New Xmax 300 !
Discussion in 'Battle Scooters' started by wibble, Sep 16, 2017.
  1. Wdoney
    Wdoney Been here awhile
    May 15, 2019
    259
    O'Fallon, MO
    My wife recently bought a new Honda CRV with Honda Sensing. It is pretty amazing stuff and I am sure will pretty soon be standard in most cars. Some of the higher end motorcycles are also incorporating many of the safety and convenience features as well. Over time they will trickle down to the less expensive scooters and motorcycles. Frankly I was surprised the XMAX came with traction control as a standard feature.
  2. Wdoney
    May 15, 2019
    259
    O'Fallon, MO
    I have been using 87 which I think is what Yamaha recommends. No advantage that I can see to using a higher octane. Some will claim all kinds of advantages to using premium but none have been proven from what I have read when used in an engine designed for regular.
  3. crazygordon297
    crazygordon297 Adventurer
    Nov 11, 2019
    53
    Key Largo FL
    I use rec 90 only because I don't ride it often. It's good for marine outboard and can't hurt. I had a Chinese 150 cc scooter that had some problems and I think it's because I didn't use it often enough. One gallon would last around two months therefore the fuel turned into some water.
  4. Glen e
    Glen e Been here awhile Supporter
    Aug 31, 2018
    812
    Fort lauderdale, fl
    This is debated on every car forum I’ve ever been on ad infinitum, much like when to change the oil or what wax to use...LOL. I agree, use the octane that the manufacturer recommends, because that’s the way they build the engine and calibrate it. Google the question and read for days.
    exception: If I was going to store the bike for a couple months.I’d use 91/93... Because 87 octane does degrade quickly. According to Sunoco website, 87 starts to degrade after three months, 91 grade lasts for nine months. Rec 90 non-ethanol is a perfect choice. So I would use it when I put it away.
  5. Glen e
    Aug 31, 2018
    812
    Fort lauderdale, fl
    Exactly ....when BMW came out with active cruise control in 2002 on their 740i, the option was $2500 bucks. Just for that. Now Honda makes it standard on most of their mid level trims, even down to the civic.
  6. S/W
    S/W Long timer Supporter
    Oct 21, 2003
    1,132
    Massachusetts
    You have to remember how much BMW marks things up. As an example, a BMW CVT belt for a 650 GT scooter is priced at $388.64 retail. You can buy the exact same belt from Europe for around $100 bucks and shipping isn't that much.
  7. Glen e
    Aug 31, 2018
    812
    Fort lauderdale, fl
    Parts prices are not the point. Yes Bmw inflates their pricing, I would never own one out of warranty, Too expensive. The point is most features come into the marketplace with a tremendous cost because there’s no economies of scale, once they ramp up, things get cheap. ABS Was a huge cost on cars when it came out, and it was an option. Now it’s standard on every econobox that comes out of the Pacific rim.
    ClearwaterBMW likes this.
  8. S/W
    Oct 21, 2003
    1,132
    Massachusetts
    Cruise control was invented in 1948 and even in the Seventies you could get a kit for a couple hundred bucks and now the kits aren't much more. Today it is electronic throttle control that makes it cheaper to add as most of the parts are all ready there. There were never a lot of parts to cruise control , even the old vacuum systems had only a few parts , it's hard to use the economy of scale in this case, the technology has been around for a good while. Bikes without electronic throttle control will not see cruise control anytime soon. Of course you can get a throttle lock for that will hold the throttle for down to around 30 bucks, I had one, but, now that I have real cruise control on one of my bikes, that's what I want !!
    Ivabign likes this.
  9. ClearwaterBMW
    ClearwaterBMW The Examiner Supporter
    Jul 17, 2005
    9,905
    Clearwater, FL USA
    you are correct about that I had 11 BMW I always bought the extended warranty but as to your comment about ABS it's available on every model because it's the law across the Earth you can't sell a car without ABS now
  10. dirtmarine
    dirtmarine Been here awhile
    Jul 21, 2014
    414
    Kansas City
    Do these provide any mechanical advantage? I have an 8.5" hand size and relatively strong. Wondering what advantages might be of changing the pull distance or lever length. There seem to be several brands out there.
  11. Wdoney
    May 15, 2019
    259
    O'Fallon, MO
    They do not provide any additional leverage as they do not extend out any further than the stock levers. The main purpose of these levers is to be able to adjust them closer to the bars for those with short fingers. You can also adjust the length if you like a shorter lever. If the stock levers fit you and your style the adjustable levers bring little value. They do have a hinge in them to help prevent breakage in a fall which is an interesting feature. I have a similar set but did not like them and put the stock levers back on.
  12. dirtmarine
    Jul 21, 2014
    414
    Kansas City
    Good feedback, thnx
  13. Mr:River
    Mr:River n00b
    Jan 29, 2020
    6
    Uberlândia-MG Brasil
    Hello, would anyone have link manual service Xmax 250/300 year 2018 to 2020?
    Download via pdf.
  14. BigBaloo
    BigBaloo Been here awhile
    Sep 3, 2019
    562
    Scotland
    Aye, very interesting when they fold up out the way when you go to grab them for an emergency stop.
  15. Glen e
    Aug 31, 2018
    812
    Fort lauderdale, fl
    There is a 4mm nut you can tighten if you dont want them to fold.....There is no advantage to these type levers if the stock levers are close enough to your hand and it’s comfortable. I like them pulled in 3 to 4 mm, closer to the bar. Easier to pull with my hand.
  16. ismatts
    ismatts Been here awhile
    Mar 13, 2019
    109
    WisCanSan
    I have the manual on PDF. I do not have a place to host it, but if you have somewhere I can upload it to.... I will do that for you.
    The PDF is 153megs
  17. Wdoney
    May 15, 2019
    259
    O'Fallon, MO
    The levers I bought have a spring and ball detent in the hinge to prevent them folding up due to your going over a bump etc. It takes a little force to get them to fold.
  18. donmac
    donmac casual angler
    Jun 26, 2010
    716
    East Coast
    ismatts, was able to upload the pdf to my dropbox. Thanks!
    If anyone would like a copy msg me and I'll send you a dropbox link
    I will leave this available for a few days then reclaim the space.
    hdamok, minimac and ismatts like this.
  19. Mr:River
    Mr:River n00b
    Jan 29, 2020
    6
    :clap
    rivellycius@gmail.com
    ismatts likes this.
  20. donmac
    Jun 26, 2010
    716
    East Coast
    link on the way ;)
    for everyone else, please share your email address with me via the adv message app rather than posting it all here...
    Mr:River likes this.
