS allow you to follow a track (without converting it to a route) and will waypoints display on the screen while following the track?
    Michael
    Ps. I could live without it, but the weather functionality on my Zumo has saved me a
    Few times or at least helped me prepare in advance for some serious storms. Hint hint
    mauroarriagada likes this.
  10. mauroarriagada
    mauroarriagada Been here awhile
    Nov 28, 2015
    466
    Sammamish
    Using mine on the TT Rally I found that the heads-up perspective view is great but the arrow and track lines are too small/thin. It would be great if we had an option to configure that so it can look bigger/thicker to see it better while riding.
    I would also be a happy beta tester for you guys.
  11. TThelper
    TThelper Adventurer
    Dec 13, 2013
    45
    The Voyager pro imports GPX files and should retain the route and waypoints. I have never seen it not retain the waypoints. If you want to send us the file we can load it and look at it.
  12. TThelper
    TThelper Adventurer
    Dec 13, 2013
    45
    This is feedback we have heard before and working on options for enhanced viability. If you turn off topo lines and hillshading the map will be super simple (only shows roads and routes) and easy to read.
  13. EnduroFever
    EnduroFever BRAAAP!
    Feb 10, 2014
    90
    Twin Cities, Minnesota
    Is there a beta program or way I could get in on testing firmware and providing feedback?
  14. mfaoro
    May 29, 2008
    243
    Will send you a PM.
  15. mfaoro
    May 29, 2008
    243
    And another question is, are tracks routeable? Can I follow a track on the device without converting it to a route (like the Zumo forces you to do)?
  16. therak
    therak n00b
    Jun 6, 2015
    8
    Melbourne
    I'm considering getting a Voyager Pro for my Husky 701 and I'd like to remove the stock ( very basic ) speedo. Will I have to install a magnet setup like on the older trail tech units to get wheel speed or will I be able to plug the stock wheel sensor in somehow?
  17. EnduroFever
    EnduroFever BRAAAP!
    Feb 10, 2014
    90
    Your going to need the TT sensor as our ABS speedo sensor doesn't put out usable pulse... I have spent a lot of time tryi gnto use the ABS speedo sensor signal for the PCV as well with no success either.
  18. therak
    therak n00b
    Jun 6, 2015
    8
    Melbourne
    Ah bugger. Thanks for the info, might just keep the little stock one and mount it somewhere else
  19. ptgarcia
    ptgarcia Huh?
    Apr 26, 2009
    724
    Alta Loma, CA
    Does this unit not have a GPS-based speedo?
  20. Jeff@TheQuadShop
    Jeff@TheQuadShop TAT survivor
    Nov 28, 2004
    7,111
    Crestwood, Kentucky
    It does
