    Dismiss Notice
New Xmax 300 !
Discussion in 'Battle Scooters' started by wibble, Sep 16, 2017.
  1. dbeth
    dbeth Adventurer
    Aug 5, 2019
    46
    South Central Wisconsin
    I had ordered some rivets at the beginning of the month, and they just came in on Friday. I didn't find them elsewhere, but they're exactly what I needed.
  2. BigTexasOne
    BigTexasOne Motorcyclist
    Nov 8, 2007
    3,841
    1 acre of heaven, Springtown, TX. NW of Ft. Worth
    They generally are a standard size, and I've found generic ones at virtually every good metric motorcycle dealership of parts shop.
  3. Speedtrap
    Speedtrap Adventurer
    Feb 5, 2014
    89
    I’m curious to hear how that works out for you.
  4. donmac
    donmac casual angler
    Jun 26, 2010
    642
    East Coast
    Did you order them online? or through a dealer? All sorts of sizes/styles on Amazon. Any chance you can confirm the part number?
  5. dbeth
    dbeth Adventurer
    Aug 5, 2019
    46
    This is the part number I ordered off of Partzilla a few weeks back and just received last week. Ordered some extras. Wasn't having luck finding them on Amazon...sorry (but I also wasn't looking insanely hard either).
    donmac likes this.
  6. kpinvt
    kpinvt OLDnSLO Supporter
    Jan 22, 2007
    840
    Most Peculiar, Vermont
    I can send you some of the ones I found, I just have to find them first. They came from Cycle Gear or Revzilla.
    Edit\ They are the CG house brand Trackside. Nylon Push Rivet 6mm.
  7. donmac
    Jun 26, 2010
    642
    East Coast
    Thanks KP, appreciate it but no need to send. I’ll just order some!
  8. kpinvt
    Jan 22, 2007
    840
    I
    It probably won't.
    Speedtrap likes this.
  9. ismatts
    ismatts Been here awhile
    Mar 13, 2019
    101
    WisCanSan
    Do you have an update?
    My update is frustrating. Called Monday this week and they said they havent even looked at it yet.
  10. X-Hannibal
    X-Hannibal Adventurer
    May 27, 2020
    52
    Germany
    The repair of my XMax is done one week ago. The repair shop installed a new cylinder head and changed the oil filter and the engine oil.
    The following picture shows the damage:
    Since then I have driven 400 km and the scooter works great as if no engine damage has happened.
  11. dirtmarine
    dirtmarine Been here awhile
    Jul 21, 2014
    372
    Kansas City
    Time for oil change XMAX 300. My local shop has the filter but not the 20-40 oil which the manual recommends for hot weather. Nor do they have the 85W GL-3 gear oil but the option is 10w-30 for that. Since I can't find Yamalube in either of those weights locally is it ok to use a high quality full synthetic from local auto supply as long as it meets the Yamalube standard, Mobil 1, etc.? I'm not sure if Yamalube is full synthetic or if they require a non full synthetic for those applications.
  12. dirtmarine
    Jul 21, 2014
    372
    Kansas City
    Thats got to be one in a thousand or more. Glad it runs perfectly.
    X-Hannibal likes this.
  13. Glen e
    Glen e Been here awhile Supporter
    Aug 31, 2018
    742
    Fort lauderdale, fl
    It’s absolutely OK. Yamaha does not own a refinery. They buy their stuff from one of the oil manufacturers, mobile 1 will work fine. I use 10 W 40. Have Used it for years…
  14. BigBaloo
    BigBaloo Been here awhile
    Sep 3, 2019
    455
    Scotland
    Any 10w-40 motorcycle oil will be fine for the engine and any 10w-30 motorcycle oil will be fine for the final drive.
    I stick cheap car oil in mine but am a complete tightwad.
    No mention in my Xmax300 user manual of any engine oil other than 10w-40, absolutely nothing mentioned about different grade for hot weather...?
    Have you actually read your manual or are you relying on information from bike shop?
    Bike shop staff often speak pish.
    Glen e likes this.
  15. Glen e
    Aug 31, 2018
    742
    Fort lauderdale, fl
    So just an update on the turn signal relocation discussed above. It is such an easy mod, I don’t know why I was thinking it was difficult. I had no idea you could leave the lights on the bike until the post was made above.(Thanks) A 1 inch hole saw, as discussed above cuts out the blank perfectly, and although I don’t have any turn signals to cut off the attachment part, I simply glued them into place with silicone seal, which will allow me to take them off easily if I need to. As you can see in the picture they point straight back so they’re easy to access…The turn signal wires going down to the turn signals are illustrated by the arrow. Pull them back up and re-wire.I cut off the turn signal brackets with a sawzall.
    bulbs:
    https://www.amazon.com/gp/product/B06XK4PL33/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1
    by the way, I love these connectors vs std heat shrink/butt connectors, they melt solder on the joint:
    https://www.amazon.com/gp/product/B07NZ9L48L/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
  16. aguim
    aguim Long timer
    Dec 27, 2007
    1,070
    Northern Quebec
    Rotella T6 15w40. Everywhere. It's as good as ANYTHING else, and half the price, if not
    less.
    Wdoney likes this.
  17. dirtmarine
    Jul 21, 2014
    372
    Kansas City
    Yes I've read the manual several times, thank you! On page 10-1 it has a temperature chart with corresponding recommend oil weights. For my region I would use a SAE 20W-40 as I would be riding in a temp range of 50 to 100+F. It also gives the recommended oil grades. I recommend reading your manual for any equipment and then determining what allowances can safely be made and thus my questions. So I will be using a full synthetic in the recommended weights.
  18. fm13
    fm13 Adventurer
    Dec 12, 2019
    22
    Limousin , France
    Dirtmarine, I ride in the same temperature range as you. Just had a 1000km service. The Yamaha shop use 10/40 in both the engine and final drive.
  19. dirtmarine
    Jul 21, 2014
    372
    Kansas City
    I think mine did to. It will get er done. So much for the manual. Not a big difference anyway. Wonder if they recommend full syn after break-in? If they do it probably not. I plan to anyway.
  20. Glen e
    Aug 31, 2018
    742
    Fort lauderdale, fl
    I don’t think they make a distinction. Just remember synthetics are great for extended oil changes. That’s why they were requested for the car companies. It does really little good when we’re changing every on a regular basis. However, synthetics are so cheap you might as well…
