NEW Trailtech Voyager Pro - speculation and rumour
Discussion in 'Mapping & Navigation' started by iggs, Oct 17, 2014.
  1. NSFW
    NSFW basecamp4adv
    Feb 20, 2007
    21,122
    Burbank CA
    in fact i can see both gps speed and wheel speed on the same screen side by side. that's awesome since i can calibrate the wheel speedo using the signal from the gps.
    StanBo likes this.
  2. NSFW
    NSFW basecamp4adv
    Feb 20, 2007
    21,122
    Burbank CA
    finally got the time to play with the buddy tracking. we tried them out in my neighborhood where there are homes, trees and other buildings blocking off the line of sight.
    started out good, both units are active and we can see each other on the map display....:clap
    if you see the "X", meaning we lost communication. if that happens, ride to a higher ground or go closer to my buddy.
    notice HQ is not X anymore, meaning the 2 units are communicating again
    afaik, it's pretty slick and effective at least a mile. could be better in the desert or where there's little obstruction. can't wait for the heat wave to go away so i can try it else where.
    StanBo, ohgood and advmoto66 like this.
  3. dirtbikekid
    dirtbikekid Adventurer
    Mar 7, 2009
    26
    Need some advice, might be simple thing but still. Installing voyager pro to my husky 701, should i wrap the tach sensor cable into inner or outer spark plug, and to which cable (orange or white&purple) trying to do the "option 3" from TT instructions. I have the tach sensor with 1 cable, black casing over red.
  4. Magus
    Magus Never grew up...
    Jan 25, 2006
    355
    Texas and Colorado
    I was told by TT that taping the sensor to spark plug wire rather than wrapping is good option as well. For me, I had to play around with location until I got a reasonable rum readout.
  5. EnduroFever
    EnduroFever BRAAAP!
    Feb 10, 2014
    90
    Twin Cities, Minnesota
    On the 701 and 690 the sign isn't strong enough to tap... I tried, have troubleshot and spent time talking got Justin at TT. You need to wrap the bottom of the coil.
  6. dirtbikekid
    Mar 7, 2009
    26
    Do you have a photo how you did it, wrapping ?
  7. EnduroFever
    EnduroFever BRAAAP!
    Feb 10, 2014
    90
    I wish I did... I'm traveling with my wife on our bikes in Canada right now so I haven't participated much in this thread but I pulled the inner plug boot (not the smaller outer plug) and wapped it 4 times around the bottom where they pop over the top of the spark plugs.
    I also used a single wrap of wiring harness tape to keep it in place. I ensured no conductor was exposed at the end of the wire as well as cutting everything to length.
    RPMs are matching my PCV POD-300 perfectly.
    For the wheel wheel sensor I ended up replacing one of the bolts with TT's magnetic bolts.
    TThelper likes this.
  8. TThelper
    TThelper Adventurer
    Dec 13, 2013
    45
    Do it just like option 4 shows in your image you posted for the 690/701.
  9. td70
    td70 Adventurer
    May 16, 2017
    19
    Any updates on the release of the Protector?
  10. mauroarriagada
    mauroarriagada Been here awhile
    Nov 28, 2015
    469
    Sammamish
    And the new firmware? :)
  11. BDO
    BDO Been here awhile
    Jun 22, 2015
    257
    Transported Tube
    Following...
  12. td70
    td70 Adventurer
    May 16, 2017
    19
    How are people mounting the Voyager Pro if they are running HDB top clamps and handguards? There's no room for clamps with this configuration.
  13. dirtbikekid
    Mar 7, 2009
    26
    I made temporary bracket from carbon fiber plate that i had laying around. not pretty but it works.
    first photo is rough cut which i made nicer & smaller once i had all the places figured out. second photo is how it looks now. IMG_0513.jpg IMG_0520.jpg
  14. td70
    td70 Adventurer
    May 16, 2017
    19
    Thanks, nice work. I've got the Rottweiler Performance bracket for the BRP bracket, but the antenna attachments get in the way. I'm hoping Paul is going to make a mount or the new protector will provide some options.
    mauroarriagada likes this.
  15. zipperpotamus
    zipperpotamus n00b
    Jul 15, 2018
    7
    Australia
    I ended up making (bodging) a bracket that holds the voyager just above the factory speedo, as I wanted the odo to keep ticking. Still uses factory mounts on the voyager and the bike, and is low enough to be flush with the headlight surround. Also, has anyone had any luck getting the unit to work with regular Bluetooth headphones? I can pair, but no audio.
  16. mauroarriagada
    Nov 28, 2015
    469
    Sammamish
    Have the same problem. I’ve paired it with my sena 20s and iPhone and no audio
  17. TThelper
    TThelper Adventurer
    Dec 13, 2013
    45
    We are not seeing that issue and have paired and played audio on the Sena 20S, iPhone, and Sena momentum helmet with zero issues as well as a slew of other intercoms. Please call our Tech support. (844) 378-8143
    Have you tried starting the music on the phone itself instead of the Voyager? Will it play?
  18. zipperpotamus
    zipperpotamus n00b
    Jul 15, 2018
    7
    Australia
    The music plays (according to progress bar) and phone says it is playing on voyager pro, volume at max, but there is no audio at the headphones. Have tried a few devices, to no avail. However no ‘intercom’ style devices, only headphones.
  19. GO_OUTSIDE!
    GO_OUTSIDE! dirty hippie
    Jun 29, 2011
    399
    SF Bay Area California
    Ive been using garmin handhelds on my rides for years. I am not a fan of garmins ui and am waiting for something better. PLEASE get the turn by turn sorted so i can but one. Or maybe offer a satisfaction gaurantee so i can buy one now. Thank you for stepping up for us and saving us from garmin.
    mfaoro, ohgood and EnduroFever like this.
  20. Ck622
    Ck622 Adventurer
    Sep 23, 2012
    53
    For those having problems with audio, change the name of your phone to anything that doesn’t contain “iPhone “
    I had the same problem and that’s what tech support told me to do. It worked.
    AugustFalcon and zipperpotamus like this.
